Periodic Maintenance
1st - should i wax/polish car after 5 months of ownership?
2nd - if so, what kind of wax/polish do you recommend for a silver exterior?
I use meguiars yellow wax. some people tell you zaino is the best stuff out there, zymol is pretty good stuff... IMHO, just don't use the cheapo $1.99/bottle no-name stuff on your car.
OVERFILLING THE ENGINE OIL:
Yeah, it can possibly cause damage depending on the engine design. Probably the worst that could happen would be oil pushing past an engine seal. I guess in extreme cases the oil could cavitate(foam up) and that could be real trouble.
Bob
Thanks a bunch, bud.
bob
If you ask engineers to define a schedule which would maximize the life of each component regardless of cost they would have you change every fluid [including the AC PAG oil] every year and oil every 90 days. [65 running hours is the spec for standard oils]
Your solution is somewhere in betwen these two extremes.
To determine WHEN to change coolant you just measure the PH of the coolant that will tell you when the alkaline additives are used up and the the mixture has turned acidic and is eating things from the inside. Simple inexpensive test with test strip.
Same with brake fluid when it changes from clear to amber to brownish it is contaminated and eating seals. When ATF is no longer sparkling red it has been degraded by over heats.....when oil has changed from clear to brown it is contaminated and has started to break down.
Mostly a sample [of each fluid] of new and used [a drop] on a white paper towel will tell you all you need to know.
All depends on whether you want components to last 50k, 100k, 200k, or 300k or 500k.......each is possible depending on maintenance ........you can even destroy them earlier if you try hard......use tap water or inexpensive fluids that barely meet specifications brand new.
I'm shocked at the number of people who have NO idea what the maintenance requirements of their vehicle are - most never unwrap the manual - just gas it and go.
they STILL haven't been read. real men don't need directions, just a bigger hammer
They ranged from 20-42 mile distances and the prices ranged from $510-$640 for this service, with two of the nearest dealerships at $640. The Gulfport,Ms dealership (42 miles) not only had the lowest cost, but accepted my appointment on 1 days notice and completed the work in less than 3hours this morning while I waited.
For this maintenance, it definitely paid to shop around. I had to go 14 miles further than my selling dealership, but it was well worth the drive.
I'm curious how this compares with the cost of this service in other parts of the country for the 98-02 model years.
Other than brake pads shortly, I should be good for another 100K hopefully. This car continues to shine!!!!!!!
Does anyone know where to get a small enough filter wrench? Is the original filter probably screwed on so tight that I won't be able to get it off myself anyway?
The oil shoots out quite far. Didnt realize this till my street was covered with oil.
Oh , if you didnt know, never over tighten the filter!~
Does anyone have an opinion on this?
80 lbs isn't that much - and if you use 40-50 instead, your wheels will fall off. That's a bad thing.
Was watching one of my neighbors using a small torque wrench to torque his Saab lug nuts-Er sez me-what torque setting are you aiming at for those lug nuts-something foot pounds he sez-hmm-how do you convert the foot inches on that torque wrench to foot pounds?-went and got my overpriced snap on. So be careful out there-there be inches, pounds and those evil impact wrenches.
I got one at Wall-Mart for about $2.50. It is a black thing that fits on a socket wrench. They have two types (brands) of the same size, one is a little smaller and works good. The slightly bigger one works on the small fram filter for the 03 Hondas, the smaller on works on the Honda small 03 filter and the Wall-Mart small ST filter for the 03.
Both filter wrenches fits on the end of the oil filter.
then there is the infamous ViseGrip tm 12LC locking plier, with a curved jaw like a baleen whale that opens up and clamps hard on cylinders as large as 3-1/4 inch diameter. that ol' boy would either take your filter off or shred it like cole slaw, so if you ever get that desperate, use it on the filter near the flange of the engine, and be SURE it's clamped on the filter. the flange is a bit more costly and ugly to replace they work great for opening up old Atwater Kent horn speaker diaphraghms
http://www.handaaccessories.com/15400.jpg
I apologize if this was brough up earlier in the forum.
