What I did was clean out the boost sensor. It didn't look bad as I have the EGR disabled, just a little oily. I hosed it down with carb cleaner and it hasn't acted up since.
No performance issues before or after.
If you look in the owner's manual, you will find that 5W-40 is an acceptable alternative to the 0W-40.
The RedLine oil I am using is a "CJ" rated oil designed for the new diesels with the particulate filters. The 0W-40 is a "CF" rated oil. The common thread between these two ratings is that they are both low ash. Redline costs about $9.95/quart plus shipping from the manufacturer. I have another source that costs less and if you purchase $100 or more, and shipping is free.
I read your test results and it sounds promising. Please keep us informed as things move forward.
Additives are helpful, especially cetane improvers because domestic diesel fuel is so rotten.
Saw the post for the speaker question. Searched for a back up copy of my canadian sourced? cd shop manual. Probably gave that and the original away at the same time. Wish now I had sent it to you.
Checking in from time to time to see the results of your tire purchase. I was wrong about my cycle tires used years ago. Believe we went with metzler but avon was a brand chosen by others.
I believe redline 15w40 was in the crd when we traded it in. Can't find anything in the redline file and the huge crd file is long gone. I think that was the first time I talked to Dave but also it has been awhile since dfw flirted with zero degrees.
My CRD came with 225/75/16. Chrysler, Costco, and Tirerack does not show an optional size, however some local tire dealers have stated that a 235/70/16 and even a 245/70/16 tire will also fit without touching or hitting any of the suspension components. I am skeptical about sticking a 245 tire on the CRD but I would probably be content with the 235 tire. Most 225 tires are LT and that would make the ride too stiff.
All thoughts and opinions welcome.
dusty
The optimum tire size for a Liberty is 205 80r 16 but they are hard to find.
If you are not a high speed driver but are in need of a great tire and great value for winter trips check out the FIrestone Winterforce UV 225/75R16. They are available from Tire Rack at a huge saving price. Truely a great snow traction tire!
I followed the thread but did not discover what hobjr's solution was. I read a lot of suggestions but what ended up being the problem? A trucker on the road (that was telling me that I was smoking a lot) told me that it is a clogged fuel filter but I find that unlikely as the problem began suddenly and not gradually.
Thanks in advance
Not a lawyer so I may be way off on this....
From time to time I give the Jeep a good long, fast run which seems to clear its lungs.
I would not discount the fuel filter advice. I think the filter does not gradually slow down the vehicle. It gets to a point when it is full or blocked and then you get what you have described. Hope this helps
1)Make sure vehicle is turned off. 2)Unplug the MAF Sensor (located on the air filter) Do this by pulling out the red tab (located on the plug) to its stop, then pinching the clip on the plug and removing. 3)Restart your vehicle and let idle until temp gauge show that it is at the normal operating temp (needle pointing up). Note a check engine yellow light will come on which is indicating the MAF sensor is unplugged - ignore for now. 4) At this time try to rev the engine several times. If normal operation begins (no surging) try to drive the vehicle on a short trip. If smoke and surging has ended then continue to drive the vehicle for several days at moderate speeds and moderate distances. 5) The MAF sensor should eventually be plugged back in when the engine / vehicle is turned off. If the problem does not reoccur immediately you may be in luck. 6) Service the Oil with recs below. or replace the ERG valve if the above steps didn't work (expensive).
Basically, your choice of engine oil (too thin) has carboned up your ERG valve and probably your MAP (yes MAP is different than MAF) sensor. Having a mechanic clean the MAP sensor is a good idea (he should use carb cleaner spray on the removed sensor). Also you should start using a a heavier weight diesel oil in the crankcase. If you are in a warm climate (all the time like California) use Mobil Delvac 15W40 or Shell Rotella T 15W40 on a 3K schedule with a good filter like a Puralator (Pure One). If is is a temperate climate use heavy weight in Summer and lighter in Winter. Good Winter Oil is Shell Rotella T 5W40 Synthetic or Mobil 1 5W40. Winter change schedule can be 6K if you use synthetic oils.
I also suggest you buy your diesel fuel from a truck stop that has a large amount of truck traffic. You can bet if the truckers are not buying there is something wrong with the fuel. Word get around in the trucking world.
Good luck and find a non-dealorship mechanic that knows the Liberty Diesel Engine (unless you got bucks to burn) .
Also, any suggestions on turbolag? It gets a bit anoying when I floor it and it takes 2 or 3 seconds to respond.
Regards
I have a oil plug out of a 2002 Saturn which has an "O" ring when
makes a perfect seal each time with little torque required. It appears
to be 1/2 inch fine thread. Am thinking of getting a crd plug and having a local machine shop cut a groove in it for a "O" ring.
Anybody have any info on how deep the groove is in relationship to the height of the ring..?
Here is the link the the pics of the plug I took.">
http://photoshare.shaw.ca/view/13452437393-1256940219-70673/0
Last year during the winter I was using jet fuel in the diesle engine and noticed only one difference, that being that when it was at idle the temp guage would be a little warmer (still in normal operating temp) then using regular diesel bought from cenex. I was told this was because of the higher burn temp of jet fuel. I didn't mind it because it meant the diesel engine would share its warmth better.
When using regular Diesel in the winter it would take a long time before the cabin was warm enough to take a jacket off. I've noticed this with all diesel vehicles i've had.
I also noticed slightly better MPG with the jet fuel. I noticed it was a lot cheaper for me to get it as well.
I use to work for a small freight airline and when it came time for one of the planes to get a fuel tank inspection i always got a free fill up.
I was wondering what the long term damage, if any, would be from running jet fuel in the vehicle as opposed to regular diesel.
I know that jet fuel is tested and regulated alot better then diesel, think it may have something to do with its primary customer flying, but not sure.
Anyways, i was just hoping for more opinions then A&P mechanics.
Thank you,
Ian
FYI I am a retired Aircraft Mechanic and also worked for Conoco in my younger days. I would suggest not using it. If your looking to run something lighter use winter diesel and an additive.
We were running Jet A, i'm not sure what the difference is between JP4/JP5, my A&P friends said that Jet A is much cleaner then JP4/JP5, but with out having the stats on both, i do not know what the difference is.
Thank you for the help, and answers.
http://www.amsoil.com/mygarage/vehiclelookup.aspx?url2=2005+JEEP+LIBERTY+5
As I have said in the past, domestic diesel fuel is swill. The Europeans have better quality fuel in terms of cetane and have fewer aromatic compounds in their fuel. Only in CARB land, California, can one get something resembling European diesel. Aromatic compounds contribute to particluate/soot formation as well as low cetane numbers.
I have over 57K miles on my CRD and have only had the EGR replaced one time at 14K miles. With the help of my local dealer and others here on this blog, and especially Caribou, I have not had to replace the EGR. I "blow the nose" at least three times weekly
I followed your recommendations and sure enough it stopped surging and no more smoke. As you said, the engine light has come on. One question, I still hear (when stepping on the throttle) a louder-than-normal air-rushing sound from around the turbo location. I heard that for the first time when it first exhibited the surging. Could there be a blown or slipping-off hose that would do that? What is a CAC hose? (as some one else suggested I look for)
Also, will 15-40 Delo 400 been the cause of my problem? I've been using it for about 20K miles so far and I thought it is a good product?????
Regards
The CAC hose(s) (Charged Air Coler) usually refers to the hoses from the pressureized/output side of the turbo going to the intercooler to the engine intake on turbo charged diesel engines. It may have popped off (doubtful) or inflated from excess heat and oil until it split (thus emits a hiss when pressurized). The intake air side hoses of the turbocharger are not this problem as it has been using clean air thru the air cleaner. These CAC hoses could be checked by any certified mechanic for free with a visual inspection and could be replaced easily.
A split CAC hose reduces the amout of pressurized air from th turbo to the engine thus reducing power. They should be replaced very soon if damaged.
The oil you are using would be ok for California year round driving on a 3K service interval.
Hey make sure you mechanic cleans your MAP sensor when you take it for the CAC hose check.
Aren't Turbo-Diesels Fun???
You may be hearing a little more noise as the turbo may be winding up a little more with the MAF disconnected.
Just bought a Toyota Cami for my wife: it's ultra small, miniature for me, sub compact, has only 87HP and gives 23.5mpg. The Jeep is really not hard on fuel when you compare cherries and pumpkins
It is quite dependent upon weather and road conditions.
Just wanted to let you know that I had the exact same problem with surging and smoking just this past Sunday. I looked at your post and saw that pulling the MAF helped, so I tied it because I knew I shouldn't drive it far in that condition. Then, I also had the sound of rushing air, but with some loss of power. The advice to keep the MAF unplugged for a few weeks just didn't sound right as most of the sensors are designed to work together. So I called my dealer and explained the probem and the first response was a booster hose. Took it in this AM and sure enough, the hose had a 4" gash. They replaced the hose, plugged the MAF back in, and its again running like a top.
I have had very little trouble with my CRD and I think engine wise, other than the above, just a bad glow plug. If you can get service from a dealer that understands the product, problems are almost non-existant. I have several dealers closer to me than where I go for service. The place I go to is in a smaller "farming" area and sells a lot of diesel trucks, so working on diesels is second nature to them. I even go there routine oil changes and such.
At times, I look around a these posts and really can't believe all of the gripes people have. The Liberty CRD was a very limited production vehicle over two model years, which was a well known and advertised (by Chrysler) fact. So one would have to assume--like computer software--version 1 is not going to be perfect.
I'm hitting about 60K now and can't imagine not having my CRD. It was, in 2005, about the cleanest diesel on the road, gets better than advertised mileage, has the pulling power of a much larger vehicle, and real four-wheel drive to boot. An on top of that, it has never not started and run for me, even when having the above problem, I could count on it to run.
