1. The Bluetooth on my phone seems to shut off a few moments after I take the phone out of the car. Can I do anything about that?
2. Should I be seeing a call waiting caller ID when someone is calling me while I'm speaking to another person?
3. How do you switch between calls in a cal waiting situation?
4. How do you edit a voice tag or phonebook entry? I made a phonebook entry and the voicetag didn't work--I need to re-enter it. I didn't see any answer to this question in the manual.
5. Will I regret a switch to Cingular after 10-plus years with Verizon?
Thanks for any help.
Gas mileage both city/highway is 17.5 to 19.5. Not one problem at all with car.
5.1 sound is great on both DVD-Audio & Reg. Cd's.
Installed Verizon Motorola v710, it will not load phone book & you have to manually install numbers. Still can't figure out how to answer call waiting and there's no mention in owners manual. Also can't figure out how to edit or delete voice tags. People will stop you at gas stations and want to check out car. My 8 year old son love's rear entertainment center & has complete control of remote. I thought that if the back seat passenger used the headphones, the driver can change to radio and not have to listen to DVD. can't figure this one out. I'm a car nut and also own 2004 Audi Allroad along with several classic cars (60 Impala convert, 69 firebird convert & 31 Model A). After several years of owing Acura & Lexus models, I can say that the M is the only car I have owned that I am totally satisfied with.
I'm making far too many trips to the gas station and would like to stretch my tank a little further.
I'd love to see twilight blue, please email to aas5NJ@gmail.com.
Thanks - that helps. In looking at the NAV Web site, I was a little worried since it seems the coverage isn't that great. Nice to hear that even in remote areas it has good detail.
Thanks for the numbers - where did you get them? Are they published anywhere?
Does it still show the street level maps for the half that doesn't have the turn by turn guidance? If not, what does it show - just a big solid color with a "you are here" arrow?
thx
spfotey@aol.com
I do have a question, however, as the guy who sold me the V710 and got me up and running didn't have the answer and I haven't found it in the manual (yet). When getting into the car is it necessary to shut off the ringer on the phone so only the car's phone will ring? Or is there a setting that automatically turns the phone's ringer off when using the car's phone system?
Bart
If it continues to improve, I am guessing I will be close to the Mitsu in another 1000 miles or so (and then level off). Given the bigger engine and better performance, this is fine for me. Btw, the Mitsu also took premium--any follow-up about octane requirements for the M35? The insert makes it sound like 87 or better is just fine, but elsewhere it sounds like 92 or better is required.
<<The Bluetooth on my phone seems to shut off a few moments after I take the phone out of the car. Can I do anything about that?>>
No problem with the V3. I ran it 20' from the car, still pretty decent.
<<Should I be seeing a call waiting caller ID when someone is calling me while I'm speaking to another person?>>
Only indicator I get is loud beeping from car speakers. Pretty easy to tell it is call waiting. Nothing on the screen.
<<How do you switch between calls in a cal waiting situation?>>
Don't know, would expect need to find cell phone & quickly pick up there.
<<How do you edit a voice tag or phonebook entry? I made a phonebook entry and the voicetag didn't work--I need to re-enter it. I didn't see any answer to this question in the manual.>>
You can get into settings, phonebook, work on the entry with no tag. Accept all the old info, have a chance to add a voicetag.
A few other observations:
In transferring the phone's phone book (V3 Razr) to the car, reverses 1st & last names, has anyone else noticed that?
Wish there was a bluetooth signal strength indicator.
Has anyone found where the microphone is? Would be nice to know so could direct voices in that direction.
Has anyone found where the bluetooth ant is?
Norm Perron
Has anybody seen a phone battery strength indicator on the screen? It's not that important, but I believe some phone/car combos have it. The signal strength indicator is nice.
Now, good sir (ma'am?), I beseech thee. Can you please post more pictures of your interior??? PLEEEEASE (with all sorts of sugar and candy and stuff on top)???
[edit]
Nevermind. I checked them out on your website. :shades:
The color actually looks more like pumpkin guts than bourbon.
Yes, it shows with my V551.
The noise was indeed coming from a roof crossbar member where it was attached to the car's frame over the rear window on the driver's side of the car. Tustin Infiniti removed the headliner (and most of the back seat), bent a few ends of metal pieces, tighten some things and added thin rubber insulation at the point of the squeak - all per the Japanese engineer's direction. They had a similiar problem with a few G35s.
I haven't driven the car yet (will pick it up on Friday) but the engineers and service manager have and they all say the squeak is gone.
The pictures on my website were from someone else's vehicle and camera. I was hosting them for them. The color looks off in those shots probably due to a poor quality camera. The shot I have above is more color accurate. I'll take some more and post them later.
Mr. My45.
The noise was caused by the contraction of the Exhaust Heat Shield - seems it was attached rather tightly at the factory when cold. Upon heat up it expanded and then during the cool down process (and contraction) it would make the clanging (pinging) sound. The Japanese engineers heard it and although they said it was a normal process they came up with a fix. They will loosen the Exhaust Heat Shield, get it really hot (it will expand), then reattached it. They will also put a small crease in the heat shield to allow for the flexing of the heat shield and hopefully the clanging sound will go away. Won't know how this works until I pick the car up on Friday and give it a try.
Someone earlier mentioned the guage registering "empty" when there's still 2.5 gallons in the tank. My advice, advice I received from a private service shop owner, is to NEVER let the tank register less than 1/4 because there's sediment and water that accumulates in the bottom of the tank and can run into your fuel line when slurping those last few quarts. Bart
Agree .. that passenger seat is a disgrace ... fortunately my wife hasn't complained (yet).
A previous post mentioned that he had a tach reading of 3000 rpm at 80 mph. I have checked a couple of times and have only been able to get 3200 at 80 mph. Has anyone else tried this?
Also a friend who owns a G35 suggested lowering the tire pressure to improve on the comfort of the ride. The manual says that the recommended pressure is 35 psi. I have noticed that the pressure goes from a "cold" 35 to 37 after the car has been driven here in NE. Should I be more concerned with the cold or warm tire pressure?
Lastly, a great audio dvd I just got the other day is the Blue Man Group "Audio" . A track from this dvd is included on the Infiniti demo
The catalytic converter smell is very strong. Hopefully it will go away quickly like other people's car. Have to work on some of the defaults. The 1 touch window button is not set up. Instead it has to be held to go up. I may need to have a a tech reprogram the windows (per Ray Catena Infiniti) but I may not care enough to do it immediately. The lock button on the fob defaults to the horn beeping. Not sure if there is a "beep" rather than the horn but if there is, I would prefer it.
The tire pressure was set at 40 psi by the dealer which is significantly higher than the 33 recommended by Infiniti. I just let out some air and will see how that changes the ride. Having the car report its own pressure is very neat. The computer system is intuitive but there are LOTS of options. I will have to explore it thoroughtly. And of course I have to get a new bluetooth phone to test out the functions.
Lastly not having a key takes some getting used to!
If the windows do not close
automatically
If the power window automatic function
(closing only) does not operate properly,
perform the following procedure to initialize
the power window system.
1. Push the ignition switch to the ON position.
2. Open the window more than halfway
by operating the power window
switch.
3. Pull the power window switch and
hold it to close the window, and then
hold the switch more than 3 seconds
after the window is closed completely.
4. Release the power window switch. Operate
the window by the automatic
function to confirm the initialization is
complete.
5. Perform steps 2 through 4 above for
other windows.
As for the horn when locking, when you use the button on the door handle it beeps. There is an option in one of the settings menu to turn beeps/horn off completely, but then you don't get a horn or beep with either fob or door handle button. I too, wish the fob lock/unlock would use beeps, but it appears there is no way to set it to do that. I pretty much use the door handle unlock/lock anyway though so I don't have to bother taking the fob out of my pocket, so I get beeps.
Mrivision: A matter of mistaken identity. Don't mistake folks who buy a $50K car for those who care about the gas mileage. Yes, I'd not have bought my M-car if it gave me 5 mpg ... been there, done that with my wife's '74 Olds Custom Cruiser. As it is today I really don't care, give or take 5 miles.
The microphone is on the underside of the steering column.
If you'd prefer the car's audio system to ring when receiving a call, there is an on/off setting in phone settings for using car's ring tone.
I don't know if you guys are experiencing delays on incoming and outgoing calls but there is also an on/off setting in phone settings for automatically putting the call on hold before answering it. If this is set to on, the calling party believes the call to be answered and often begins talking before you have really "answered" the call.
Even in MI, the car gets hot (assuming you are in the 15 minutes of sun per day). I have not noticed the seats getting too hot, though.
Whether you get the bourbon or black interior, remember that the headliner is a neutral, light gray.
