Mystery car pix
16406416436456461477
    The one on the right (as we are looking at the picture) is an Olds, I'm thinking about '63. I'm pretty sure about the second an third ones on the left, '63 and '57 Fords respectively. The one in front on the left looks like a Mercury Comet from about '62, but something makes me suspect that it is the short-lived mid-sized Mercury Meteor. I can't place the bronze one behind the '57 Ford as anything from that time period.
    I'll take a few guesses. 62 Mercury Meteor, 63 Ford, 57 Ford and maybe a 66 Olds. Can't make out the coral colored one.
  • kyfdxkyfdx Moderator Posts: 271,205
    I see Nicholson, Fonda and Hopper.. ;)
  • andys120andys120 Member Posts: 23,686
    edited March 2012
    IMCDB sez that the Merc is a '62 Comet, not a Meteor. I think they're right, the
    Meteor had a different rear fender>
    I'm pretty sure the Olds is a '65>
  • wgraferwgrafer Member Posts: 592
    Ah yes, Captain America.... but the Olds is a '64.....
  • jwilliams2jwilliams2 Member Posts: 910
    edited March 2012
    Looks like a Bristol 402 Cabriolet....from around 1950 or so...very few made...
    Yup, Wikipedia sez 23 402s were made. The 402 Cab was mechanically identical to the 401 Coupe (611 made.)
    In such exalted company that Fiesta does look a little out of place. THe Aston is either a DB4 or early DB5, and is the Ferrari a 275?
    Not sure about the older stuff - the wide car behind the Ferrari reminds me of an Alvis, but could be loads of other cars, while the saloon above theBristol's steering wheel could be a Jag - perhaps the immediate pre or post war model (retrospectively called the MkIV).
    I'll have a go at two - behind the bus on the far left is that a Corvair ?, and behind that is a 59 Chevrolet - but is it a sedan or something I've never seen like a pickup one - didn't they do a 59 ElCamino which was fitted with those oval lights and vestigial fins on the rear panel?
  • fintailfintail Member Posts: 58,792
    The car behind the bus looks like a 61 Chevy, and there was indeed a 59 El Camino with the oval lights and batwing fins.
    I'll also pick off the 65 Ford with the white top, which I assume is an LTD.
    You know, my first thought was that the Ford might be a '66 but those had taillights that are similar but wider and more nearly square. I don't know if there was an LTD in '65.
    I think the white car behind the bus is a full size '61 Chevy, it looks too big for a Corvair.
    edited March 2012
    65 was first year for the LTD, and they are relatively uncommon. I don't know if a white vinyl top would be usually seen on a Galaxie HT, but was normal for the higher model.
    I generally think the 66 Ford looks better than 65, the subtle curves helped.
    I'll pick off the '63 Impala in front of the Ford.
    Behind the '59 Chevy ElCamino and in front of the '63 Impala is a '65 Dodge Coronet. Also, I spy a '65 Ford wagon on the right (in front of what I would suspect is a '63 Chevy) and in front of the '65 Ford wagon I spy a '61 Buick!!
    And I guess nobody yet mentioned the ubiquitous VW KarmanGhia behind the '63 Impala....
  • explorerx4explorerx4 Member Posts: 21,047
    '64 Chevy is behind the Ford wagon.
  • lostwrench1lostwrench1 Member Posts: 1,165
    I'll grab the city - Boston.
    Any guesses on the partially shown car behind the Karmann-Ghia? I can't get it.
    I'll guess the last car is a '65 GM 4-dr hardtop, most likely a Chevy Impala, but the antenna should be up front...
    Explorerx4-you're right - it's a '64 Chevy now that I see the rear lights through the windows of the '65 GM.
    Also, in the distance I see a '65 Dodge full-size (Polara?) and a '64 Pontiac.
    ps: Isn't McCormick Place in Chicago????
    I agree with the 65 Impala. Some of them had the antenna(nae) on the back.
    You are correct on the city's being Chicago. I based the city as being Boston because of the Prudential Building and Boston's John McCormack.
    I was thinking that car might be smaller than an Impala, perhaps a Chevelle 4 door HT, or one of the rebadges?
    Oh, the humanity!
    I'll pick off the 60 Ford in the middle.
    Yellow 47 Chevy Fleetline.
    The rear window's chrome on the top left being rounded and the bottom left being "squared off" would indicate Impala.
    Top right - 54 Chevy.
    Just to the right and above the '60 Ford is a '58 Chevy (Biscayne or 210) sitting atop a '60 Thunderbird..
  • jlindhjlindh Member Posts: 282
    BMW 507 coupe.
    BMW 507 coupe
    Nope, sorry, AFAIK there was no 507 Coupe.
  • texasestexases Member Posts: 11,187
    edited March 2012
    That's what I thought, too, but looks like some removeable hardtops were made (no coupes, you're right):
    The sleek nose does bear a resemblance to the beautifully crafted nose of the 507.
    Perhaps some clues would help.
    MY is 1961; it is Powered by and Inline Six from Fiat. Body is by Michelotti on a Fiat chassis. Going...going
    I just can't let this one pass. I'll take the NEWEST - the brown '63 Impala on top of the '62 Ford and next to the '59 Oldsmobile and above the 2 '57 Chevys near the '63 Cadillac under the '60 Ford .......
    In return, the '60 Bird is sitting on a red '60 Falcon. Lots of memories brought back. I had one that year and color. Eighty-five snorting horses and a two-speed Ford-o-matic. That car taught me to enjoy scenery (unless it was going uphill, in which case it taught me to enjoy a good book.)
  • grahampetersgrahampeters Member Posts: 1,786
    edited March 2012
    G'day
    Gee, these are getting hard, You must be working through every small coachbuilder in Turin who ever bent a Fiat to a different shape:
    1961 Moretti 2500SS
    Took me ages to search for it. I have not been able to find out a lot, beyond its origins which are off a Fiat 2300. Moretti was better known for variations on the Fiat 850
    I found the following link; got to love the fashions of the early '60's
    http://bprint69.home.xs4all.nl/fiat/en-us/pg_28.html
    Somewhere I have a book of English kit cars of the 1960's. It is tempting to drag some of these (mostly very ugly) pictures out to see if I can exact revenge!
    Cheers
    Graham
    That Moretti must have been influenced by the sharknose Ferrari Grand Prix cars which were new that year....
    G'day
    There are a couple here that you have not covered yet
    Abarth, corso Marche
    Bertone, Corso Allamano
    Coriasco, via Salbertrand
    Moretti, Via Monginevro
    OSI, Via Agostino da Montefeltro
    Pininfarina, corso Trapani
    Pininfarina, Via Pininfarina
    Viotti, corso Stupinigi
    If you can find an image of the OSI Ford Taunus, I'd love to seen it.
    Cheers
    Graham
    Well, that red Falcon has me confused. The 'flying falcon' trim on the side says 1961, but the bumper seems wrong.....
    Anyone have any idea what the white 'foreigner' is in the lower right corner under the '59 Chevy wagon????
    edited March 2012
    Yup, that's a '61 Moretti 250SS, essentially a re-bodied Fiat 2300 with an up-rated engine. It's true that not many were made but back in 1966 when I was attending law school in Washington DC I saw one being driven regularly.
    This particular Moretti was light blue metallic and wore diplomatic plates. It belonged to someone in my apartment building and it was very good-looking.
    I'll go with the Falcon's being a 62 because of the ends of the bumper and the verticals of the grille.
    There is a 57 Dodge buried at the bottom.
    I think you're right. The front signals in the bumper give it away. So let me take another try. I think the car sitting on its back bumper just to the left of center is a '61 - '63 Rambler American.
    We've had no takers for the pretty red coupe in #32741 so here's a hint:
    that's not Italian running gear beneath that slinky Italian coachwork.
    Here's another angle>
    And here's the even prettier Spider version>
    Paging Grahampeters. ;)
    OSI - but underneath its a Ford Taunus 20M...
    edited April 2012
    Yup, it's the OSI Ford Taunus 20M from the late 60s that Graham was looking for. I must admit I'd never heard of it or OSI before and I haven't been able to find much on it.
    The standard Taunus 20M was nothing special to look at>
    Here's a charming bit of brochure art for the OSI version>
    Jalopnik called it "the most beautiful Ford in the world". About 200 were built.
    That is sharp!
    G'day
    Gee, that spider is gorgeous! Could I have one in my Christmas Stocking, please?
    Cheers
    Graham
