Mystery car pix
15285295315335341476
    The French copy nobody and nobody copies the French!
    They must use a Harley engine to replicate the traditional vibrating rear view mirrors of British cars. Well, at least you can buy engine parts at Home Depot, that's something.
    It's blurry but there's a nice potpourri of cars in this still from a 1961 movie.
    The gray car in the center is a 1957 Ford Skyliner. The white car off to the right is a 1958 or 1959 Ford Thunderbird. The parked black car looks like it might be a 1955 or 1956 Ford Mainline sedan. The black and white two-tome car ahead of the Skyliner looks like a 1956 Buick. The blue car next to the Buick might be a 1961 Dodge. The white car ahead of the Buick is either a mid-50s Ford or Oldsmobile.
    A Ford woody is parked off to the left - possibly a 1949 or 1950 model. Behind it might be a 1961 Valiant.
    Good job Lemko. The white Squarebird is a '58, it has the hash marks along the side spear. '59s had a chrome arrow at the tip of that side molding instead.
  • uplanderguyuplanderguy Member Posts: 17,067
    Another quick way to tell a '58 T-Bird from a '59 is that the "Thunderbird" nameplate is ahead of the front wheels on a '58. On a '59 it is on the spear on the door.
    Host, please remove, I didn't know it'd come out so big!
    edited November 2010
    The link inside the html symbols less than at the beginning and greater that at the end should be
    http://assets.hemmings.com/uimage/1643063-1600-1065.jpg width="650" height="432"
    I can't put the symbols the IMG key puts on, or the text won't show.
    The 432 comes from 650/1600
    then multiply that result by the current height 1065 which gives 432. Using those ratios keeps the height in proportion to the original picture.
  • stephen987stephen987 Member Posts: 1,994
    I'm guessing it's a Lamborghini Miura V12
    Good guess Stephen, but the Miura's engine was transversale>
    Thanks for the fix!
  • jwilliams2jwilliams2 Member Posts: 910
    Must be a 12 in a Ferrari...
  • texasestexases Member Posts: 11,177
    A Ferrari 12, flat 12 that is...512BB?
    Yes, believe you are correct, a flat 12 like in a 512 Berlinetta Boxer....has to be a flat 12 with the 4 Weber 3-barrel carbs....
    I'm gonna say a Ferrari 365 GT4 or similar. circa mid 1970s.
    Yup, you guys have the right idea. It is a 4.4 liter flat 12 as seen in the Ferrari 365 GT4 BB. In '76 a larger 6.2 liter motor replaced the earlier unit. The resulting 512BB was the best selling Boxer Berlinetta by a healthy margin and the 512 motor was carried over into the Testarossa.
    Question for you Shifty, since the flat 12 offers a considerably lower CG than a Vee12
    why hasn't it been adopted by other builders of mid-engine exotics?
    RE: flat V-12s
    Probably no one uses a flat V-12 because there are ready-made blocks available from any number of passenger cars which can be modified for the exotics. Developing a new engine from scratch is enormously expensive---I'm thinkin' 40 to 80 million dollars (or more).
    What about guys like Lamborghini, Bugatti and Pagani, they don't use adapted blocks do they?
    Lamborghini and Bugatti are now owned by VW, and both their engines are adaptations of VW technology. The Bugatti 16 is an amazing extension of the VR engines first seen in the VW VR6. Pretty impressive.
    Yep, the Veyron is like two very narrow VW-based V-8 engines stuck together in a W pattern--turbocharged of course.
  • sallyandmiltsallyandmilt Member Posts: 2
    We found this photograph of my grandfather and his wife with their new car from sometime in the early 1900s. (We actually found the negative and printed it, so there was no identification with it.) We know he had a Willys-Knight at some point, but my brother doesn't believe this is it. Can anyone identify it?">link title
  • cooterbfdcooterbfd Member Posts: 2,770
    Sally, there is no actual link.
  • fintailfintail Member Posts: 58,756
    I don't know exactly what it is, but it isn't a Willys-Knight, the design predates the existence of that company.
    I have a suspicion it is a ~1911 Cadillac.
    Cars of this vintage are hard for me to distinguish, unless you can see the script on the radiator or some other identifying part. Could this possibly be a Willys Overland? Willys production was second only to Ford in 1911, so they were fairly common.
    Both those guesses are good ones -- I can see that the car pre-dates electric lighting, so pre 1912-13. It's a pretty big car--the owners must have been people of some means.
    Could be, but I think the Overland cars were smaller - that thing looks to be pretty hefty. I googled some pics and Cadillacs in 1911 had the same lights and grille shape - which is still inconclusive as a lot of cars had that feature, but the body is Cadillac looking too. That's my guess. The AACA Experts probably will know quickly, I think some of them know brassies well.
  • wgraferwgrafer Member Posts: 592
    Looks like a '64 Buick Skylark.
    '64 Skylark is correct.
    That would be a Talbot-Lago Record T 26 Cabriolet from the 40's.
    Yup, a 1947 T-L Record with Figoni coachwork.
  • jlbljlbl Member Posts: 1,333
    And I'd like to have one of them. If only to admire it closely.
    Jose
    OK, I'll take the Thunderbird -- 1963.
    I believe the presence of the vent windows marks the Camaro as a '67. Hidden headlights indicate the RS package. Badging indicates it's an RS/SS.
    The old car way in the back looks like a 1942 DeSoto or Chrysler if those are painted "blackout" hubcaps. Else, it's a 1946-48 DeSoto or Chrysler.
    1958 Buick Limited Convertible.....with lots of chrome.
    Doh!, the license plate is a giveaway!
    MGA, not sure of the year...1959 or later if those are disc brakes...
  • kyfdxkyfdx Moderator Posts: 270,703
    '60 MGA
    Close, in '60 the MGA MK2 was introduced with a slightly inset grille like this.
    The car shown is a 1958 MGA/1500 Mk.1
    Yeah.. I was guessing.. my friend has a '61 with the inset grille, so I went one year older... lol..
    "refinement" of British cars of those days....
    http://www.youtube.com/watch?v=4nv9pGKovLA&feature=related
    Nice...yesterday's car, today! :shades:
    Here's what Germany was making around the same time:
    http://www.youtube.com/watch?v=h7YK9n6zaPQ
    (this is actually my car)
    Listen to this 1961 Alfa and look how beautiful the engine is!
    http://www.youtube.com/watch?v=JoBHJz7KLjg
    Hard to believe that's real, an Italian car running, not covered in oil, not on fire...must have been put in a hermetically sealed vault when new :shades:
    This is pretty awesome:
    http://www.youtube.com/watch?v=GXd4liZ6Io8
