Usually a warped head would show two adjacent cylinders dropping somewhat in compression.
I am rather surprised you didn't replace the water pump. I suppose it's worth a look now, although if it isn't leaking that would have to mean the impeller is broken or severely corroded---a very unusual circumstance.
As previousl suggested by others, I'd be looking for a crack in the head or cylinder wall, or warped head.....since you've already tried replacing the head gasket.
Water pump bad would show symptoms of leaking, or no coolant flow. It wouldn't account for the continual air in the system.
Heater core bad, would show up as leaking in the passenger compartment. It could also account for a little bit of air in the system, as the engine cooled down, instead of drawing in refill water from the reservoir, it would draw air thru the leaking heater core. That's a little bit of air, not a continual supply of air.
thanks,
bieks
thanks.
P0302 = cyl 2 misfire
P1494 = Leak det pump failure or mechanical fault (part of evap control system). This most likely isn't causing your problem.
thanks.
for the last 6 months i did change parts left right and center ..had no problem doing it or problem finding the part ...now this time it is different .
let me explain ..i was driving at 100 kmh then i did ear a very bad noise and did see dust and feel like the front drive shaft did hit the passenger side floor ...
turn out the tire did peel ( tire was still inflate)..
because my pick up have no inner wheel well made of metal .the rubber did destroyed lots of stuff.so the part name i need to know is against the firewall passenger side and have the blower motor attache to it .this part is all black plastic 2 feets wide not sure how tall .i did look a bunch of place to find the name but no success help please ..also where can i find this part?..peace claude
Go to a salvage. They have books. And picture. And dead trucks where you can point to the part.
thanks in advance ...claude
Could even bring it to a Ford dealer. They have books and online diagrams for everything.
First, you know there's no fuel pressure, but do you know why? Look up your computer pinout diagram online and find out which pinout is the fuel pump enable. Put a voltmeter on it and test it, and if you're not getting the specified voltage (usually +/- 5 volts), then the computer is not sending the message to the fuel pump.
If this is the case, you have a few probable causes. You could still have trouble with the anti-theft device, or even more likely, your computer could be KAPUT. I imagine this is your problem, based on what you wrote. Get a cheap used one from a junkyard (50 bucks) and see if that solves your problem.
In the end, the bad computer could even have been what was overheating your engine by getting the ignition timing all wrong. I have seen this happen.
Good Luck.
My truck was driving as smooth as glass, for about two weeks. A car pushed me into curb, on a corner (left outside rear). Now when driving down the highway I get white knuckles from the Canadian Tire Chainsaw like vibration from the steering wheel. I drove 1000 Km yesterday. It was fine. Today, it vibrated for about 200 Km. And then I pulled off the highway, did a steady 95 Km/hr.(on a smaller highway), no vibration..????
--I'm going to re-torque my wheels right now. I hope it's not tires. I replaced the front bearings 3 months ago. In hopes of getting rid of a horrible groan/howl. No luck with that one. The groan thing seems to come from the tranny. Between 95-99Km/hr. Other than that everything is pretty quiet.
Also my right rear brake locks on. I take the tires off. loosen the brake, a week or two later, I get home, my right rims are glowing read, you can feel the heat, and the great smell as soon as you open the door.
I changed drums and pads two weeks ago. Just noticed tonight that the brake was stuck on again. ---I thought it needed a little more pedal on the highway tonight.
The 91' Olds runs like a top. The $2800.00 optional factory paint job is immaculate with 400 000km on it. The worst conditions, snow, salt, gravel etc....
In hot weather it does the drop your transmission on the street-shifts. Change the 3 pack distributor and the computer underneath and your ok for 500 km, at a cost of around $600.00 At 140 km/hr (In the USA) the car gets 45 miles to the gallon (Canadian).
--The 2 million lights/computers/controls in the car burnt out 3 years ago. That includes the entire dash/climate/jumbo jet steering wheel controls, everything inside the car. Still lays rubber..
All three cars get hot in stop and go traffic at temperatures above 20 Degrees Celsius and do that thump/slam shift thing. And it is the head gaskets leaking and damaged coil pack.
The right fan on the rads doesn't come on, causing the coil pack to get hot and slowly melt. In the cold the cars run fine. I checked my fans, they all work but the right fans never come on when the engine is hot, only the left....
After I put the new drive shaft on, the back end of my truck it was jumping across the road at 101km and over. I re-torqued my rear wheels, I got 1/4 turn out three nuts on the right side. This fixed the jumping thing. It was pretty bad, at 130 km the wheels felt like they were leaving the pavement with a good couple inches under them.
I pulled off my right rear wheels, the drum actually just slipped off. (I didn't have to beat on it for an hour with a sledge hammer). My bran new Ray-Bestess brake pads...a little smooth areas here and there, mostly very rough with metal hairs hanging off, with deep crevices. They appear to be junk, and burn to a crisp.
The drums appears ok.
The old pads were smooth, but the forward shoe was worn uneven. It was tapered from the top down about 1/4 of the way.
When my rims are glowing red, I have to beat the drum off with a sledge hammer.
My rims were glowing red this time, but the drum slipped off by hand...?
The old pads were original. I went to replace them 8 years ago, but they were 3 times thicker than the new ones.
The new pads were $269, I took them back. The truck has 300 000 km on it. Every time a mechanic touched my truck. My rear wheels were glowing red (I have to have it certified/inspected every year).
This might have also caused the off/on vibration?
When I got to work I crawled under the back end. Left rims and plate -ice cold, drum maybe 17 degrees Celsius. The right side, not glowing red but I singed my finger tips on the rims.
The way home, my truck drove as smooth as silk. Just like a new truck. The brakes seem to be pulsing but that's to be expected considering the right (brand new) pads are burnt to a crisp and have gouges in them. I imagine the brand new drum is garbage too.
-The night before, on the way home. The drive was insane. I got white knuckles at 60 km/hr. @90km/hr my entire truck (front to the back) was doing the cheap chainsaw vibration thing. My camper mirrors were almost braking off the doors. I was going to pull off the high way but I don't have a $1000 for a tow truck. I decided to go pedal to the metal. At 125 km/hr the vibration that was beating the living c--p out of me and my truck was gone. Pulled on to another highway and my truck was as smooth as silk again, at all speeds.
--My brother has a 2002 Duramax 4X4 dually. Every time the mechanics certify it, an hour down the highway you hear a faint groan from the rear. The back end of the truck starts walking side to side (smoothly). Very weird feeling. Pull over, check the wheels and the lug nuts are falling off one side.
My truck, if you get 1/4 turn on three lug nuts on one side, you might as well strap yourself to a couple of Bosch Brutes for the ride..!!
The right drum was black, brown, blue.
The sound usually occurs when I first drive the car in the day. It only happens one or twice. And it can happen either while driving or while idling at a stop.
I checked my trunk and there is nothing loose. I thought it might be the rear shocks or brakes, but I had these checked out earlier this year.
My car is is a 1996 Oldsmobile 88 LS
3.8L V-6 engine.
Automatic transmission
46K mileage
The only random thing I can think of is if you have the load-leveling rear struts. The system uses a pump that's mounted under the right rear of the car inside the stub frame at the rear. That pump might be making a noise trying to start or the change in air pressure it gives to the struts may be causing a shift and a noise.
Another might be the links at the ends of the stabilizer (sway) bars or the sway bars where they are held in rubber mounts under straps. The links on the end have a rubber pad that wears and hardens. The internal part is a metal bolt that rusts away. It's inside a hard plastic sleeve. Some people with cars our age (I have a 98) have had trouble with the links. If they break on one end, when the car wheels go up or down just right the remaining pieces hit or shift and make a noise.
Also it could be a ball joint that's low on grease or is worn giving a noise as it binds and then lets go.
It could be the muffler and exhaust system expanding.
And the knock usually happens after I have parked the car for a while. It happens within a few minutes after starting, and then I don't hear anything more.
In terms of the load-leveling rear strut pump or sway bar problems that you mentioned, are these issues pretty serious in terms of repair cost and possible damage?
And would the muffler or exhaust system expanding be a problem?
The front sway bars and the links that hold the ends to the A-arms for the wheels can be inspected visually for flaws by a mechanic who knows what to check.
But I just decided I might have another source: the gas tank. Does your car have the original gas cap? Or has it been replaced with what might be a wrong cap? The gas tank might be pressurizing from the fuel in it or it might be running a leak check where, I believe, it pulls a vacuum and sees how long it lasts. If it leaks air in too fast, then it fails the pollution check and the check engine light comes on steady which means pollution devices didn't test right.
Pressurizing or vacuuming might cause the tank metal to move in or out giving a dull thud sound. The tank is under the rear seat cushion, so sounds would be like they were from the trunk.
Do you run always low on fuel? Or always full? You might start thinking about how much fuel is there when it does it. Some cars have a sloshing problem. E.g., when stopping, you'll hear the fuel hit the end of the tank as it sloshes a short time after a stop. The fuel is supposed to be baffled in the tank with things placed to stop the sloshes from moving as a single wave front. Sometimes baffles come loose, or the baffles just weren't designed right. These symptoms might not occur with a different level of fuel in the tank.
Without checking again for your car year, the vacuum check for pollution leaks occurs on my 98 when the tank is between 3/4 and 1/4 full. It only is run when the engine is started and the coolant is between two temperatures, for example only, between 100 and 170 deg. You might notice if the sound occurs only under those circumstances. The check does not take long, less than a minute. I know because I've had a gas cap turn on the check engine light and when the car ran the check the light was off before I was down the street very far from the quick market.
Your idea about the gas tank being the cause of the knock sounds interesting though. I've heard the sloshing gas sound from the tank that you mentioned, sometimes when I back out of a parking space. I usually run the car on a 1/4 tank of fuel. I'll put in more gas and see if I still have the knocking sound problem.
As I understand it, you're saying that the problem could be caused by the gas tank pressurizing fuel or the baffles in the tank being loose?
I haven't noticed the check engine light turning on or the "vacuum check for pollution" running when the knocking sound occurs, but I'll look for it again.
If the problem is the gas tank, how serious of a problem is this in terms of repair costs? Or is this a problem I can just ignore?
When the pressurization or vacuum test is run, the light doesn't turn on. Only if there's a problem does the light turn on.
I would just keep driving the car rather than replace a tank due to a noise.
It doesn't cost any more to run the car with a full tank & when my gauge gets to 1/4, I fill it up.
I would suggest that you lower them a bit.
It costs fuel to carry fuel.
A full 20 gallon gasoline tank weighs 120 pounds.
You wouldn't ride around all the time with 120 pounds of bricks in your trunk.
How much more? You're averaging 20mpg on a full tank and 19 mpg on a quarter tank. Seems it would hurt you in a lot of stop and go driving, not so much if most of travelis on interstate.
According to the government web site fueleconomy.gov,
fueleconomy.gov
5.8% of the energy content from a gallon of gasoline goes to overcoming inertia losses (vehicle weight). If a vehicle weighs 3600 lbs, then the difference between a full tank of gas (20 gallons) and and half tank of gas is 60 lbs. As a percentage of the example vehicle weight, that 60 lb difference is 1.67%.
So the effect on gas mileage between a 20 gallon loaded tank and a 10 gallon fuel load would be 1.67% x 5.8% = 0.1%.
Tell us, do you think a 0.1% difference in fuel economy is noticeable amongst all the other noise?
