Mystery car pix
16236246266286291424
    they were a rarity the day they were sold new. Typical agricultural engine for a Subaru of that period, but pretty torquey. My friend Jim said they were really nasty to work on. They even made a turbo model, which is banned from his shop apparently. And THIS is a man who works on Peugeots! :surprise:
    uplanderguyuplanderguy Member Posts: 16,186
    My guess is an early '70's Opel Manta coupe.
    Correction: I revise that to "early '70's Opel 1900 coupe". I'm thinking the name "Manta" wasn't used until the advent of big bumpers.
    andys120andys120 Member Posts: 23,415
    grahampetersgrahampeters Member Posts: 1,786
    G'day
    I'll guess at Rover P5B 3.5litre, although front overhang looks a bit wrong; could be perspective
    Cheers
    Graham
    Best to avoid any air suspension Subaru from that era. $2k or so to rebuild. In fact most find it's cheaper to convert to springs so they do that instead.
    Having said that, paisan owned an XT6, converted it to metal springs, and was actually competitive in autocross.
    The Subaru Crew did a fun run in the Pine Barrens and this other guy showed up in an XT with rally tires and all, and did this water crossing WAAAAAAAAAAAy too fast and ended up sucking up water in the intake and stalling out.
    He didn't get the memo that water doesn't compress like air does.
    Funny thing was they pulled the plugs, sprayed in WD40 and cranked it a few times, then before you knew it it was running again! Hilarious.
    Clutch gave out later that day. No surprise given the abusive type of driving he did.
    Any how, bizarro but fun little car that probably to this day makes most people think quirky when they hear "Subaru".
    Correct Graham.
    boomchekboomchek Member Posts: 5,516
    Mazda Cosmo, from early 70s? Wasn't this one of Mazda's first rotoary powered cars?
    Yes it is and yes it was. The full handle is 1972 Mazda Cosmo sports 110S.
    edited January 2012
    stickguystickguy Member Posts: 50,791
    Shelby GT 350. maybe a 65? or 66?
    edited January 2012
    1966 Shelby GT350H.
    I knew I should have 'shopped out that rear mat. Might have lasted another 30 seconds that way. :shades:
    It's going up for bid at Barrett-Jackson with several others.
    1965 Shelby GT350 Fastback "Barn Find" To Cross Auction Block (Inside Line)
    odie6lodie6l Member Posts: 1,173
    Here is one I wish they would have put into production.
    Odie
    Here's an outdoor picture of same vehicle...
    Odie
    subearusubearu Member Posts: 3,613
    That has to be a Pontiac concept of some sort, I have no idea what, but that nose sure looks a lot like a Firebird/Trans-am. Curious to what year this is from. Guess it kind of looks like an early '80's Corvette morphed into a Pontiac.
    -Brian
    Give you a hint... The Aztek morphed out of this concept. Im my mind, this would have sold better.
    Odie
    That's the Pontiac Rageous concept. I even have a hot wheels version of it.
    lemkolemko Member Posts: 15,261
    Clever! I also see a little bit of 1948 Cadillac in the grille. I believe this is another Russkie copycar called the ZIM. I'd say this is around a 1955 model.
    Wow!, You are good Lemko. It's a '54 GAZ M12 ZIM. Bet you didn't know that the M in ZIM (Zavod Imeni Molotova) is for Molotov as in Vyacheslav Molotov, the old Bolshevk who served as Stalin's Foreign Minister.
    qbrozenqbrozen Member Posts: 33,038
    edited January 2012
    Triumph engine, I believe.
    Ok... had to cheat a little to find out what Triumph had a straight 6 and flip up hood, cause I knew, of course, the spitfire didn't have a 6. I still don't know if this is the exact one, though: so how about the GT6?
    Triumph GT6?
    Once described as "the world's best worst car".
    He also has a cocktail named after him! :P
    Yup it's a 1968 Triumph GT6 Mk.I
    RE: GT6 --- Do Not Enter unless you are 5' 8" or less. You might need to call the Fire Dep't to get out.
    As in outrageous, but the press nicknamed it the "Diculous", as in ... well, you can guess.
    edited January 2012
    Now you know why there is no more Pontiac.
    When you do a concept car, the general public is supposed to go "WOW", not "WHA?"
    tjc78tjc78 Member Posts: 16,007
    Charger SRT8
    2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
    Raspberry. If it's for race use only, why's it on the street? :lemon:
    edited January 2012
    It comes in two other street legal flavors. The race kit flops 590 horses in there.
    And some states don't have safety or emissions inspections, if you get my drift.
    robr2robr2 Member Posts: 8,805
    Dodge Charger Redline.
    Supercharged Hemi with all kinds of Mopar back room goodies tacked on. About 600 HP IIRC.
    See it in Detroit.
    edited January 2012
    Yep, 590-HP 2012 Dodge Charger Redline (Inside Line).
    "The Redline is a Mopar-tuned Charger that will be available in three kits. Stage One gets you a Mopar carbon-fiber chin spoiler, carbon-fiber door scoops and a carbon-fiber rear spoiler on top of a Charger R/T. Stage Two gets you a cat-back exhaust, front strut-tower brace and high-performance brake linings. Stage Three is the fun one. Stage three drops in a 590-horsepower Gen III 426 Hemi V8 crate engine that is for "race/off-road use only." In unrelated news, states like Wyoming, Florida, Montana, Minnesota, parts of Nevada and South Dakota (that I know of) don't have any sort of safety or emissions testing. "
    At least it had some power to it. 5.7ltr V8 OHV. With the way the new hatchback crossovers are coming out (Honda Crosstour, Subaru XV, Audi Q5, Volvo C30, Infiniti EX) I think GM was ahead of their time with this in '97. You gotta admit, this thimg looked a hell of a lot better than the hAztek.
    Unlike Chrysler who only dropped a tiny v6 into the Prowler.
    This should be simple to identify both of them.
    Odie
    Parts of New Hampshire do not have emissions testing including Coos, Grafton, Carroll, Belknap, and Strafford counties. That's probably true of lots of states that have sparsely populated rural counties far from urbanized areas.
    Dodge Shelby GLH and Dodge Shelby Charger (rear) ca. mid 80s IIRC.
    edited January 2012
    Only Boise/Ada County in Idaho has emissions checks and no safety inspection anywhere. There's one stretch of interstate where 590 hp could be enjoyable. :shades:
    None of that stuff is near me now, but around here, you'd just hit a deer that much faster.
    Oh' Shel and the Dodge-KABOOM. :P
    fintailfintail Member Posts: 57,277
    I think all of WA state outside of metro areas is the same way, and no state inspections anywhere. Some interesting stuff on the roads here.
    The 2012 Charger CGI-8 on the streets of SimCity? :shades:
    I could have sworn that was the floor entrance to the RenCen in Detroit. :)
    Maybe it's Race Street in Philly?
    Parked on the street looks like a 1941 Chevrolet coupe and a 1953 Plymouth Cambridge.
    First three cars facing the sidewalk are a 1955 Chevrolet, 1949 Chevrolet, 1955 Oldsmobile, and 1953 Pontiac.
    wgraferwgrafer Member Posts: 592
    edited January 2012
    The Pontiac above the trunk of the '53 Plymouth looks like a '54 to me (cannot see too clearly,but looks like the signal light is in the trim, not below like on a '53).
    Behind that Pontiac looks like a '54 Dodge, a '48 Pontiac Streamliner, and a '53 Pontiac. I can't tell for sure if the nice Olds convertible behind the '49 Chevy is a '54, '55, or '56. I guess i need a new monitor.....
    GLH meant goes like ... uh, Heck, back then.
    One guy modified his and made it faster, he called it the GLMF!
    The GLH engine was...er...delicate...it was more like lighting a firecracker...you don't get too many chances.
    My Dad had a 86 Shelby Charger. As a kid it seemed like a pretty cool car. He wrecked it on the Jersey Turnpike and then replaced it with an 87 Shadow Coupe w/ the turbo 4 automatic. That car, not so cool.
