On modern automatics (or any transmission), isn't "overdrive" simply a transmission gear that's a tall enough ratio (1.00:1 or less), which makes the engine turn at a lower rpm than the axle?
Maybe it's the lockup in the torque converter you're thinking of, that needs a sensor or solenoid to activate?
In '89 I bought a Ford Probe with the Mazda 5-speed manual in which both 4th and 5th gears were overdrive: .914 ratio in 4th gear and .717 in 5th gear. You could tell that 3rd gear was exactly 1:1 ratio because the tach and speedo needles would turn perfectly in sync. I think the old Porsche 914 also had a 5-speed with overdrive in 4th and 5th gears - although nothing else too "modern" was built into that car.
Wonder who made the last passenger car line offering a "splitter" or external overdrive from the factory/dealer?
I remember driving with a neighbor in his 74 Volvo. It had an overdrive button on the shifter. I'm not sure if that is the sort of thing you mean.
Actually Volvo used that overdrive into the '80s. I think most cars had gone to 5-speeds with an integral overdrive ratio or two by then.
Good memory. Yes, I am sure that was an external (splitter) overdrive. Chevy put the same sort of setup in the Corvette in the '80s. As a point of interest (?), Rambler had a similar setup in the mid 60s.
Indeed it was. But it was an external overdrive as opposed to an overdrive ratio in the transmission itself. Oddly enough, at least in the '72 that I had, the overdrive only operated on top gear of the 4-speed main transmission, so it functioned just like an overdrive 5th gear would.
The Corvette 4+3 was definitely the old school, domestic, RWD layout I had in mind. Hard to polish the "America's Sports Car" title back then when a 5-speed was available in so many other bow tie vehicles - but not the Corvette.
Now you have me curious about the imports from that era, especially the Volvo overdrive on your '72. Since the overdrive only engaged in 4th gear, maybe it wasn't rated to handle the stress in lower gears. It turned out that the overdrive component of the Doug Nash 4+3 trans was not nearly as strong as the Super T10 4-speed it was adapted to.
I had never thought of it, but you could be right. My Volvo was a 164E, the six cylinder model. I now wonder if they used the same overdrive unit that they put in the four cylinder, and it couldn't handle the torque in a lower gears. Did anyone out there have a four cylinder Volvo with overdrive, and if so, did the overdrive operate on the lower gears?
I think the 4th-gear-only was just how it was rigged at the factory--I know that my friend's MGB-GT could utilize overdrive in 2, 3 and 4, but he may have wired it up that way. It wouldn't be hard to do that.
Then, the sucker died when I put it into reverse. Thankfully, it started right up again, and didn't stall any more. It does seem to be idling a bit slow when I come to a stop, so I might have to increase it a bit.
The real test, I guess, will be when I go out for lunch. In the past, the car always got me to work, but it was a toss of the dice as to whether it would get me back home!
I had no idea retractable hardtops went back this far.
Those '57-59 Ford Skyliners seemed to have a pretty good survival rate; at least I always see a good number of them at the Ford show in Carlisle PA.
I heard that they weren't such a hot seller partly because of the price. IIRC, a regular Ford Sunliner convertible started around $2500, while the Skyliner retractable was around $3500. $1000 doesn't seem like a lot of money, IMO, for that kind of technology, but at the time it represented a 40% increase in the price of the car! And that was just base price. I'm sure once you added a bunch of options, the price went up fast. My grandparents had a '57 Fairlane 500 4-door hardtop that was pretty well-equipped, and Granddad said it was around $3500, as equipped, so it probably had at least $1,000 in options tacked on.
This is kind of a Jay Leno car--one that you can talk about because nobody else knows much about them.
The first Peugeot 402 Eclipse retractable was, in fact, power-operated, in 1935.
I think people tend to forget that France at one time was the absolute leader in innovation in automotive design and engineering. This had probably waned considerably by 1935 (hence the super-tricky 402 for a swan song perhaps?) but at the turn of the century, it has been said that "Germany gave birth to the car, France provided the nursery to make it grow, and the United States brought it to maturity".
Sort of the opposite of what happened in aviation---the USA gave it birth and France produced the first modern airplane.
I remember years ago, seeing a Skyliner in a junkyard near Culpeper VA, that had its top eternally in the half-up position. I always thought it was kind of odd that it was left that way. I'd think they would have cranked it down, if possible, to try protecting the interior, but maybe it simply broke in that position?
Had one of these back in the 50's. No problems with the top at all, and had it for 3 or 4 years. Definitely turned heads whenever the top went up or down. It was a fun car at the time.
Here's a write-up of how the top worked:
http://auto.howstuffworks.com/1957-1959-ford-styling10.htm
Yeah, good point. Plus, when that car originally came into the junkyard, more than likely it was worthless, just an old car that was overly complicated that nobody wanted.
I think the last time I even went in a junkyard was Columbus Day weekend in 2006, after someone stole one of the wheels off my Intrepid. Hubcap, lugnuts, and all. Back in the day, if I saw a car with the windows rolled down, I'd try to roll them up to help protect the interior from the elements. Probably hard to do nowadays though, since most cars have had power windows for some time now.
It's probably kinda silly to do something like that with a junkyard car, but who knows? It just might save some interior part that someone else is looking for.
Sounds like something I would do. The other thing that always bothered me about junkyards was if someone needed a part that was hard to get to they would simply punch a hole or start ripping parts out. It would suck for the person who needed the part they destroyed.
Where's Italy's place in automotive history?
But that was then and this is now. Even Harley Davidson uses Marelli electrics.
Probably the Italian contribution to the early automobile was in racing, with FIAT. But they were soon eclipsed and not to dominate again until post WW II.
Also, weren't the Italians at the forefront on the widespread use of 5-speed transmissions and overhead cam engines on popularly priced cars, plus fuel and space efficiency?
More here
EDIT: Note the seller's remark, "Bring a Trailer Please keep out." Too funny.
"Bring a Trailer Please keep out." = "Don't clue me in on my insanity and uncontrollable ego"
For the price he is asking, one should be able to find a very clean, totally sorted out running car. Near show quality actually.
Presuming one even wants one.
Soooo, you cannot get to THERE from HERE very easily. This car needs a total restoration, every nut and bolt. Can you do that for $75000? I don't think so. Well maybe if you owned your own body shop, did all the mechanicals yourself and had 5 years spare time.
TRIVIA: The name "Mangusta", meaning "mongoose" in Italian, was a dig on the Ford Cobra. The mongoose is the natural enemy of the cobra.
Well good luck with that on a race track. :P
The problem here is that you end up with a car that many people like to look at but nobody wants to actually drive (unless they really like scaring themselves. Handling is atrocious.)
it's an expensive coffee table IMO.
Somebody will take it on, but not for that money. You'd be a damn fool.
Though on this car, you can't even cheat to save money by sticking in a US V8, since they did it for you.
Interior looks a tad shabby there.
And can't imagine trying to find parts for that beast.
I just don't know where the seller pulled this price from. He seems knowledgeable, yet his pricing speaks of ignorance to the marketplace.
I suppose I should heed my own advice when I tell people "asking prices are merely the seller exercising his First Amendment Rights" :P
