Visitor Agreement.
But I must say the noise on mine was not that significant so your situation may be different
Just my opinion
Hope someone more mechanical answers also
PGP
Make sure you buy genuine MAZDA filter if this is the type car you have.If so I do not think you need to do anything .
If its not broke dont fix it
PGP
P.S. My car runs excellent like that!
92 Geo Prizm, the starter has been replaced I think 3-4 times now & still seem to have the same problem. If I drive around in town for a length of time & it's hot outside the car simply refuses to start occasionally. However it proved to me that it doesn't matter if it's hot or 90 below, it didn't want to start this morning either. I've ordered yet another starter, this time from Napa. It seems to go along just fine for ohhh about 5-6 months & it begins to not start again. I have noticed that when it starts this trouble, the positive side of the battery gets corroded real bad & I usually have to replace the battery as well. I'm quite stumped at this point as to why it keeps repeating this cycle. Could it be the voltage regulator is going out & it's causing the battery to overcharge?... but what about this no start problem? I can't figure this out. Please help!!! :confuse:
Rene'
If you feel confident in their customer service dept. repairing everthing that was caused by their negligenc I would say you are in a good position. Get something in writing to that effect.
Low compression in one cylinder could be an indication of broken rings, and I am quite sure you will here from someone more knowledgeable in here than me. Trying to predict what will happen is hard. How long did she drive without oil, how fast, etc and they might say didnt you notice the idiot light or something before they contacted you?
If they seem 100% fair I would leave it in their hands. If not contact an attorney.
Good luck and always watch out for leaks after any oil/filter change.
PGP
PGP
The last few weeks I've been noticing a whining sound when the car idles. When I turn on the A/C, the sound goes away.
Under the hood, it "seems" like the sound is coming from the new alternator. Does this sound plausible? My only other thought was the serpentine belt was loose, but that doesn't seem to be it.
So far, voltage is holding steady. (I keep an eye on it because when the original alternator went out I had to push the 'Stang 4 blocks home in the Texas sun.)
Is there a bearing or something in the alternator that could be going bad?
I know having contaminated air can do a lot of damage. The car is in Greece and MAzda there tried to cut a filter to fit, because they donthave the parts for this model there.Its possible its been the cause of 3 years of CEL problems, but after changing MAF and putting in an OEM filter from USA in the car, CEL light went away and the SAGA is over for me I hope. Most of the problem was prolly caused by this " SHOEMAKER' job, including that MAF finally giving out.
If you do a search you will see numerous posts by me over the years and all were resolved by MAF/OEM filter properly fitted combo.
I suggest you find someone with the identical car and ask them to let you see their filter box.
Good Luck
Peter
P.S. 06 nissan arent you still under warranty?
I'd imagine rebuilt alternators from Pep Boys are very cheesy items so I wouldn't be surprised if the alternator was rebuilt incorrectly...next time try a better rebuilding source.
Size doesn't matter.
CAREFULLY put one end of the dowel on a questionable rotating part. Put your thumb on the other end. Stick the end of your thumb into your ear. Move from front to back to decide if it's the front or rear bearing on an alternator.
Dealer says they found foamy transmission fluid which could be from wrong kind of fluid, too much or too little fluid.
I was told by my dealer that I needed a new transmission mount a few weeks ago (could feel a harsh downshift), the harsh downshift miraculosly went away 2 days before this latest problem happened.
Any thoughts as to wether I should believe them or not??
:confuse:
Joe
Well, I went back to Pep Boys and let one of the mechanics listen to it run. It took him all of 5 seconds to pronounce the impending death of my alternator. I hastened home with crossed fingers, took off the rebuilt alternator and went back with it. The Boys cheerfully gave me another, I went back home and put it on, and WA-LA no more noise. Also the voltage is higher on the dash gauge.
Thanks to everyone's help!
The noise is driving my crazy!
Any ideas about my problem? :confuse:
The four dimensial cube?
Or the Band?
Or the Corporate HR Software?
I worked with the software for several years.
Oh, the car. If your exhaust 'sound' has changed significantly, and all of a sudden, it's probably a problem with the muffler or cat converter. Let a muffler shop check it out.
Are these coils very expensive to swap out (parts + labor) and can I use my own ASE mechanic for the eventual repair?
As always guys, thanks for the help.
The Sandman :confuse:
Rob :sick:
If you are getting water into your oil, correcting this might cure the lifter. But, water in oil is very, very bad. A lifter might be actually rusted up and sticking. If you get the mainfold fixed, I would change the oil again, immediately, to get the water out.
Overall, if I had a car that was actually getting water into the oil, I would strongly consider dumping it. You are worried about the car 'lasting'. It may be too late for this, water in oil could already have done damage in various parts of the motor.
The intake manifold leaking problem is another known deficiency. The gaskets should be replaced with the improved versions.
What can I do here? If they won't replace and it fails after my warranty expires, how much $ for the part & labor to fix this problem?
TIA all!
I'm wondering if there might be a relay somewhere sticking on, or if the only solution is replace the ignition switch?
(I also posted this in Subarau Crew, but after further looking around that didn't seem to be the right spot. Sorry if I have violated any rules.)
Thanks for all replies.
Ed
Any assistance will be greatly appreciated.
