Visitor Agreement.
How was it a complete failure?? I didn't think the Honda had paired a manual and hybrid until the CRZ and that's designed to be a performer - not a sipper.
Only "indications"....??
That statement is a bit "soft" for you...
Fully cut the fuel with a "stick" shift, the driver suddenly, fully asynchronously, disengages the clutch....
Now you need to restart the stalled engine.
But again...
With an automatic the transmission can be "continuously" downshifted as road speed declines thereby keeping the engine turning even with FULL fuel cut...
How could that possibly work with a stick shift....?
So I can disable the OD in my '01 F/awd RX and still get 22MPG hwy at 70MPH...??
I personally am not anywhere close to needing one @ 167,000 miles.
I myself don't like to go IN THERE twice on a FWD car. :sick: So if I had a TDI, I'd replace everything in there within a square mile. clutch, pressure plate, throw-out, pilot bushing, maybe clutch fork pivot/bushing, flush out hydraulic fluid, rebuild clutch slave, and I'd take a real good look at the flywheel, because I hate clutch chatter.
MINI clutch, full job, maybe $2200, because of 12 hours labor and dual-mass flywheel, which is a factory defect from the get-go and needs replacing.
Still, it's not $6,500 bucks.
What about the V6 Altima CVT? They've been around for a while, too.
Now you need to restart the stalled engine."
You either failed physics or you're referring to folks who downshift slower than molasses in January. Ever hear of angular kinetic energy? Nope, didn't think so. The fact is the rotational mass of the engine, flywheel and clutch has more than enough angular kinetic energy to keep the engine rotating for the duration of the shift without so much as a molecule of fuel being injected into the engine.
Like I said earlier, time for you to deal with it and move on.
Are there broad power bands, though? With more turbos and smaller displacement engines, I'm not sure that's true any more.
Plus, we should look at RPM drop between shifts. It's much more than just a 2500 to 2000 drop.
I believe it; that however is small consolation for the poor souls still behind the wheel of one (or waiting for one to get fixed yet again).
That's what I mean as far as diesel costing more per mile than regular gas. If you're getting 45mpg in a diesel, because of the extra cost in the cost of diesel fuel that's the same as getting 39.5mpg in a gas car. So when you see any MPG ratings on diesels, you need to factor in the cost of the gas.
I don't buy that argument, and I've seen a lot of VW guys pitch it.
Passat is slightly smaller than Camry, forget the Jetta.
Jetta competes with the Civic, Corolla, etc. Prius is a hatch so it's hard to compare, but I'm sure it has more interior room than a Jetta sedan but less than a Jetta wagon.
I've even VW guys talk about how a Polo TDI beats a Prius, ridiculous. Now that's comparing a Sub-Compact with a Mid-sizer, 2 size classes above. We may as well compare a Prius to a Touareg TDI, then.
I never get why there is such hatred of the Prius. I don't even like them, but I'm shocked at the lengths people will take to criticize them.
Shocked!
So a focus group of one deems it a failure?
Jetta vs Corolla doesn't, however. I'm not sure about overall size, but I can tell you for a fact that the interior room in the Jetta is far far better. I don't even fit in a new Corolla (buddy at work just bought one and I tried), whereas I can actually get quite comfortable in a Jetta.
Have you taken a look at a VW/Audi 2.0T torque curve recently? Full torque develops at something like 1,800 RPMs before the curve flattens well into the 4,000 RPM range.
Based upon the numerous reports I read "back in the day", her car was quite typical of the breed.
Plus the Prius actually gets higher MPG - not a lot, but it compounds the advantage. I think CR got 44 in the Prius and 38 (IIRC) in the TDI.
I prefer manuals, and I'd prefer a diesel over a hybrid for driving enjoyment purposes, but let's not lie to ourselves - fuel costs for a Prius are much lower than for a TDI.
1000 miles / 44mpg = 22.7 gallons at $3.584 AAA national avg = $81.45
1000 miles / 38mpg = 26.3 gallons at $3.893 AAA national avg = $102.45
Both are good, but the Prius wins by a wide margin.
EDIT: CR on-line had two Jetta TDIs at 33mpg and 36mpg overall, but I won't be cruel and re-do the numbers and increase the height of that "Prius pedestal". Even leaving that generous 38mpg it gets crushed, end of story.
PS My personal preference would still be a diesel, by the way, yes I would pay more for one vs. a hybrid, but let's not kid ourselves you will spend more on fuel, period.
Works for me, too, and it was the Golf that got the 38mpg I mentioned in my previous post.
So figure on spending about 26% more on fuel in a Golf TDI.
But I think with the new CAFE standards, continued strict emission controls and continued extra cost for diesel, hybrids mated to CVTs are going to be growing quicker than diesels with manual transmissions.
Good question, let's look...but not an OEM-claim massaged and smoothed one, a REAL one:
http://www.034motorsport.com/images/Laszlo/B8_A4/034_B8_HFC_Gains.jpg
Blue XXXs show the stock curve, and you definitely see a peak between 3500 to 4200 or so.
So you would need tight ratios in the DSG so that a shift from 4200 did not dip below 3500, but I doubt that's the case.
CVT could keep it at the 3600 peak the whole time. DSG would likely dip to that 3200 point, is my guess, so you would enjoy 255 lb-ft instead of 281 lb-ft.
Still adequate, but not maximized like a CVT could be tuned for.
To bring this back on topic - this is where a close-ratio 6 speed manual has an advantage over a 5 speed manual.
http://consumerguideauto.howstuffworks.com/will-a-hybrid-save-me-money-in-the-lo- ng-run4.htm
So you pay more now, but you do eventually get a return on that investment. Some where between 80 and 100k miles depending upon the price of gas.
2010 tdi wagon vs prius
Price is about the same, passenger volume slightly higher for the prius, legroom, hiproom, etc., cargo volume greater for TDI.
Seems a fair comparison to me...
21cuft of trunk space in the Prius and more rear seat leg room as compared to the Corolla. For me and my family of 4, the Corolla was way to small.
Since I needed the 2004 Prius/2004Civic for a purposeful commute 1 to 3 commuters)., the Civic has proven to be the better choice over the Prius. I have no doubt we could have probably gotten 50 mpg in the Prius vs the 38-42 mpg in the Civic. The Prius for that year would be close to 2 x higher in price. The Civic is @ 127,000 miles and will sell on the open market for app $2600 less than paid, new. Needless to say resale value remains very good.
Is that wagon still based on the previous Jetta, though?
No surprise the wagon wins on cargo space.
The Golf TDI comparison may be closer in that regard.
Wrong. Even Audi uses CVT technology in the A4. It is no better that Nissan's in my experience having had both as rentals at some point. It is simply cheaper than a true 6 speed automatic, and especially cheaper than a dual clutch version. I don't see CVT outperforming DSG, wish there was an example with the same car though.
Did you look up the replacement cost for the 6 speed manual to find the true delta?
woops, nevermind, read it later, 2,200. so about 4K more for CVT! wow. What's the lifespan on CVT's being reported as typically?
I can see the EPA being biased against diesels if they don't like diesel fuel being used, but what in the world would be a motivation for being biased against manuals? After all, most automatics come with manual mode nowadays :P
However, only in a DSG do you really have truer control of that manual mode, but even that is limited to some degree (no bouncing off red line allowed, no stalling the engine allowed).
A remanufactured 6 speed manual transmission with differential is about $3400 list price.
I haven't heard of any problems with the 6 speed manuals however, other than that they seem a bit clunky to me.
I haven't looked closely enough but I bet 700 RPM's is about right for the 6 speed DSG in my Audi A3. The ratios are VERY tight and close. Too close and tight in my opinion, for CA where you have many straight and flat roads, but ideal when you are in mountainous twisties. I think 5th and 6th are only like 500 RPM apart.
Kind of floaty, poofy, quiet, mom's couch kinda-cozy feeling. It wasn't at all unpleasant, and a very comfortable car for a long journey.
But sporty? fun? exhilarating? Life affirming?
Er.....no.
AVG. mpg was 47.
Same exact trip in fun, sporty, exhilarating, life-affirming MINI Cooper the following year----AVG MPG was 33
Over 2M folks (Prius buyers) are just fine with its ride. I think if I HAD to have a Prius, I would do my best to overlook its RIDE.
For me, I like the combination of (VW's Jetta TDI's) massive torque (155# ft vs 100 or so) and I would suppose I would be fine with 59 mpg @ 75 mph, but I'd be fighting road hypnosis.
Are you sure you're not talking about my Miata? It's exactly the same way. I usually skip 5th and go straight to 6th!
Some thing has gotta give, though, and in the Miata it's RPMs at high speeds. I'm close to 3000rpm just past 60, at higher speeds it's screaming down the road at 4000rpm at times. WAAAAY to high. For 2009 they made 6th slightly taller, but only slightly. It's still too short-geared for high speed cruising.
I guess it depends on the application, but a CVT can have a wide range, from the lowest to the highest gear, and avoid this. A good example are some Subarus - at 80mph they run around at 2000rpm, so better highway mileage than my Miata in a car twice the size.
I can't even tell you the RPM in my Miata at 80mph because I think I'd lose my hearing.
I test drove one when the local Whole Foods had a loaner available (perfect product placement), and I liked it OK. In that city environment handling never came in to play, and the electric motor felt torquey off the line.
In the right context it makes sense, even if it's not my cup of tea, either.
Some comic relief this thread could use right now:
http://www.youtube.com/watch?v=2UFc1pr2yUU
It's gettin' real in the Whole Foods Parking Lot..
"Pay my 80 bucks for 6 things" make me LOL.
My '88 Porsche has an "upshift" signal/indicator (programmed for maximum FE), which most of the time I simply ignore.
Real world testing, drivers are instructed to be LAZY, drive the stick in the way most driver's would, NOT in a way to "artificially" improve FE.
I suppose in theory if the operator of the vehicle waits until the RPMs are under some arbritrary number (800 RPMs plus or minus 200 depending on the engine and cylinder count?) and they shift real slowly, it is possible for the ECU to be called upon to use some fuel to keep the engine running. That said, even the worst stick driver I've ever encountered wouldn't wait that long before downshifting.
Long story short, in the real world I seriously doubt the off throttle fuel cut-off mode is ever interrupted during a downshift.
