I own a 1998 Saturn SL2 and I was working on the car and found something odd vibrating. I'm not a car guy so I don't know the technical term, but I just know it doesn't look right. I took a video of my situation.
link title It isn't obvious in the video, but the second from the left is vibrating while the others are keeping still.
Also this is the second time in between oil changes that I had to top the oil off. And my milage has been much lower than I am used to (21-23 combined mpg, maybe 25 if 175mi of 200 are hiway)
So is this bad that my car is on its last legs or am I expecting a large repair cost?
Specs:
Year/Make/Model: 1998 Saturn SL2
Type & Size of Engine: 1.9L 124 hp I4
Transmission Type: (Auto)
Mileage: 80k
So I would pull the boot off and check that the plug is not loose, and that the boot is on tight.
You have it right that I'm talking about the four rubber boots/wires as you have worded it (I'm more of a computer guy than car guy) The second from the left vibrates like crazy. I'll go ahead and check it out.
If only one is moving, then yes, as stickguy said, check that the plug wire is firmly on the plug. The plug might even loose.
At this milage, and especially at this age, 14 years, all you need might be a set of new plugs and new wires. Especially new wires. 4 plugs at what, $5 each, and a set of wires for $30 (?) for a total of $50 would not be throwing a lot of parts at an unknown problem. And if the motor has never had the plugs and wires changed, it surely could not hurt.
A spark plug socket and a cheap 3/8 inch rachet set should enable you to change these plugs. They look very easy, sitting on top of the motor, very accessible. For $75 or so you can get what a shop will call a 'tune-up' (plugs and wires) and would probably charge $225....
For code 41 I replaced the Throttle Position Sensor, for code 71 the EGR valve has been cleaned and the EGR gas temp. Sensor replaced. After replacing these parts and clearing the codes they come back within 20 miles of driving.
I’m unconfused and out of ideas. Please help.
any help would be great.
Signals from the Throttle Position Sensor(s) are also input to the TRAC Electronic Control Unit, So when a malfunction occurs on the TRAC side, code 41 or 47 may be displayed."
As for the EGR code, it could be more than just the EGR being clogged up:
"TROUBLE AREA for code 71
Open in Exhaust Gas Recirculation Gas Temperature Sensor circuit.
Short in Vacuum Switching Valve circuit for Exhaust Gas Recirculation.
Exhaust Gas Recirculation hose disconnected, valve stuck.
Clogged Exhaust Gas Recirculation gas passage.
If you are considering an alignment, you should be sure that your tires aren't ready for replacement---if you have very worn tires the truck will be difficult to align properly. I'd say if you need front tires, you should do that, too.
As for the ball joint on the other side, that can be tested for movement.
Generally though, their thinking wasn't bad---when a car struggles uphill, it often does relate to clogged filters, weak fuel pump or a bad catalytic converter, so they were in the right general area. My guess is that they took a good guess--with your checkbook.
Conditions like this can be hard to diagnose because it's not easy to simulate them in the shop.
I'd certainly suggest a fuel pressure test and a test of the catalytic converter.
Thank you! I will have those items you mentioned checked. I will also update you to let you know the outcome.
Have a great day!
I have a 79 olds regency 98. The switch for the fan on the dash works on all the lower settings but does nothing on the high setting. How do I figure out where the problem is/fix it? Thanks.
The lower speeds run through one circuit and switch between the varied resistor groupings in the resistor pack that is sitting in the air stream of the blower fan inside the heater housing.
There is a relay that switches from one pole to another when you switch to HIGH speed. The circuit bypasses the resistor unit. The new circuit has a large fuse, in a relay center on mine, that is 30 amp. This allows a higher speed and current draw for the blower motor.
So you have two things to check. The first would be the larger fuse, probably a 30 amp. It may have blown from age OR from a blower motor that is deteriorating and drawing more amperage and the fan teased the fuse to its deather. The second is the relay that switches from one contact to another. On my 93, one of those relays similar burned the contacts and didn't work any longer. If you can figure out the wiring you might be able to pull that relay and check to see if it can be trigger to switch contacts with the low power solenoid terminals and then does it give a continous circuit through the other two contacts. I removed the cover from my relay to visually check it. That might be possible if you are able to do that. Otherwise, you might use a fused jumper to see if directly connecting the power lead for the high speed blower circuit bypassing the relay itself allows the motor to work at full speed.
For many of the relays in my vehicle, there are several similar numbered relays for the one pole relays, and another relay, such as horn, could be substituted to verify one was bad. But there are no duplicates for the switching relay that uses one circuit and then switches to another circuit.
-Weak fuel pump. It has to 'prime' up everything for the first start, and this might take more time.
-Bad 'power valve' in the carb. This is a little diaphram pump valve that gives the carb a 'shot' of gas directly into the carb throat when you depress the footfeed. When the car is running at speed, if it will not accelerate quickly when you push on the footfeed, this most probably is the problem. A carb overhaul kit always comes wiht a new 'power valve'.
Are you sure the choke is closing completely to block off most air flow? I suspect that it is, but you might take the air cleaner off and observe the choke when it's cold while someone else cranks the engine to be sure the spring closing the choke isn't weakened and the air flow at crank speed is pulling it open slight??? I may be overthinking the history of these, but age on the choke springs in a few cars mandated replacing the choke.
You don't say where you are so I don't know if "cold" is 30 deg or 55 degrees. BUT my #1 guess on this is leaking of gasoline through the plugs in the bottom of the carburetor. If I recall correctly, the plugs are put in to seal passages that had to be drilled inside the carb but went through the outside. These seep slightly as the carb cools and the gas level in the bowl leaks. I don't recall if it leaks onto the manifold or internally inside the manifold. So it takes little time for the fuel pump to refill the carb float chamber to a level where the jets and suck fuel instead of just air.
You might do some internet searching for this--QuadraJet is the carburetor. The 4-barrel version had this. I don't know if the two-barrel version had it as well. I seem to recall talk of epoxy to try to seal the plugs better from the outside?
A test to do, would be to take off the cover on the carb (only if you have done before and can do it right and check the level of fuel after engine has sat. There is a depth dimension from the top of the edge of the float chamber in books.
OR you can see if you can have air cleaner off, open the choke butterfly, and pump the accelerator rod and get gasoline through the accelerator pump. And see how many pumps of gas it gives. Then compare with what the quantity of gas is after car has sat just for a couple hours and cooled down during daytime driving.
>either holding the pedal to the floor or pumping the pedal
I believe the correct starting procedure is to just push down on pedal one time before cranking to allow the choke butterfly to close with its spring pressure. Then keep your foot off the accelerator pedal while cranking.
Holding the pedal to the floor actually moves a cam that opens the butterfly choke valve, eliminating choking for when the engine has been flooded. So don't hold the pedal to the floor during normal cranking.
I had a Quadrajet Olds 350 in 1977 but traded it for a 1980 with the two hole version for better fuel mileage. I didn't have trouble with mine, but it may now have aged enough to start seeping where it lengthened crank time.
However, if say your float is defective, you might be dribbling gas into the engine overnight, thereby creating a flooding condition even before you start the car--and this you are "curing" by flooring the gas pedal.
So if I were you, I'd try two experiments and then report back:
Day One -- get in, pump the gas once, crank it without doing much of anything to the gas---what happens?
Day Two -- get in, floor the gas pedal and keep it there, crank it---what happens? Better or worse than Day One?
Day Three -- get in, don't do anything, just crank it---what happens?
Also, I doubt the brake light switch (down at the pedal) has separate dual terminals for left and right, but if it has more than 2 wires coming off it, then ensure it is not the culprit. Wiggling while someone watches would help rule it out, but if salt off your feet in that type of climate, and position of switch allows that corrosion, then it could get into switch and wiggling will not work. Again though, I doubt it has a dual circuit to the rear. Also rule out a potential trailer towing controller, or wire harness if that exists on your vehicle.
If vehicle has been in accident of a nature that would involve wire harness repair or replacement, then that too could be suspect. I assume you did not replace the entire harness from front to back.
Replacing any harness or part that ends up with a full-time failure vs intermittent before, is your best clue as to where to look.
I have a 1986 Mazda B2000 pickup. It's been very hardworking for many years, with a few issues along the way. It used to get hot in the summer so one year I took out the thermostat. Never got hot after that. I drove it that way fine for about five or six years.
I took the truck in for smog the other day and they put a thermostat back in to get it to temp. It has passed smog twice before with no thermostat with other smog people but these people said they couldn't do it without a thermostat.
After fiddling with the truck for hours and $228 dollars later they finally got it to compliance. The next day or maybe the day after that it was hot weather out. As I was driving up a long grade here I started to smell burning oil. At first I thought it was someone else. When I got to a place in town and stopped I now noticed that smoke was billowing out from under the hood.
After letting it cool I took off the radiator cap and saw that there was no water. When I filled it I noticed that it was now dripping rapidly out from a hose underneath the carburetor (in a very inconvenient location I might add). I had to pick up my daughter from school so I filled it back up (I also took a five gallon bucket of water) and with a little difficulty got it started and went and got her. It is another 17 miles from there to home. My plan was to watch the gauge and when it started getting too hot to turn it off and let it cool down. I just wanted to get us home.
About halfway home when the temps began to rise abnormally I turned it off. Problem was that when it cooled down it wouldn't start up this time. Still won't. It cranks, the timing belt is good, there is a spark to all the plugs, the tank is full of gas but there is no turnover. I tried putting a little gas in the carburetor but still no ignition.
I'm wondering if it might be a clogged fuel filter or maybe the pump went bad from the heat. I asked someone else who told me that I might have blown the rings and lost compression.
I had to get another vehicle but I want to see if I can get the truck going again. Why? I live in California where you can collect some money to retire old vehicles. The catch is that you have to be able to drive the car to the dismantler. It's frustrating knowing that if I had not gone to these smog people I could have recycled this truck without a problem.
Anyway, I am wondering if anyone has any other ideas as to what may be causing the truck not to start? It cranks, and almost seems like it wants to start but doesn't.
Your earlier posts are just on the preceding page of this thread.
fourwheeler.com article
- air leak between air flow sensor and throttle body (I do not know if your Regal is MAF, speed density, or MAP)
- vacuum leak
- fuel filter
- idle air control solenoid
- fuel pump
- air flow sensor
if that's too much for you to mess with, take it to a trusted mechanic.
The mass airflow sensor was replaced about 5 years ago by dealership... they could have cleaned it, but charged me something around $400 for a new(remanufactured) one. Small garage shop owner charged me $75 to fix that and turn signal. Car runs great.
Dealership by the way wanted $85 to put in a new socket for that turn signal, it was slightly melted. The local shop owner pulled out the prongs, to make contact with bulb, that fixed the problem. Wonder why the dealership didnt think of that? $
