Honda Accord 2007 Maintenance and Repair
Besides, the engine feels just like my old 95 accord. It is noisy than I thought for a new car.
Somehow, I feel this is 10 year old car with new paint. I drove my friend 2002 accord and 2003 camry. They both feel much smooth and quite.
Did I get a :lemon: ?
I am even thinking of trading this 1 month new car.
I would think every new Accord would feel the same as what you got unless you have a legitimate issue which you should check at your dealer.
You didn't notice during your test drive?
Replacing to a Tire designed for a smoother ride would be my recommendation. And if you have 16 inch rims then perhaps down sizing to 15 inch rims may help a little also.
Mrbill
I am very much in your position. I have a 1996 Accord (same as 1995) with 173k miles on it, as well as a 2006 Accord EX (currently 21k miles).
The '96 rides a little softer, and I feel a lot of this is due to the shocks being much older (they are originals). The handling of my new car is MUCH better however.
I have to ask though, why did you buy this car if you feel it rode badly? Insufficient test drive? The Camry has always been a softer-riding and quieter car than the Accord (sort-of Buick-like), with the Accord being much more sporty and fun to drive.
I also second the notion of making sure your tire pressure is 32-35 PSI or so. Much higher, and your car will ride rougher.
Dealer said that is normal for accord, but I did not hear any buzzes from a 2007 rental accord from enterprise.
any clues?
Both front windows make a grinding noise on the way up. But I could only reproduce this problem when car is parked outside under the sun and outdoor temperature is high enough (above 85 degree fahrenheit).
Any suggestion?
After we signed all the paperwork, the dealer washed the car and filled the gas. Then we found 2 adjacent small dents (1.5mm in diameter for each) on the hood and they are very visible when you stand by the hood. They feel like dents with hand, and the color is black (the car is silver).
The dealer promised to fix it for free but we were still quite upset. It seemed we spent hours to buy a brand new car that need to be fixed.
Now my question is: if the dealer's body shop fix the problem so that the dents are no longer visible for now, will the paint in the fixed area last as well as the other non-touched area? How can I protect myself from problems rising from the repainting area for the next 10 years? (that's how long I'm planning to keep the car) Thank you so much for your inputs!
Paint is missing (damaged) over the two dents, and that's why they are black. So for me, it doesn't look like something hit the hood, but only defects in painting.
The dealer wrote "fix scratch on right side hood" on a form called "get-ready authorization", but didn't indicate how the body shop will fix it.
It was a really big Honda dealer (maybe the biggest in N. CA), so I tend to believe that they didn't cheat on purpose.
Since the dents are small and we had signed everything before we found out, we didn't expected to get another car. But maybe I can try.
Any suggestion is appreciated!
Does dealer have to tear apart the doors to fix this problem? How difficult will be?
I will make appointment with my dealer to correct this problem.
Once the problem is fixed, I will report the status here.
That would be nice.
However the sound coming from this part is considerably louder in my car than in my friend's car, to the point where I am afraid that there is something wrong with this part in MY car.
Take it to an independent shop and have the dealer pay for it.
It depends on the dealership. My local dealer's body shop has been around for a long time. They are as good as any other shop in the area.
Thanks for your inputs!
Let me know how you make out with the grinding noise problem. I was going to wait until the 1st oil change to have mine looked into, but may bring it in before then. Since it is both my rear windows, I rarely ever use them. But might was well get this fixed.
What is that peice? That looks like a rubber hose...
I went to high school with one of the mechanics at my local Honda dealer, and he's given me objective advice so far. I'll ask him what he thinks, if we do indeed have the same noise. It doesn't sound like something to worry about to me, but I'd still like to know... you know?
Not 100% sure why a sound coming from a little hose would be louder in your car than your friend's, but it should be easy enough to pop off that hose and make sure it is clean inside. It looks to be in clean and good shape but could also be the hose has a pinhole or something, because other than a hole or a crack a hose is not going to make a whole lot of noise.
If you're not talking about the hose, but the part underneath it, please identify the part. What did your dealer say it is? If you don't know, can you check it out for a part number and post it here? Then maybe we can advise. Also please describe the noise a little.
The hose has the following number printed on top: AGE-ECO-6X03.
It's Frankenhonda's monster.
Thanks :confuse:
I am going to see other dealer this Friday to find out what is going on with this noise. Hopefully, I could meet a more skillful mechanic. Once the problem is corrected, I will post here.
Minor damage like this is repaired all the time before a vehicle is delivered. Vehicles do get damaged in transit and they do get repaired without disclosure. Every state has a threshold amount that must be exceeded before it has to be disclosed.
If these small dents on the hood had been repaired before delivery, you probably would never had known about the repair. Repair techniques are so good today you'll probably never notice it.
Good luck with your new car.
We are going to drop the car to the dealer, and according to them, it will be repaired somewhere else. I'm not sure whether that indicates we won't have top-notch 3rd-party body shop to do the repair for us.
It probably means that they don't have a bodyshop and they send it off site.
