I couldn't find pictures of South African Holden/Chevies from the 50s but I found more
RHD Opels...>
And LHD US Chevies from SA....>
...Moving forward to the 60s we find Holdens that look like Chevies but are badged as Holdens in the U of SA>
<img src="http://www.dyna.co.za/cars/Holden_61_Special_Grey_sf1.jpg
Jose
It's an Invicta, and as it is an 'underslung' car, with reduced height chassis, (simply by putting the spring hangers on the top of the chassis) I assume its a 4-1/2 litre, from about 1932/5. Invicta went bust a couple of times in the thirties, and were also connected with Railton, who were also on shaky ground, but they did revive briefly after WW2 to make a handful of Invicta Black Prince cars, before finally collapsing about 1950.
There have been several attempts to revive the name, indeed I think there is one currently available, but they have no real connection with the real Invicta like this. A lovely car....
The 850GT, also known as the Saab Sport, Granturismo 850 (USA) or the 850 Monte Carlo('66-'68).
Bingo! Sorry Urnews, but you see those side marker lights only on 1968 or newer vehicles. Those wheels are aftermarket but period-correct and give the car a menacing look it wouldn't have w stock wheels.
Most likely the crank hole was more likely just a retro styling touch as on TR-4s of the period. My '66 TR-4A had the hole at the bottom of the grille work but behind that hole was the radiator, inserting a crank there could have resulted in a nasty leak.
I think possibly TR-3s could be crank-started, anybody know?
This red roadster is even more rare than the Cord 812 behind it but unlike the Cord, it is postwar.
Regrds,
Jose
Hmmm. The styling cues are Austinish, it's true.
Call me a skeptic, but despite the RHD I don't think it looks British. It seems a bit large, and the Brits were mostly making very small poverty-spec cars in the first decade after The War.
I know there were some postwar Delages and Delahayes that were RHD. Perhaps this is one of their racing specials?
Then again, the wheels and the nose remind me of a '37 Ford.
BTW it isn't a one-off, about 1000 were made.
Weird.
Could it be Belgian? Minerva wasn't still around, was it?
You're pretty hot now Stephen, it is Belgian and there was a connection to Minerva.
After Minerva failed in 1935 it was absorbed into Imperia Automobiles of Liege, then owned by a Belgian textile maker. After WW II Imperia assembled Standard-Triumph cars under license and in 1948 used the Standard-Triumph chassis to produce the Imperia TA-8 shown, replacing the pre-war Adler drivetrains used with a Gregoire designed 4-cyl powerplant licensed by Hotchkiss.
Concluding that they could not make any profit from the design, Imperia's owners returned to the manufacture of Standard-Triumph designs after '49 until S-T opened it's own assembly plant in Belgium in 1958.
Really nice car, went like a cut cat, and handled pretty well at the same time.
As for the pre war stuff, was in response to the guy asking for more of a challenge..
If so, I'm guessing some sort of early '70s Saab (Sonnett?).
Here's a pic of the v4 in the Sonnett III
It sure looks like the Ford motor to me. But I'd say it's in a Saab 96 rather than a Sonett.
The other possibility (sure wish I had a better angle on the exhaust manifold) is that it's a itsy bitsy teeny weeny V6. Lancia Aurelia, anyone?
Fiat Doblo.
You're getting warm, here's another angle>
Yes, this got me curious, I didn't know that engine had a single OHC for both banks of cylinders, must have been the inspiration for VW's VR6! There was also a DOHC version (one cam intake, one cam exhaust). This pic helped me understand the setup (SOHC left, DOHC right):
Yup, from a 1956 Lancia Appia C10 Camionetta.
Wasn't bad for the time, but in 1987 when it was still in production, it was a new vintage car.
She also knew someone who had a Pacer wagon with a plaid interior...I remember I rode in it once when I was maybe 8...even then it was very bizarre.
