Well, it does have to be relatively inexpensive while not needing work, so its possible I'll HAVE to settle on a 912. It all depends on what's out there at the time, of course.
Also, it seems like one of the most important things you can do with an older Porsche is a PPI (pre-purchase inspection), and another one of the most important things is to have maintenance records.
The 912 is not a great choice...I have owned 2 of them....I used to describe them as "VW performance at Porsche prices". The 911 is so much more car for almost the same money. engineer is right...avoid the 2.7 liter cars like the plague or woe is you--it'll pull the studs right out of the case and you're in for a $12,000 rebuild. Yikes! My choices would be either a 1973 & 1/2 model with CIS injection, or the 78-83 SC models. Yes, they are clean and without tails, etc. And most SCs have sunroofs, which is a GREAT option, since 911 ventilation systems really suck from that period.
A clean well kept 914 would be a fun option for you, if you can tolerate targa tops. Targa tops are a pain in the butt. They squeek, they leak. Same with the 914 or 911. You really have to want one.
A 911 sunroof coupe from 78-83 is the best of all worlds....you get excellent performance, a rugged, non-fussy car, and you don't have to pay through the nose for one...and they cost no more than a 912 to keep on the road.
I have also been more seriously looking at the 78-85s or so. I like the idea of motronic fuel injection over CIS (bad flashbacks from my possibly misguided love of 80s Audis), but CIS if maintained seems to work fine. If I go that route, I would be looking for a sunroof car.
What would a completely clean and nothing-needed example cost? Of course this would change by the time I'm ready, but hopefull not too much.
Yup, noted and already part of the plan, although there is a company that makes all kinds of adapters to fit other engines to the 914 bay. There are a few EJ20 914s (914 with the Subaru Impreza WRX motor) running around, but I am not ready to take on that level of fabrication.
So with the 2.0 it comes out to about 100 hp (96 or something) in about 2100 lbs, with your butt about 2.5" off the pavement...how bad could it be?
I think this:
'68 912
Is a great deal prettier than this:
'79 911
Maybe I could get a late 60s 912 and put a late 70s 911 engine in it.
but you say '77 is not a good engine year, right?
well, anyway, that's the style I like. If the one I think looks the best is not a good choice mechanically, then maybe I need to drop the Porsche idea.
Stuffing a 911 motor into a 912 is doable but by the time you do it, you can just go out and buy a 911---even an earlier one with the chrome bumpers, etc.
By the time you buy a 912, then buy a good used 911 engine, then all the bits and pieces you'll need (oil tank, flywheel, clutch and whatever, plus all the labor....well by that time a real '69 911 for $15,000 will start to look pretty good.
You don't want to go much earlier than '69 for a 911 as the handling gets tricky. I think a 1970 911E is a sweet car. The 911T (for touring) are common, cheaper and somewhat underpowered.
155 hp isn't scorching, I understand, but its probably adequate for such a car, isn't it?
Anybody have data on that? What are we talking? Maybe 8 seconds to 60 mph?
Maybe I'm being too optimistic. What did these cars weigh?
I don't really know the differences in transmissions...I know the 914 uses the 901 transmission, which has 1st gear by itself, down low and to the left. Not my favorite way to shift.
As is usual at BJ, this seems like excessive bidding to me.
Stuff I just wouldn't expect at BJs based on the stuff they've put on the block the last couple of years. Seems like either they are expanding their horizons OR everything else has just gotten SO expensive that they figure they should start driving up the prices across the rest of the market.
For instance ... an '87 Olds Cutlass? How about an '84 Mustang? Or a '73 Riviera Hardtop? '74 International Scout II? The list goes on and on.
It's a nice looking very low mileage Can Am. Kinda sad though that it was a base model that was well-preserved. Crank windows, no buckets or console, and the relatively tame 403. These things officially came with a 200 hp Pontiac 400, but Cali and high-altitude areas got stuck with the 185-horse Olds 403.
Was the horsepower of European cars rated the same back then as it was for domestics? i.e., that gross vs net thing? So that 80 hp gross would be more like 60-65 net?
If the seller tried to re-sell that car privately in a dinky want ad, he wouldn't get that price.
You gimme $18,000, I'll get you TWO nice 914s and pocket the change.
Geez, my buddy is building a very nice black one, with a 2.4 (!!) hotrod motor, clean clean car, for maybe $8,500.
:surprise:
My '96 Subaru 2.5L is year 1 of the notorious Subaru head gasket failure, and I still have it (even after replacing said gaskets!). All makes, models, and years have their quirks. :sick:
I think having a better car to start with tends to make the quirks a little more tolerable, though!
A 1992 Roadmaster should have a TBI Chevy 305 with 170 hp or, if optionally equipped, a TBI 350 with 185 hp. These B-bodies went LT-1 for 1994, with a 200 hp 4.3 V-8 (Caprice only) and 260 hp 5.7 V-8 for everything else. Now maybe these LT-1 engines might have gone through some lightening techniques, such as using plastic intake manifolds which wouldn't hold up as well as the old iron ones.
Also, since this '92 Roadmaster is a wagon, it might not be THAT floaty. I think wagons often had heavy-duty suspensions for towing/hauling, which cleaned up their handling considerably. And by the time these cars went to the LT-1 for 1994, I think they made them all fairly firm, except for the base Caprice.
I'd predict it'll be bid to about $8,500, allowing for eBay euphoria.
uh... but again ... NOT that color!
But its very big and very heavy ... i don't expect much, personally. Maybe its worse than I imagine, I dunno. Some day ... if I ever come close to a purchase ... i'll have to try one out.
ya know, now that I'm thinking about it ... I'm not sure I've ever truly driven a pre-1978 vehicle ... hmmmmm....
i've owned a couple older than that, but they were never on the road. huh... seems strange... i MUST be forgetting something.
*slaps forehead*
Excuse me, I need to "thin out" my abandoned car collection....
ugh!
Love the idea, but too much money, IMO.
Like these, but don't know...
Like these too, $$??
Don't see many of these, but it's an auto.
Still runs? Seems overpriced. Looks like a Stratus or Sirius at first glance.
No way!!
Maybe. BRAKES!! Dammit!! That has to be the most often misspelled word in automotive history!!
Like these for some stupid reason.
I'm speechless.
Nice project, too much moola, IMO.
All of my opinions are based on asking price. I'd consider the Cutlass for around a grand, if it's all that it seems to be. Maybe the Caddy if it could be repaired relatively inexpensively. There are more that I would consider, and share, if only the owners could figure out how to post a freakin' picture!
Anyone make aluminum slots for FWD cars?
Most FWD wheels I see are very flat-faced, as the part where they actually bolt to the car is pretty far outboard. RWD cars, it seems, tend to have wheels that have more of an offset, which allows for deeper patterns, like those slotted wheels.
If you put those particular rims on a FWD car they'd stick out too far. But I also have a feeling that if someone tried to imitate that style for FWD use, it would just look flatter, and not as attractive.
I've always wondered...why DO they make FWD cars like that? It's not a recent trend either...even the old Eldorados and Toronados of the 60's were like that.
