Mystery car pix
16946956976997001421
    kyfdxkyfdx Moderator Posts: 237,773
    Starions are uber-rare in the US, so I think it's probably a Conquest...
    andys120andys120 Member Posts: 23,395
    Actually it's a 1987 Chrysler Conquest. According to the Wikipedia. Dodge, Plymouth ahd Chrysler all used "Conquest" to name their versions. :confuse:
    Don't remember seeing anything but Chrysler. Maybe the others were Canadian models?
    odie6lodie6l Member Posts: 1,173
    The most famous version is that of Jackie Chan's in Cannonball Run. I think they also used it in the style of the Cartoon version of the Gadgetmobile.
    Odie
    Never saw a Chrysler version.
    Was in high school when those came out and I like them.
    Dodge Mirada?
    Odie
    fintailfintail Member Posts: 57,185
    Go gadget go!
    Dodge Mirada?
    Sorry no, but obviously a close relative.
    stickguystickguy Member Posts: 50,580
    Chrysler imperial?
    Yup, it's a 1981 Chrysler Imperial, but not just any Chrysler Imperial, it's a "Frank Sinatra Edition" :confuse: .
    andre1969andre1969 Member Posts: 25,690
    1972 Chevy Impala convertible. One of many 70's battlecruisers that I've had a lusting for from time to time. Also, the last year that the convertible was in the Impala series, as they moved it to the Caprice line for '73-75.
    If I bought one though, I don't think red would be my first choice.
    I'd love to own one of those big convertibles.
    lostwrench1lostwrench1 Member Posts: 1,165
    I had a 73 Pontiac Catalina batttlecruiser. 400 cubes. What a ride!
    Yup, it's a '72 Impala. I too have a soft spot for those big convertibles but they're just too big to mess with on today's crowded roads, and then there's the gas mileage. :surprise:
    last week I was driving a Chrysler 300G convertible---talk about BIG---we couldn't even find a lift that it would fit on!! Parking in a 'slot'? Forget that. And those 2 big 4bbl carbs sucking gas. What a ride, though. You park that next to *anything* and the other car immediately disappears.
    tjc78tjc78 Member Posts: 15,946
    The G isn't that big. Looked it up and found 219in. My 79 Continental was 233 in. :surprise:
    2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
    I wonder if the 300G weighs more? Also, 18 years of product development between the 2 cars can certainly be felt in brakes and steering.
    From the same sources the G weighs in at 4430, the Lincoln shows a range of 4900-5500 lbs.
    If you consider my "mid size " 2012 LaCrosse tips the scale at over 4000 the old boats aren't that bad.
    My guess is the biggest difference would be the tires and steering wheel. Those old cars had big steering wheels, to compensate for versions that lacked power steering. No matter how well a car handles, an oversized steering wheel just makes it feel sloppy.
    As for tires, according to cokertire.com, a 300G came with 8.00-15 bias ply tires standard, and 8.20-15 optional. I'm sure that had to hurt handling, although sometimes, putting radial tires on a car originally designed for bias ply isn't always the magic bullet many people think it is. It can vary from car to car.
    But, fast forward to 1979, and steering wheels were much smaller, ratios were quicker, and a '79 Lincoln was running around on 15" radials. Cokertire.com lists the original size as "LR78-15", which I don't know how to relate to modern terms. The (presumingly) original spare in my '76 LeMans says "FR78-15" on it, so I wonder how the two would relate, size-wise? You'd think a ~5,000 lb Lincoln would take a bigger tire than a ~4,000 lb LeMans. Maybe that's where the "L" versus "R" comes into play?
    I'd imagine that if you were going for relatively stock tires on a '79 Lincoln, you'd probably get a 225/75/R15, or even a 235?
    blh7068blh7068 Member Posts: 375
    My dad had a 71...orange with a black interior...4 speed and a 1600 cc motor.
    qbrozenqbrozen Member Posts: 32,963
    Falcon... but trying to pin the year... early '60s... its like a '62 hood... but the grille.... hmmmm
    uplanderguyuplanderguy Member Posts: 16,116
    edited January 2013
    '63 Falcon Sprint...first year for a two-door hardtop and first year for a V8 Falcon.
    That's a pretty big spear going down the side of the car! ;)
    Sprints actually ran in the Monte Carlo Rallye!
    I had forgotten that the Falcon was that late in adding a hardtop to the lineup. I think the Valiant/Lancer added one for 1961, and of course the Studebaker Lark had one from the get-go in 1959.
    Didn't the Chevy II have a hardtop from the very beginning, in 1962? I wonder if that's what put pressure on Ford to add a hardtop to the Falcon?
    edited January 2013
    Hmmm... a little confusion about the nomenclature here. The seller advertises this car as simply a "Ford Falcon Futura" but Wikipedia confirms that you are correct, the 260V8-powered Sprint model was introduced in 1963. The bucket seat Futura version was introduced in '61, the second year of the Falcon.
    IIRC the original name for this model was Ford Falcon Futura Sprint.
    edited January 2013
    Chevy II had a hardtop in '62, and I'm pretty sure they also had a convertible in '62...my in-laws (now divorced) had a choice of a cheaper model full-size Chevy or Chevy II Nova convertible as a wedding gift and chose the Chevy II...a robin's egg turquoise per my mother-in-law. They were married in '62 and their gift from the groom's parents was a new car.
    Falcon got its first convertible in '63, also. Chevy II, and Dart and Valiant, got their first V8's for '64. The Rambler American didn't get a V8 until later, and the mid-sized Classic only got a V8 in mid'63. There wasn't a hardtop Rambler Classic until '64.
    I really wanted one of those for my first car back in the 90s - I knew of one in town, owned by a nice old guy who was talkative about it, but wouldn't sell it - was "saving it" for his adult son who couldn't care less about the car. Then the old guy passed on and the property was emptied out overnight. It was a cool car, 260, red on red, very solid condition - I wonder what became of it.
    robr2robr2 Member Posts: 8,805
    It's a Shelby Mustang - year and what particular version, I don't know.
    69 or 70---can't tell from the photo.
    I will guess 1968
    Wouldn't 1968 or later have side marker lights? Or was Shelby exempt from those somehow?
    edited January 2013
    definitely not '68 taillights.
    And shouldn't it say SHELBY across the back? Something seems really wrong here to me.
    edited January 2013
    Boy, I didn't think it would be that hard but the green car is a 1967 Shelby (Mustang) GT-350. IMHO it may be the best looking Mustang ever (the "Eleanors" were patterned after it (mostly).
    Here it is from the front>
    The misaligned (fiberglass) hood was typical, the extra lights in the corners of the grille were not, these were usually twinned in the center of the hood in the '67s.
    edited January 2013
    That is a '67--no side marker lights, but more importantly, it's the '67-68 bodystyle and not the new '69-70.
    Oops, now I see the poster had to identify it!
    huh. OK. I found more pics and they do all look like that. Really thought '67 would have still had the '65-'66 taillights, and I definitely thought it said shelby on the back.
    Yep, the side marker lights are a good way to tell a '68 from a '67 Shelby Mustang. Another is the placement of the hood scoops and the more rectangular auxiliary lights in place of the round ones in the '67.
    There's a shiny metal surround on the '68 tailights which the '67 doesn't have.
    Oh, and there were no convertibles in '67 (what a shame).
    explorerx4explorerx4 Member Posts: 19,340
    edited January 2013
    but where was it built?
    2023 Ford Explorer ST, 91 Mustang GT vert
    It's a Rolls 20/25 (plate helps ;) ), "where was it built" is a fun question. I see it is RHD, I don't know if a Springfield built car would be RHD, and the body is later than Springfield production.
    That picture was taken last September and I didn't look at it very closely, but I thought we had a picture of a Springfield Rolls and that is definitely not it!
    although odd color choice for the brand ;)
    Springfield production ended in 1930, I think. That car is probably 1935-39. But, RRs were often rebodied. It would be cool in a way to have a US built Rolls.
    A friend of mine, who is a collector, once had a US made Rolls..
    edited January 2013
    That's the car that comes to mind when I hear the word "Ferrari", it's a late 50s/early 60s 250GT Short Wheelbase Berlinetta.
    Ferraris don't have to be red, Stirling Moss won a race at Goodwood in 1960 driving a dark blue SWB, while listening to the radio.
    That looks like a prewar BMW 327 or 328 Coupe but it could be a postwar replica made by the Eisenach Motoren Werkes (EMW) which was formed by the Communist regime of East Germany. EMW was later merged into the IFA/Sachsenring consortium which made Wartburgs and Trabants among other things.
    The EMW emblem looks like a BMW roundel with red in place of the blue and I believe that's what I spy on the nose of the pictured car..
