My first was a taurus and my 2nd was a SHO....!!
I got a mustang now but always atop to check out a taurus...
they have changed design so many times....although the 500 looks good..
I need to go to the mustang forum to complain on the new mustang-based interceptor design...
later...
Guesses - didn't put 'clips' in or in correctly or entire rotor is not tightened down correctly.
Dont forget to follow the procedure for seasoning the rotors before bedding the pads. If you do not season the rotors 1st, you may experience less than optomal brake performance.
As a reminder... here is a link which describes seasoning the rotors before bedding the pads. http://www.shotimes.com/brakes/part1.html
http://www.speedibleed.com
http://www.speedibleed.com/products/completekit2.php
I use the same brake pressure bleeder also and love it. When I phoned them they told me about some newer DIY kits that will be available soon on their website at
The hard pedal would indicate either loss of power brake vacuum to the booster (a leaking vacuum line to the booster?) OR a jammed up relief valve in the master cylinder itself.
Don't know about this "sensor" thing, not sure what they are talking about...maybe an ABS issue? I guess ABS problems are a possibility.
The remidy is the same either way... Replace the calipers. There is no way to "fix" stickey caplipers that will last very long.
Today, it started to make the godawfullest noise, first only when I hit the brakes, later just when the wheels were turning, like it was rubbing metal to metal, and it didn't feel like I had ANY breaks when I got it home.............. Any suggestions I can take to the dealership tomorrow (other than some I can't print, and probably shouldn't tell them about anyway if I want this fixed)? I'm wondering if they maybe didn't put the wheels/brakes back on right?
Installing new pads necessatates pushing the caliper pistons back into the cylinders. Oftentimes, with old calipers, this causes the calipers to "stick" and not release the brakes when you let go of the brake pedal. This it the first thing I would look for.
The only real fix for this condition is to REPLACE the calipers. It is NOT the fault of the mechanic.... just old calipers.
Of course, there are other possibilites - let us know how it works out for you.
If your new master cylinder differs from the original in piston-size, this will also be a factor in your brake-pedal effort.
Sorry for the late response. The email got caught in my spam filter. I just found because I bought a new version of Norton ISS.
I had to adjust the rod to the very end. Actually, I turned it until the first thread on the nut showed. It still has some slack in it before the brakes engage, but its a lot better...maybe 90% better.
Thanks again.
Perry
Of course it could also be caused by a bad caliper with a stuck piston, but then it would most likely be that way all the time, not just when the brakes get heated up to normal operating temperature.
-mike
-Perry
Thank you for your information and suggestion
-mike
Intake manifold gasket - $600-$900 depending on if it is done by dealer or independent shop.
Metallic and semi-metallic brake pads extra.
Ceramic brake pads extra.
Low dust brake pads extra.
Rotors and drums will only be resurfaced if they meet certain criteria. New rotors and drums are extra.
Dot 4 brake fluid extra.
Foreign cars extra.
Electronic wear sensors extra.
Brake pads with wear tabs extra.
Brakes with anti-squeal backings extra.
And the list goes on
Best Regards,
Shipo
But, no... there is no "fine print" in the ad. They do run a LOUD SCREAMER ad on the radio that is a real turn off... almost as loud as Kia's radio ads. :sick:
Also it's kinda funny, because almost all brakes on cars these days have squeeler tabs and anti-squeek backings. So basically they are offering this service for a car brake pad that doesn't exist or only exists in <1% of the cars on the road.
Scam....
-mike
Understand that there are several interpretations of "resurfacing" the rotors and not all of them involve turning the rotors. Some use ball hones and are pretty worthless.
Their brake pads are more than likely 30,000 mile quality brake pads.
The kind you buy at the parts store for $18, they probably buy them for $6. And one can assume that they come in a plain white box.
So you think you are getting a good deal for $99?
Let's break this down for say a 99 Lumina.
My customer's prices for same job, better quality parts.
Front Break pads Metallic $19.99
If I like you, I can get them cheaper.
Turning the rotors using a professional on the vehicle lathe. $30.00
If rotors need replaced, $30 each.
Labor to replace front brake pads 1.0 hours.
So my price for the same job would be with in $30 of their "special".
Would I do that same job? No.
I don't do cut rate jobs like that.
There is more to brake jobs than replacing the brake pads and resurfacing the rotors. Inspection of all moveable parts, flushing the brake fluid and bleeding the system of any air should be a standard and you will find that quite a few high quality shops include this in their labor and materials (some may call it incidentals) charges.
I agree though, if you want a $99 job you will get $99 worth of a job. Being in the brake business, I could do it but I wouldn't, our brake jobs cost anywhere from $250 up to $500+ depending on what services are done, what level of pads are used, etc.
-mike
Best Regards,
Shipo
In my area, the humidity pushes 90%+ most the time, so moisture is a problem.
So brake flushing is a needed thing.
