Visitor Agreement.
Current shop says that there are three things wrong: the battery, the distributor, and the coil. Is this possible considering that the car has managed to start after not starting in the past?
Any advice or thoughts? Thank you.
If the miles are very high, it could also be a low compression issue.
Still, from my highly limited understanding, I am not seeing how the distributor and/or coil can factor into this. Is that correct?
You can have a battery "load-tested" to see how well it recovers from stress.
I need your help with something I experienced. My car battery died and I called in a technician to jumpstart it. He tried to connect the incorrect polarity (reverse jumpstart) but then corrected it. This blew off the max fuse which I replaced but now the CD\MP3 player is no longer working. Isn't the max fuse supposed to protect everything?
Is it also true that I should expect more electrical problems in the future?
Thanks Rahul
CAR DETAILS
Year/Make/Model: 2000 TOYOTA CAMRY CE
PLEASE clear my lense on this ...
Eggie
there is a loud knocking noise coming from the throttle body until the engine warms up. It quiets down after about 10 minutes.
Could this be the injectors or the pressure regulator.
using a stethoscope the noise is all over the top of the throttle body.
http://www.troublecodes.net/GM/
i was driving down the road one day and my ac stop working and so did my heat i took it to a local shop witch had it apart and they could not find out what it was but some how it started working again but a little down the road it stop working and hasnt work since any body have any idea's
Also, whatever that fill thing is, what level should it be up to? Nothing in our owners manual about this fill cap.
-High Beam fuses both good (Visibly good and checked with multimeter.)
-Relay good in fuse block (constant power to proper terminal. Also swapped with
known good relay of same type.)
-Both bulbs good (Visibly good and checked with multimeter. Also replaced with
known good bulbs)
-Multiswitch on steering column good (Checked with multimeter - power to
Orange/White wire when switched to brights. Also replaced with known good
switch.)
-High Beam light in light cluster doesn't come on and brights don't work.
I am at a loss for what to check next. Any help would be GREATLY appreciated.
It's all hard to say why these things happen, but by all means have the engine's oil pressure checked with a numerical read-out before you repair anything and also have the engine carefully examined for sludge.
My point is you don't want to end up just repairing the symptoms and not the disease.
injectors & their wire harness.
Engine cranks. But No power detected coming from OBD to injectors.
Dealer suggested it was the power control module instead of the OBD and
gave us a drawing showing the PCM on the pass. side of the engine inside
the van. The Haynes book is of no help either.
BUT, we can't identify it! Any help?
:confuse: Or other suggestions as to problem.
I may have the same thing in my Astro.... feels like going over rumble strips almost.
:confuse:
