Visitor Agreement.
I have the 01 F250 SC. The recall was about the front outboard belts. It said that when the belt is buckled in a slow manner, the red button wouldn't pop back out all the way indicating a complete catch. I haven't tested mine (I buckle too fast I guess.) I have the seats where the belt is in the seat instead of hanging from the ceiling (a mid-2001 change.) Maybe only these are affected?
"Seat belt tongues that are not inserted into the buckle firmly may not latch properly. Owners will be notified by mail with letters sent between 7/25/01 and 7/27/01. "
"Drivers can help assure that the seat belt is buckled properly by firmly and rapidly pushing the tongue into the buckle and then wiggling it to confirm a solid latch. Drivers
should also check visually to ensure that the seat belt buckle release button has returned to its full up position. The recall affects both the front driver's seat and outboard front passenger's seat."
The inspection procedure will involve the use of a special dealership tool developed to identify potentially defective buckles. Actual defect rate is believed to be less than 5%."
I've noticed mine opened up once in a while, but I've usually had a bunch of junk on seat (bench) next to me. Thought that I leaned going through a turn or something and pushed release on the seat belt somehow. Guess I'll be going in for service sooner than I thought.
(By the way lilelmo do you use Akins?)
They have mine again! Actually I should say still.
They have tightened the cab bolts twice... still pops.
They have replaced spring isolators twice...still squeaks.
When they "fixed" that they made the front end pop when turned to the right, they replaced the entire drag link set up, spindal to spindal. At least I got a free alignment.
Then I tried to pick it up for the third time and the cab still pops.
About a year ago they fixed the clicking transfer case, this happens when you shift from drive to reverse. It took about 6 weeks for them to get the part (that reads lock-tite) that Ford recommended. It now has a strong vibration from 78 until 85 mph. I have asked them over and over to fix it but they keep telling me this is not a problem, its normal on our trucks. I have finally put my foot down and said it wasn't this way til you "fixed it", I will not accept it back until its fixed right. I told them this is there 4 th time and if I need to I will let them keep it. They know what I mean now. I even got a friendly call from the shop manager.
Anybody else have Ford to tell you this was normal?
The best part, if there is, is that Akins gives you a free loaner car. I've had a 2000 F150, 2000 Taurus, 2001 Ram 1500, currently driving 2001 Escape.
See ya,
Jim
about that?? I have a 2001 also, but only have 600 miles on it right now. If I paid this much
for a truck and this happens to me I will not be a happy camper. And in fact, you should
somehow be compensated by Ford for your troubles. Good Luck.
With my 00' F250 Superduty (5sp), I hardly ever use 1st anyway because its really a creeper gear meant to get heavy loads moving. However, if I want to shift into 1st or R from a dead stop, I can simply put it into 2nd, then goto 1st or R and it works every time.. It's just a habit I do everytime before shifting into R to shift into 2nd and then goto R.
I think the tranny in the F150 is different from the Superduty, so I'm not sure if my experience is relavent to your issue or not. But I thought I'd share it anyway.. Have you tried this method?
I have had the truck to the dealer 4 times. First time light was not on, but the night I brought it home the engine bounced rpm's between 2000 and 500ish then stalled. after the first few days it did this again on several occasions, stalling a few more times but sometimes pulling out of the problem ok. The fix as ststed on the work invoice..."remove and re-install cam-synchronizer 180deg at proper timing.
After this was corrected, the light has not stayed off for more than 30 miles out of the dealership yet it runs fine. Since the first fix, they have replaced the PCM and cam stator assy. Still showing light since this service on Aug 29. I have not yet sheduled a new appt. but I will be taking it back when I have the time.
Any comments on a cause, I'm sure the dealer service need a clue.
its a little maddening grrrrrr help please
thanks for any help
matt
Things like option codes, HP ratings, towing capabilities etc.
Also, links to performance mods and accesorizing.
Keith
http://www.f150online.com
http://www.F150world.com
They both have forums sections where you can ask
There is no setting to disable this feature..
LAST WEEK, I WAS IN A HEAD-ON COLLISION AND WAS SENT INTO A TELEPHONE POLE AT APPROX 25 MPH.WITH THE COMBINATION OF RECALLED SEATBELTS AND THE FACT THAT THE AIRBAGS DID NOT DEPLOY, MY WIFE AND I WERE INJURED, BUT LUCKY TO BE ALIVE.
I CONTACTED FORD TO FIND OUT WHY MY $31,000.00 TRUCK, WHICH I BOUGHT FOR IT'S SAFETY RATINGS, IN MY OPINION, DID NOT FUNCTION PROPERLY.
FORD TOLD ME THAT I SHOULD BRING THE AIRBAG SENSORS TO A FORD DEALER AND, AT MY EXPENSE, WILL TEST THE SENSORS AND TELL ME IF THEY ARE RESPONDING PROPERLY.WHAT DO YOU THINK THEY WOULD SAY? NO, THEY DIDN'T WORK CORRECTLY,PLEASE SUE US?
I'VE OWNED FORD TRUCKS FOR THE PAST 15 YEARS, BUT I WILL NEVER BUY ONE AGAIN.
Good Luck...
I was planning on getting this year has turned into a Tundra (forgive me guy's but I'm way to PO'd at Ford).
Ford recently gave the Audubon Society five million dollars. Audubon and The Nature Conservancy, funded the infamous "Wildlands Project" promoted by Earth First! founder Dave Foreman, and Dr. Reed F. Noss. This plan seeks to convert "at least half" of the lower 48 states to "core wilderness areas" which are off-limits to humans, and surround those areas with "buffer zones" managed by government for "conservation" objectives.
This plan, consistent with the unratified Convention on Biological Diversity, became a high priority for the Clinton-Gore administration's Ecosystem Management Policy. These policies have shut down logging, mining and ranching operations across the west, and continue to threaten the livelihood of farmers and rural people across the country.
Rural people are among Ford's strongest and, heretofore, most loyal customers. Young Bill has completely ignored this customer base and, instead, turned to his Ivy-League, soccer-mom, SUV-driving environmentalist buddies for advice. He is betting that they outnumber and can outspend the working-class, pick-up-driving common folks. The jury is still out.
My question: Where are we going to live and grow our food when the greens take our land from us?
I do a lot of volunteer work with both Audubon and Nature Conservancy and have never seen them "take" anyone's land. If TNC determines that a particular piece of property has something that is worth preserving then TNC will work with landowners to either buy their land at full market value or have a conservation easement put on the land which in return for a tax break the owner agrees to some level of non-development, the more strict the easement the higher the tax break. Logging, farming, and even house building are allowed under an easement depending on how it is written.
Wilderness areas does not mean that it's off-limits to humans just off-limits to motorized vehicles/equipment. That means you park your pickup and walk in (and leave the chain saw in the cab
It's probably better to take this topic off the board and not waste bandwidth of folks that want to know about problems with their pickups. If you want to flame/slam me you're welcome to blast me an email at fjr69@hotmail.com
As far as a pickup problem my 2001 F350 has a strange problem with cruise control. When I'm going up/down a hill you can feel the truck speed up/slow down. It's especially noticeable going down hill. If it's a long enough hill it almost makes ya sick it's so jerky. I took it in to the Ford dealer where they replaced a brake spring that had broken which fixed the problem I had with it just shutting off after hitting a bump but that didn't fix this problem.
Frank
Just playing around with numbers..
Customer is looking to buy a truck. Their choices are a used truck that the dealer is selling for around 18,300 (figure 1k dealer markup for profit). But the 0% and low interest rates don't apply to that truck.. Payment for 3 years @ 7% $565
Or they can buy a brand new 2002 truck for 22k with 0% interest for 3 years, payments: $611
Will people buy the used truck, or for $50 more a month buy the brand new one? To really start to even things up, what would it cost to add an extra year of warranty to the used truck?
owned a 1991 Dodge Dakota and went through almost the same kind of situation,I hope you were able to resolve your problems,I have felt your kind of pain!!!!I have owned a TOYOTA since i dumped that P.O.S. Dodge.
The ford dealer said that the cam bearings are bad and that the motor could not be repaired. I would need a new motor. come to find out ford had a recall on the trucks but my ford was not covered
under the recall because it was not made in the same plant as the recall was on.
Water from the cooling system has leak threw the wall and on to the lower cam in turn freez up the motor after a while. This is known to Ford and motors have been replace in most of the trucks.
Can any one tell me what I can do before I send it back to the bank and my credit will no longer be any good. I need help please.
I have had similar experiences with factory recalls. I used to own a 1987 GMC truck. I didn't buy it new, but I bought it from the local dealer in 87 with only 4,000 miles on it. I always garage my vehicles and keep them waxed, the paint started coming off before the truck was two years old. If you remember, GM did a recall. Guess what, mine wasn't part of it. The recall specified a certain date, which was the build date for the trucks at the beginning of the recall period. My truck, being a very late 87 model, was built after that beginning build date. I was told, by the dealers in the area, that since my truck was the old body style, mine wasn't included. Factories do this all the time, for the cost of a paint job, they could have kept me as a loyal customer. Instead, now I own all Fords and would NEVER consider a GM product.
I agree with mullins87. Don't let your credit be ruined because of a blown engine and lose an otherwise good truck to boot. If you can't do the work yourself and know a good independent mechanic see what they can do for you. Some engine rebuilders will provide you a rebuilt and do the install themselves. You didn't say what engine you have, but if it has inherent problems I would also consider changing to another that doesn't.
How the key fob's are programmed is:
a. have all of the fob's that you want to program with you (up to 4)
b. put the key in the ignition
c. cycle it 6 (or 8) times from the off to the run, back to off position. Do this within 10 seconds.
The door locks will lock/unlock to indicate that it's in 'program' mode.
Leave the key in the run position.
d. press a button each of the fobs.
e. turn the key to the 'off' position. programming is complete..
My guess is that if you have keyless, you'll know it at step c. when the locks cycle.. in your case you don't have any fob's to program..
I really like this programming feature because I use the same fob for my superduty and escape.
