Visitor Agreement.
Valves can get stuck and burn on any car, but this is an easily diagnosed problem. I don't see what the head-scratching is about.
The transmission and radiator were replaced under warranty at 58K miles. My concern is the shocks have never been replaced. Would anyone have an opinion what negative impact this might have on the suspension components, as well as any other service issues I should be aware of on a car of this age. I have driven this car and other that very light steering feel, it runs and rides very well
Check around, some honest shops will check your alignment for free, and only charge you if they make any adjustment, even if only 1 or 2 degrees...the honest shops will play it straight, so if your alignment is good it will cost you nothing, which is the BEST preventive maintenace I can imagine...
Your best bet, since you already own the vehicle, is a good set of aftermarket lights installed by a competent shop - the cost will be 1/8-1/10 of what it would cost for factory lights that have little or no resale value...
Late Dec. I had the fuel filter and IAC valve replaced, throttle body cleaned, weather got warm...no problems. End of January gets cold again, the van acts up. Back to the dealer to replace the Mass Air Flow sensor, warmer weather again, no problems.
Now it cold again and it's doing the same thing. The Dealer is scrathing his head since it's not lighting up the check engine light and therefore it's not showing any codes.
Ideas/thoughts/suggestions/HELP!
Let's say its only a 1 hour job...another $75?
$885 for fog lights????!!!???
You can buy the baddest things on the planet, PIAA lights, for under $200 and have them installed for another $75. Or even get APC or GE lights at Wal-Mart for $30-40...the whole job for under $100 - that's what I'm doing on mine, plus they'll be cool, oval, and blue.
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
MODERATOR /ADMINISTRATOR
Review your vehicle
I prefer to use grease myself on most gaskets,--it holds the gasket nicely in place and can't harm anything-- but I do use silicone on water pumps and thermostat gaskets.
Sometimes you get leaks because you overtighten the gasket and squeeze it too much.
Adhesive glues the gasket to the surface,quickly, and usually the gasket isn't removable after the adhesive dries. I wonder if the adhesive would be better to use on the tranny pan?
You may be right, I may have over torqued the pan bolts. I don't think I've seen a torque spec on those. Maybe 1 ftlb or less? thanks
Also you should put a straight edge on the pan sealing surface to make sure it isn't torqued or warped.
How bad is this on a motor (what components could be affected)? Four months/4,000 miles ago, Ford 4.0 V6, 15k miles.
But one quart over I don't think should be a problem.
Thanks in advance.
-ss4
Some good info.
But if you are flushing the system, a lot of water has to run thru, yes?
How can you capture it all in one container?
Or do you just use a bunch of them?
-ss4
Our city has a recycle tank for motor oil but not for antifreeze. The animal folks encourage not letting it get where dogs/cats can drink it. I don't worry, cause the neighbor dog deserves it since they let him out with no lease to wander the neighborhood. But antifreeze is toxic and apparently is sweet-tasting.
Then subsequent drains have less antifreeze so I let it run into the ground and storm drain. I refill twice with hose water; run the car; drain; cool. Then refill.
After the last drain I put in antifreeze and distilled water.
I believe the interior left front wheel bearing has to be changed on my Acura integra 96 .. (I can shift the wheel with my hands and also the road noise charges when I play left right with the stirring.)the tierods and all seem to be all good.
I'm no mechanic... so here are my questions:
-Does it makes sense to change the 4 bearings for the 2 front wheels, or simply the one defective on that wheel?
- Does it make sense to buy the bearings from an Acura dealer, or any after market's will be as good?
-Is this the kind of work any mechanic can do, or I would be better off going to a wheel aliment specialist?
thanks for your help
stef. Montreal.
Any decent independent shop can do this, and there's no real advantage to using Acura parts, unless good aftermarket parts aren't available.
regards
stef.
My mechanic said it sounds like a fuel pressure regulator. Does that sound reasonable? Have other quest owners seen this type of issue. The mechanic said the fuel pressure regulator is a 4.2 hour job, or in other words $386. DANG!!!!
Anyway, I would suspect a sticking cold start valve. So, this is what I'm thinking, the valve is sticking so that you are running too rich while driving (hence the lowered gas mileage) and so that its not closing all the way when its cold (hence the hard starting). This may be a stretch and, like I said, I don't even know if the valve exists on your car, but in case you don't get another answer, I thought I'd throw it out there.
And, if such a valve doesn't exist, then how about the MAF sensor? Basically, either of these parts would act in the way I am describing in terms of making you run to rich while driving and not choking it enough when starting cold.
I guess I would ask the mechanic to please explain what he thinks the fuel pressure regulator would be doing to cause this. I would assume he must suspect it is not delivering enough fuel when starting but then too much while driving? Seems strange to me that this could happen.
Everything you say though does point toward excessive fuel enrichment.
Failure causes hard starts, but not because of overpressuring. It leaks back into the vacumn hose that is connected. This causes overrich mixture.
The fuel injectors should be closed when the car isn't running. But a bad injector could leak a lot of gas into a cylinder, causing hard starting.
Checking the fuel pressure does nothing to find either of these conditions. Oh, wait a minute. Putting a guage on the system and shutting down the car - watch the pressure. It should maintain pressure (what pressure? How long? I don't know). If it falls quickly, this might indicate an injector failed open..
It's the last thing. It controls pressure by providing a restriction on the return side of the fuel rail, downstream from the injectors. Just like virtually every other fuel pressure regulator on FI engines.
Replacement would be 1 hour or less, very simple.
.4 hours
It does.
Fuel Pressure Test
With the ignition switch ON and the fuel pump running, the fuel pressure indicated by the fuel pressure gauge should be 333-376 kPa (48-55 psi). This pressure is controlled by the amount of pressure the spring inside the fuel pressure regulator can provide.
A fuel system that drops more than 5 psi in 10 minutes has a leak in one or more of the following areas:
The fuel pump check valve.
The fuel pump flex pipe.
The valve or valve seat within the fuel pressure regulator.
The fuel injector(s).
Fuel Injector Balance Test
The Fuel Injector Balance Test compares the performance of each of the cylinder by using the PCM to shut off fuel injection. The J 39021 Fuel Injector Tester is being used to energize the fuel injector for a precise time period. This measures the performance of each cylinder by the amount of RPM drop caused by that cylinder not producing a power stroke. If proper fuel delivery has been determined, then a cylinder that does not show good performance (RPM drop) indicates either an ignition or mechanical problem.
Diagnostic Aids
Any fuel injector that drops significantly (more than 10 kPa) requires service
The engine coolant temperature affects the ability of the fuel injector tester to detect a faulty fuel injector. If the engine coolant temperature is NOT between 10°C and 35°C (50°F and 95°F), go to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Outside 10-35 Degrees C (50-95 Degrees F)
No, and no. Fuel delivery is controlled by the powertrain control module, which pulses the injectors. Fuel enrichment for cold starts is provided by input from the engine coolant temperature sensor to the PCM.
Some very good ideas.
I just want to double-check:
Does anyone else know if sewer-treatment plants can handle antifreeze without any problems?
I don't want to pollute.
I remember years ago, anti-freeze was recommended for adding to toilet bowls that were in unheated areas in winter. Don't know if that has changed with more eco-consciousness.
Thanks in advance.
-ss4
