Visitor Agreement.
Dee Zee Inc. manufactures a custom bed rail protector molded to the shape of the truck’s bed rails and the tailgate, successfully covering the stake pockets and enhancing the appearance of the
truck. The DY-NAM-X side bed caps are an attractive, easily installed bed rail protector that will accommodate the Roll-Top-Cover nicely while alleviating any leakage which may occur at the stake pockets. This also adds to the aesthetics of the Roll-Top-Cover giving the truck a similar appearance as the OEM siderails of the Ford 1997 F-150.
Now I just need to find out if the make one for the Tundra.
Also found the follwing sites:
http://www.linexcorp.com
http://www.rhinolinings.com
I also considered the 3 sheets of plywood solution. Worked well years ago with my '75 Toyota HiLux, in the years before plastic bed liners. whoa, I'm geezzing now, better stop.
Good luck on your new truck.
You probably won't want to read this message after you find out that I am the satisfied owner of a Z-71 Silverado.
However, I have purchased rail covers from the vendor you indicated (DeeZee) made of stainless steel and I am not at all satisfied with the fit on my truck.
Perhaps it is because of the fact that it is a Chevy, but I doubt it.
Look carefully at whatever you intend buy before you install them as they won't come loose after you stick them on.
Jim Carr
Toytundraman,
I have the port installed alloys. Option code
WY3. Toyota calls them "machine-cut" alloys. The sticker price was $679(invoice was $519). I guess you could call them "6-spoke". As for the oil change, I have always heard that it's a good idea to change the oil between 750 to 1000 on a new engine to remove any metal particles or other debris that may have entered the engine during the manufacturing process. This may be a total myth but changing the oil can't hurt. I'll be on the 3000 mile plan from now on. Any thoughts from others on this topic????
Thanks for your input on the Dee-Zee bed caps. When I get the caps, I'll be sure to test fit them and if not happy with the looks, return them. I am curious if the caps you bought were specifically for your truck or the 'universal' fit ones that I see at many of the auto parts stores.
Also, I have nothing against Chevy, Ford, Dodge, or whatever owners. There are good and bad points to all these vehicles and the tough part if figuring which good points are important and which bad points are unimportant. I was happy with my Ford Ranger 4x4 XtraCab but my son outgrew the backseat. I was real close to becoming a Z-71 Silverado owner. Test drove 4 of them. Really nice , well built trucks. Was #1 on my list until I drove the Tundra, then it fell,..Like a Rock.. to #2.
Again, Thanks for your input.
No problem for the comments. But I will have to make a corrrection to my previous post. You asked whether the stake pockets are covered. I told you that the rear pockets are about 1/3 covered. This is incorrect. Shortly after I wrote that I went out to my garage to wax the Tundra and noticed that the rear pockets (closest to the tailgate) are actually not covered at all. The side rails of the cover is very close to one edge of the pocket, but again, the pocket is not covered at all. The front pockets are almost completely covered, probably have 1/2" showing.
I also wanted some type of bed rail cover to cover the rest of the bed rail. I looked at Dee Zee but I did not want to go with the stainless steel diamond plate. What I wanted was plastic similar to what the F150 has on it. I could not find it. But that is no suprise I am having trouble finding most aftermarket items. My new thing is trying to find color keyed (or paintable) street fender flares. I do not like the ones that are factory, they are too big. Makes the factory tires look too small especially with the black flares that come with the TRD package on the SR5. I think aftermarket street flares will be available in the next couple months, so I've been told.
Thanks for the Putco link. They seem to have a better selection of bed rail protectors.
Didn't think of them even though I had a set of their bed rails on my old truck. Expensive is right, I remember those thing set me back about $200.
I read in the Southern California Auto Club monthly magazine a few months ago that to change oil sooner than that recommended by the manufacturer is a waste on money for normal driving. The magazine said if you do a lot of driving on dusty roads, you should change your oil soon than that recommended by the manufacturer.
I think Toyota know what the average driving is when they recommend 7500 miles between oil change.
Guess why the dealers want you to change oil more often than that recommended by the Toyota!
in CA. Finally found a dealer who would deal!
1500.00 over invoice. Now that's a great deal for SO. CA.Options are:ca,ej,ab,la,bl,and cf.Will see if the deal goes through in a few days.If you live in CA. the dealers here will not deal. They want sticker or 2 to 5000.00 over sticker.Wish me luck!
thanks for the help, great site!!!
P.S. No shake in my truck!!!!
Did anybody else hear of this?
Tuck
Run, run, run from that $32,042 price. If you can' do better than that, wait. They'll want to sell it, not display it, and the'll only sell to a fool at that price. Keep searching and you'll be $$$ ahead.
Re: Michelins, the ONLY way to go. Best tire around. I've had alignment or balance problems on almost every vehicle I've purchased. Have it checked prior to accepting the vehicle and if they're out have them brought up to specs before you sign on the dotted line. They only take a few minutes to check and you can be working on the paperwork while they do it. Make sure it's the end of the month (and schedule your purchase on a rainy day). Toyo dealers famous for lack of customer service, per CR, and my experience. You have to dog them to get them to react. Too bad such a reliable vehicle from such low rated dealers, but it's what you have to put up with. Be persistent when problem come up and you'll be a lot happier. Had the same experience at a Jeep/Ford dealer with my Grand Cherokee. Never again a Chrysler product!!! I've checked all the posts on several sites and Toyota seems to take the high mark, if even by a small margin.
Re: oil change frequencies, use 3,000 miles as the benchmark, and do the filter at the same time. Cheapest insurance available. Your engine costs $8K. Isn't a $20 or so oil change worth it to keep it running longer?? Switch to synthetics at 5,000 and enjoy the ride from then on. Synthetics are "heavy duty" and when you consider the higher engine temps nowadays they fight thermal breakdown when the going gets tough. My .02 worth, and thanks to everyone for your help with my decision making.
Also, I wanted to use my stake pockets, but liked the idea of the roll-top . . . am I out of luck, or is there any chance that something could be adjusted so that I have access to the stake pockets? Does anyone else manufacture a roll-top that would allow this?
Thanks for any help! Your previous posts were very helpful.
I feel that the top is very secure. It's kind of hard to describe but the slats are similar to corregated cardboard in construction. The only way I know that someone could break into it would be to take a hammer and a crowbar and bang the devil out of it. You really need to see one to know what I am talking about. As far as the stake pockets are concerned, you have the rear pockets available but you are going to lose the front. The cannister that the top rolls into covers half of it then the plastic top that covers the cannister covers about another 3/4" only leaving about 1/2".
Yes there is another manufacturer. It is called Roll-N-Lock. Some say that they are a little better quality. They are more expensive and when I called them after I bought my Tundra in June they did not have a top for the truck yet and did not know when it would be. The cost of the Pace-Edwards is $600 the Roll-N-Lock is $900. This cover also has and option to have the top retracted by power. You have a dash mounted switch and a key fob, similar to keyless entry. Just press a button and the top retracts. I think that adds another $150.
I would really appreciate any inputs!
My friend says to buy a after market hard cover because of the locking mechanism.
If you have the soft cover and unsnap (or unhook as some others do) just a portion of the cover leaving a portion of the bed covered it will flap in the wind.
If I am only getting computers without montiors, they fit below the rails and I can lock them up securely, thanks to the roll cover and the locking tailgate.
Sometimes I also get mulch in bulk form for my home landscaping, so I do not want a cap, again I hear it is hard to get off by yourself.
That would be appreciated.
www.bushwacker.com
Tim
As far as the oil pressure at idle, I have never paid any attention to mine at idle. But I will this afternoon when I get off work.
I have a pair of 12-71TI Detroit diesels on my boat. The rule is 1 psi for every 100 rpm. Seems like too little to me especially considering the horsepower, but they have been fine for 12 years.
Take it to your dealer for YOUR piece of mind!
Todd~~~
Also, anybody find a bug shield for the Tundra yet?
Leon
Check out the other forum Tundra II about number 886? I beleive that the Lund product fits just fine. I'm not a Tundra owner yet but that's what everyone has come up with at this point.
Truckless still
was hung somewhere in the system and dislodged
during the inspection, who knows???.
They said not to worry about the oil pressure. My neighbors 4 runner has zilch pressure at idle
As for the bug shield, someone earlier in this forum said The Detail Shop has one to fit the Tundra (model# 18083). www.detailshop.com
The fifth wheel question: I did see a Tundra on Interstate 26 here in S.C. a few weeks ago pulling a camper via 5th wheel. Can't tell you if it was struggling or not, but it appeared to be doing quite fine. If my recollection is correct, I think the Tundra brochure I got from the dealer shows an Access Limited pulling a 5th wheel.
However, the Tundra's lack of configurations is disappointing (namely no extended cab long bed option).
I am a real estate investor and use my truck to haul appliances, lumber etc. and need a true full sized truck.
Toyota's intention is not to steal business from GMC/Ford/Chevy full sized, it would appear. Rather, Toyota is trying to grab customers who might ordinarily buy a car or who want to move up in size from a small truck.
Either Car & Driver or Road & Track had an article recently showing that the Tundra is really closer in size to a Dodge Durango than a full sized fleet sided Chevy/GMC/Ford/Dodge. THey also stated that it's bed dimensions are almost identical to the T100. If Toyota wanted to be taken seriously, they had to make this truck larger. I'm sorry, but it's the truth.
Has anyone heard if Toyota will offer a long bed with the extended cab in the future?
With a bed liner installed is there still 48" between the wheel wells to lay a piece of plywood down flat? (The liner cuts into bed width).
How is the comfort level of this truck in the back seat? (extended cab).
Thanks and I have really enjoyed reading comments. A few of the domestic owners should wise up and realize that Toyota is getting very close to doing it right.
I have no idea if Toyota plans to offer an extended bed with the Access Cab in the future. Personally, I wouldn't want one. They look too wierd for my tastes.
I have the Pendaliner over-the-rail bedliner. There is 48.75" between the wheel wells. I have had no trouble hauling plywood or other materials.
The Tundra's backseat is NOT comfortable(I don't care because I use it for "stuff" not adults). If you need a comfortable backseat, buy a Silverado or some type of crew cab truck....IF you can live with the reliabilty problems that plague the domestics.
I am totally happy with my Tundra and would not trade it for any other 1/2 ton on the market. I consider it a "serious" truck. Just my thoughts.
