The Future Of The Manual Transmission
15657596162205
    Yup 204 hp and over 3,600 lbs of curb weight does not make a good combination.
    It also has this funny hump on the driver's side of the transmission tunnel. I guess this is where the driveshaft for the front axle comes out and it takes away most of your right leg room.
  • plektoplekto Member Posts: 3,738
    True - I should have given the S class a pass. :) They only come in automatic over there and it's a quality unit. but an E or C class - manual or be prepared to pay BMW type repair bills. (yes, you can get manual E classes but have to do the European delivery thing last I checked)
    The manual C class with the V6 engine is an absolute rocket, btw. Easily 3 series competition.
  • michaellnomichaellno Member Posts: 4,120
    The bloat of recent cars is approaching 1970s GM standards.
    Tell me about it .. my L300 weighs in at just under 3200 pounds, while its replacement (Aura) is 3600-3700 pounds.
    One of the metrics I look at with new cars is pounds per HP .. even as HP increases, so does the weight of many new models, so the value of the calculation stays about the same.
    But, aren't manual transmissions lighter, generally, than their corresponding automatic brethren?
    The Volvo S40, V50 and T60 are 5-cylinders, but are available with stick shifts.
    VW Jetta and Rabbit also have 5 cylinder engines and manual transmission available.
  • fintailfintail Member Posts: 58,755
    It'd be something if AMG cars could be made manuals - but I know all too often the original owner of an AMG car is some lazy bloated plutocrat who couldn't figure out a clutch if his life depended on it...or even worse, his trophy wife :sick:
    I've never seen a NA-spec E-class with a manual, unless you count something like a 280E from 1978.
    For instance, I wouldn't buy a Mercedes with an automatic under any circumstances. It's a Chrysler piece of junk thrown in to appease the U.S. drivers.
    Huh?? Where did THAT come from?? As far as I understood, Chrysler used Benz trannies, not the other way around. Chrysler didn't know how to make anything other than a 4-speed with the reliability of wet paper until benz gift wrapped their 5-speed for them to put in SOME of their cars.
  • texasestexases Member Posts: 11,177
    A bad IS250 combination for sure: AWD/auto/2.5l - ouch! You'd think they wouldn't allow it, auto/AWD only with 3.5, say. I wonder if it's even been worth their while to do the 2.5l.
    And your 4cyl options + stick?
    Element Accord, Civic, Fit
    You can't even get AWD with the 3.5 liter at least not right now.
    Too many to list here, that's for sure.
    Everything from a Chevy Aveo to a Saab 9-3 comes with a 4-cylinder. Some are more fun to drive than others.
    Heck, if the 6-cyl list is short, what does the 8-cyl + stick list look like?
    Pickup trucks and the Corvette? Oh, maybe the Audi S4 and other similar vehicles.
    Will the new Pontiac G8 come with a 6-speed stick?
    Element, Accord, Civic, Fit, TSX, Sentra, Altima, Mazda3, Mazda6, MS3, MS6, Miata, Focus, Fusion, Scion, Matrix/Vibe, 'rolla, Cobalt, Aveo, C-class, Saab 9-3 Linear, Legacy, Impreza, Sonata, Accent, the one inbetween, Mini, hmm I'm starting to struggle now...
    the one inbetween,
    That would be the Elantra.
    Don't forget Kia and Suzuki.
  • cotmccotmc Member Posts: 1,081
    Hmmm.... the Subject line reads "6-cyl+stick options", but the list below sure looks like 4-cylinder models. :blush:
    How 'bout the 2.0T models from Audi/VW, such as the A3, A4, Jetta, GTI, Eos, Passat...
    Read back one more post...
    yup!
  • mcdawggmcdawgg Member Posts: 1,722
    Camry
    I understood, but played dumb. That's why I had the blushing emotorcon.
    True, but Mercedes puts absolute rubbish in their lower-end cars in Europe as 80%+ of all Mercedes sold in Europe are manuals. Nearly every last automatic except for the S class models is rental car fodder and it's a worthless transmission. So it's barely an improvement because well, Mercedes hates automatics as a rule. It's a German thing I think :)
  • oldfarmer50oldfarmer50 Member Posts: 24,516
    "...The bloat of recent cars is approaching 1970s GM standards..."
    After all the gas scares of the 70's the car makers went on a fanatical weight reduction binge to increase gas mileage. Recently, if what I read is true they have been going to much stiffer bodies to reduce flex and help handling. That, coupled with extra safety equipment like extra airbags has boosted average car weight.
    "...One of the metrics I look at ...is pounds per HP..."
    There was an article in Car and Driver a while back where they compared the HP/pound ratios of the fastest front drive cars. Other than the data charts, the article just moaned and groaned about how much wheel spin they all had.
    That makes me think. What part does drive wheels play in the decision to choose manual over auto? If you have a higher power car with front wheel drive does it make any sense to have MT? Can you effectively put that power to the road?
  • habitat1habitat1 Member Posts: 4,282
    M/T or A/T, there is absolutely a greater diminishing return when it comes to FWD. My 1995 Maxima SE 5-speed w/ 190 hp was tested at 6.6-6.7 seconds 0-60. The 1995 189 hp 328i was essentially the same. My 258 hp 2004 TL 6-speed is in the 6.1 second range and the 286 hp TL-S is in the 5.8. Faster, yes, but not as much as you would think with 50% more horsepower. By comparison, the 300hp 335i is in the 4.8 second range, which is enormously faster than its 1995 predicessor. What 250+ hp gives you in FWD format is a lot of excitement - as in wheel hop and torque steer that can be very difficult to control if you are trying to accelerate hard. As soon as you pop the clutch, the dynamic weight transfer shifts the weight backwards over the rear wheels and off the pulling front wheels. I have no doubt that an average driver in a 220 hp 328i (not 335i) will beat a good driver in a TL-S 90% of the time, because "launching" a FWD car with 280 hp is a hit or miss proposition.
    On the other end of the spectrum is my 355 hp 911S with the engine hanging out over the rear wheels and putting 62% of it's static weight at the rear. It easily outaccelerates the 400hp Corvette to 60 and in one road test, the 500 hp Corvette Z06 and Viper as well. Plus, I could point it straight and take my hand off the steering wheel and it will go straight in acceleration. Doing that in the FWD TL will put me in a hospital or coffin.
    I don't think this suggests manual transmissions are not appropriate for powerful FWD sedans. Rather, that past a certain point, additional power in a FWD chassis is peeing in the wind. At some point, dangerously so.
    "...is peeing in the wind..."
    I think that would be dangerous at any speed. ;)
  • daysailerdaysailer Member Posts: 720
    If you can't put the "power to the ground" with a manual transmission, then the nonlinear, unpredictable response of a torque converter certainly won't help.
  • bristol2bristol2 Member Posts: 736
    I believe that being able to modulate the power going to a FWD through the clutch on take off would allow a manual to make better use of power.
    I have the v6m6 Accord and if I am trying to take off fast from a stop round a corner I am glad of the clutch control.
    I think clutch control is good to have, as well as some wheelspin. Wheelspin is good because it can keep the engine from bogging off the line. I personally wouldn't drive my car like that very often, but if you really want a good launch, a bit of wheelspin can be your friend.
    So, what do we have?
    Most domestic pickups
    Corvette
    G8, when it is released
    Ferrari
    Are there any BMW's available with a V8 and a stick?
    I might consider the 2.0T available on the Audis and VWs.
  • stickguystickguy Member Posts: 54,046
    the 550 V8 6 speed is for you. My BIL has one. Enough power to get out of it's own way!
    Yours for only about 60 large.
    I suspect that is the base price, right?
    That's a little out of my price range.
    I might, however, hold out for a 1-series. There will be a 128i and a 135i, right?
    That's the story. The 135 is on my shopping list, too.
    As much as I think the 550i 6-speed is a great car, the 535i 6-speed makes a lot more financial sense:
    The base price is about $9,000 less. 15-20% better gas mileage for the 535i. Lower insurance costs, based upon my previous quotes on the 530/550.
    The 550i may be a tad quicker, but that would be a very small tad, given the extra weight of the 550i 8 cylinder. And the lighter weight 535i would probably handle slightly better. I suspect that BMW is going to have a tough time selling 550i 6-speeds for the performance minded, when the 535i 6-speed has virtually closed the gap from the previous 530i. They will still probably sell 550i's automatics to the stubborn buyers that think a "luxury" sedan requires an 8 cylinder engine, but I'd be hard pressed to spend the extra dough for a 550i 6-speed today on performance. (And I did spend the equivalent of $6k for the "S" label and 30 extra hp on my 911.)
    A 535i 6-speed via European Delivery is probably the best manual transmission luxury sport sedan value out there. Albeit it still is a lot of dough.
    I just went to BMW's website and signed up with them to be invited for an early test drive when they start showing up at the lots.
    I'm thinking the 128i would be enough for me .. keep the options to a minimum.
    Any word on pricing? Gotta be less than the 3-series, but by how much?
    And, are we talking 5-speed or 6-speed?
    I believe 6-speed. Pricing is up in the air. Rumors have been floated anywhere from $25k to $30k starting price for the 128. Personally, I'm hoping for a $30k 135i base.
    What about a Legacy GT?
    More power than a Passat 2.0FSI and it's got AWD to get the power down effectively.
    Road & Track had a nice article about manual-trans sport sedans about a year ago and the Legacy lapped the track the quickest of all. It was quicker than a MazdaSpeed6, a BMW, an Audi, and an Infiniti to name a few.
    No torque steer at all, either. The front axle has equal length half shafts and 50% of the power goes to the rear axle.
    GT comes with 5 speeds, spec.B comes with 6.
  • boaz47boaz47 Member Posts: 2,747
    I know it is a bit off topic because no WRC cars have a dog leg but have you been following WRC this year? Looks like Subaru is falling into the perpetual third place spot once again. Ford is so far ahead of Subaru and the season is half over. Not only does it look like the manufacturers championship is out of reach so does the drivers championship.
    Now if Ford would bring a example of their WRC car to the US I could die a happy man and at least test drive, though I might fork out quite a bit for one of my own, a real paddle shifting car.
    I fully realize my acceptance of the SMT comes from all of the years I used to ride Motorcycles. There is absolutely no need for H patterns in todays cars other than tradition. Down shifting has never been a problem even when it is done with the tip of your toe. In fact at first they could keep the clutch if we could simply get a OEM SMT or DSG if that is what it would take. The straight pattern would make spirited driving very interesting indeed.
    Subaru needs a smaller WRC car. The current Impreza is just too big to compete.
    The 08 is a tad shorter but honestly I wonder if they went far enough with the change for the WRC car specifically.
    Some domestic pickups. GM dropped the manual on all half-tons, and Ford and Dodge play musical engines with their manual availability.
    Legacy GT is nice, but it uses nearly as much gas as a Corvette.
    i agree. but if the traction control kicks in and derates the engine and modulates the brakes, be prepared for a mental bog.
    Don't get me started :P
    You know most of the WRC racing things are all your fault. I would never have been interested if someone from these forums hadn't challenged me to watch them. I am still not a fan because I like to see racers racing each other rather than the clock. But it does look like Ford will take the whole thing this year. Not as dramatic as when Ford took Ferrari down in the early 60s but internationally impressive anyway. And not one dog leg in the whole bunch.
    For 07 they added Si-Drive, which lets you dial back the throttle response a little, and mileage improved. You may want to take a 2nd look.
    I plead guilty, Your Honor. ;)
  • irismgirismg Member Posts: 345
    I'm so glad I found this site! I have questions to ask about technique, but for right now I'd like to know if any of you who don't have an alternate car they can drive have found themselves with a cast on their foot for six weeks. If so, how do you drive your stan-trans car in that case?
    Thanks, and keep up the interesting discussions!
    You really shouldn't.
    Find a relative that has an automatic, but can drive stick, and switch with them.
    I had a sprained ankle and had to commute by subway for a few days. :sick:
    Now I have one of each so I'd be fine.
    What kind of car? If it was a diesel not a big problem. If not it can be tricky.
    LOL :D
    In Oklahoma City, not an easy option. Next?
    Probably depends on how heavy/light your clutch is and what kind of injury you have.
    Probably your pain threshold has some relevance too.
    Back when I worked for UPS I tripped on the shop floor and put the corner of a metal desk through my right hand.
    It was a miracle the corner missed all my tendons and bones so I just ended up with a big hole in my hand. I couldn't move my hand much without pulling out the stitches, I had little strength in my hand and every time I tried to grip something my hand hurt like a @#$%&@*.
    I just shifted with my left hand for a few weeks till I had the stitches taken out.
    Could you explain?
    Now THAT'S interesting! That made for some slow shifting, didn't it? At least it didnt involve the footwork.
    I drove a 5 speed Tercel for 2 weeks with a cast on my left leg. But I don't recommend it. And I only drove the car a few times to run local errands - no commuting or fighting traffic. I don't like to think what the consequences would have been if I'd been in a fender bender - probably a ticket for failure to maintain proper control and a fight with my insurance carrier.
    The Tercel's clutch was very light. Starting out, I'd put it in first or reverse clutching with my right leg and idle at first, using the hand brake if needed.
    Once I got going, I'd just match the revs and shift up and down without the clutch. If you watch the lights you can usually creep along in 2nd and not have to wait at too many reds and avoid starting off in first gear as much as possible.
    If you really need to get somewhere, rent or borrow an automatic. Even then you'll get some looks when you climb out of the driver's seat and reach for your crutches. ;)
