The starter works fine. I can hear the normal ti-ti-ti-ti sound but the engine doesn't start up. I have to turn the key position off and turn on to start again for couple minutes and finally get it start. During the process, I didn't step on the gas paddle because I thought too much gas would make the sparking plug "too wet" and the situation worse.
Do you think this is due to sparking plug, the fuel supply system, or anything else? I know I can drive it back to be checked but I'm sure it would be normal when it sits in the dealership. Just like to hear comments from you before driving back to them.
By the way, I follow all the guideline on the owner's handbook so far. Thanks for any suggestion.
The old give it some gas prior to start does not work any more since the computer controls all fuel mixtures etc.
Could also be bad gas, re formula for winter of who knows.
Is it getting colder where you are?
If no go, I am afraid you will have to leave it over night at a dealer so the problem can be reproduced (maybe)....Then of course it will not happen...these things have eyes!
Temperature isn't that low in Vancouver's Autumn. It was about 20C something with direct sunshine when I was at the beach yesterday afternoon and encountered the engine start-up problem. The gas was the first tank from the dealership. Maybe I should drive to Seattle and burn out the gas then get refuel.
I will wait a bit longer next time to start the engine after the computer get ready. I'll keep updating this issue here. Thanks for your comment.
No, there's only 230Km on it after driving safely this morning to my office.
I plan to change oil the first time when it hits 800Km. I always treat my new car this way.
I will add new tank of gas to it after burning out the original "complimentary gas" and see if the situation is still there.
Just as with your engine oil, it's 3,000 miles or 3 months, whichever comes first... It's not a one-or-the-other kinda deal.
12346932...
If you were to use the same logic as you are using for your timing belt replacement interval... "If I use the 60,000 miles instead of the 48 months" for your oil change interval... 'Well I think I'll take the 3,000 miles rather than the 3 months'. You just can't think like that my friend. What if you use your car as a grocery getter (the manufacturer doesn't know how your vehicle will be used) and you only clock 200 miles a month. Does this mean that you would only change your engine oil every 15 months? Or, similarly, if you put on 3,000 miles a month. This does not mean that you can opt for the 3 month change interval at 9,000 miles.
Take the drive train warranty for example. It's 100,000 miles or 10 years, whichever comes first. You can't expect Hyundai to honor the warranty if your car is just 8 years old with 150,000 miles on the clock. Conversley, if your car was 20 years old with just 60,000 miles, would you really expect Hyundai to fix a drive train prob under warranty on a 20 year old vehicle? Not!
Follow Hyundai's maintenance schedule my friend. You'll be kicking yourself in the butt if your belt snaps and Hyundai says... "We're sorry, but you didn't follow the service schedule, you warranty is VOID!"
Why risk trashing your valves and a very costly repair, for the sake of a $500 timing belt replacement... :confuse:
Bambew
to repair the latch to adjust the back of the
2nd row of seats. Dealer had to "outsource" the
work to a local body and trim shop. After having
it for 2 days they now found out the parts that
were ordered were incorrect. Apparently, this
is a big job with taking the seats out and
more. Anyone else have this issue?
You are better off just letting it shut off by itself. Mopst of the new ones (if not all) have a "bladder type" of affair that can ruin the assembly if the bladder is overfilled. I think yopur manual even states do not overfill. ASlso gas needs expansion room if it should be hot outside! Warranty warranty warranty!!!!
Never checked exactly on mine but I do recall there is a little "slack" between what the gauge says vs the actual amount in the tank. (emission system??/).
I do remember that the needle does go into the full red mark though. Hint: try to have the SF on a flat surface when filling though
I would check with another dealer 1st though about what they would do...something just sounds strange there. At the very least, I would make sure their work ticket that you get a copy of stating ("outsourced" part by dealer) from the dealer.
If anyone follows my posts...I never give a dealer/auto company any room to squiggle out of a new car warranty!
Argument....you have an accident, the part is founf not to be Hyundai and is blamed for an injury to someone and you get sued? remopte but anything is possib le today!
joncar, "Honda CR-V Real World MPG" #560, 4 Oct 2007 8:17 am
3-4 gals is way too much to be off IMHO. 1/2 to one gals I could understand. My $$ would go on pump 1's mechanism being off!
EDIT: Just noticed the other reply as I said also a bit of slack is normal but still think that 3-4 gals is a lot. My last 2 vehicles (2005 Honda and 2004 Mini Cooper would shut off at About the point where the needle got it to the red zone...AND THE OTHER POSTER IS 100% CORRECT...THAT PUMP MUST STAY COOL!
NOT a single Hitch (pun =intended
DRAWTIGHT hitch from Etrailers.com =$120 (+ I GOT A FEW OTHER THINGS (new Ball, receiver + lock pin etc) TO TAKE ADVANTAGE OF THE 99 CENT FGT AT $150 in purchases...hard to beat in light of the price hyundai charges
It is heavy and i used a small jack + 2 stands and a 2x4 to position it for easy mounting of the 4 pre drilled holes.
I shelled out the $81 for the plug and play harness which took about 15 min (mostly to properly route the cables)You need small hands....(forget the crimp on job IMHO)
Reminder: there are 2 caps on the existing pre wired plugs that must be removed prior to pluging in the hyundai harness...harness was expensive, but you save all that labor taking out the back panels in the SF ($35 cost of the connector from etrailers version and there can be no BS on a warranty claim from Hyundai...Recommended on the hitch/harness and Vendor www.etrailers.com (very helpful on the phon e too!)
Bill
Just my thoughts....but don't even think about the Etrailer kit...It seems good, seems easy to install....but getting inside the inner INTERIOR panels that must be removed, seems like a PIA...still MUCH better than the Hyundai crimp on THOUGH....For the extra $$ you have simplicity, no possibility of fumes, and no possible warranty BS from the dealer or Hyundai!!!! TRUST ME...THE XTRA $$ IS WELL SPENT!
The connectors you want are a pair of very odd looking roundish plugs that are attached on the driver's side under the REAR fender well ) they are there just keep looking "> Z(assuming that yours has them (The "discovering" poster (kdahlquist said they all did) It is easier to lie on your back WITH A FLASHLIGHT and look up while under the fender.They are on the inner side of the fender well, (chassis side) and fairly close to the driver's side muffler If I recall the manual has them pictured wrong. THEY ARE PRETTY THICK WIRE LOOMS AND CONNECTORS TOO and exit the chassis via a pretty thick rubber type boot.
The word on this thread from kdahlquist, was that all 07's had the pre-wiring...I do know for sure that the touring pkg equipped ones have the prewiring.
PART NUMBER!!! A quote from kdahlquist original post with the correct part number since most dealers still do not know the harness is available by itself.
"Hyundai has finally released a plug-in trailer wiring harness for the 07 Santa Fe. It is part number U8612-2B000. It's so new that my dealer didn't know it existed, and tried to tell me it didn't. They wanted to sell me part number U8614-2B000, which requires splicing. I told them to check with Hyundai, which they did, and surprise! I was right. The computer showed it in-stock in the warehouse, so I should have it in a few days. Retail price is $81.61."
JEFF
Mine has the towing pkg so the wiring should be there.I fully agree with the PIA.I will pursue the Hyundai kit.
Bill
As far as do they require you get those bogus 10-15k inspections etc. Also the timing chain/belt inspection or replacement requirements intervals? I mean all these inspections cost big money for really nothing. ie check belts/hoses fluids... Also I read they require you get your oil changed every 3000 miles, I would rather not have to go through that and use Mobil 1 in my current cars to keep them going strong. If you went over 3000 miles etc would they just ignore your warranties?
I just wondered if anyone looked into these types of things? I would probally have to get what they have in writing. It may even stop me from purchasing if it gets too out of hand.
As far as changing or inspecting a timing chain give me a break with the 60,000 mile service. That just doesnt sound right to me. I have 2 toyotas that have not had their belt changed till 100k.
DISCLAIMER: The following are strictly my own personal beliefs...I have been around since the old DAYS..and now transitioned to the newer school...STILL DOES NOT LET ME BELIEVE THAT 10-15000 MILE OIL CHANGES ARE A GOOD THING eITHER! (like the BMW/ MINI Cooper) lOOK AT THE FINE PRINT ON TOYOTA, HONDA AND THE REST...PRETTY MUCH THE SAME!
Oil changes are good insurance if you plan to keep he car! as are good quality fluids and filters NOT FRAM!@!!
1st in reality, Mobile one is not a PURE Synthetic but is Dino Based,( THERE ARE DIFFERENT TIERS OF OIL THOUGH!!!...THE GOOD STUFF IS German Castroil AND Amsoil ( Both great for high performance engines!!!)(BIG LAWSUIT OVER THAT ONE A FEW YEARS AGO! and does not contrary to popular belief and marketing hype give you longer change intervals.
THE REALLY GOOD STUFF DOES PROVIDE BETTER SERVICE AND LIFE BREAKDOWN OF OIL COMPONMENTS THOUGH...REMEMBER TODAYS OIL IS COMPLETELY DIFFERENT (WAY BETTER)THAN THE OLD STUFF we ran years ago AND EVEN IF THE OIL WOULD GIVE BETTER LIFE...THINK OF THE FILTER!!!
Some are Bogus and some are not! Engine tolerances are very much closer today .Usually the ones on the plaquard above the writer's desk are add ons to make them $$$ . (like get an engine flush).GENERALLY...IF IT IS REQUIRED...DO IT...IF only recommended,,,DON'T...SERVICE CTRS ARE HUGE PROFIT CTRS!!!
I strongly recommend against places like jiffylube etc...worst of all worlds...poor quality oil. filters (even if they had one)_ yes, all filters were NOT created equally (materials, # of pleats etc> and poor workmanship (like in being famous for stripping the drain plugs, and not checjking form leaks!)
BTW: the OEM filtert is a Cannister type, not an all in one is known to be of decent quality)
If it says REQUIRED IN THE MANUAL...I recommend you do it...IF IT SAYS "recommended"...use your own judgment (MANY OF THOSE ARE THE BOGUS ONES YOU ARE REFERRING TO I BELIEVE). Stay away from oil additives and things that claim to increase gas mileage and make sure all fluids are the spece'd out for your vehicle I definitely stay away from additives for oil (MY RULE OF THUMB IS USE OEM FILTERS (NOT FRAM/Honeywell) AND EVEN THOUGH I HATE the stuff or Quaker State/Penzoil, LET THE DEALER USE HIS BULK OIL and do the oil changes as well...THAT WAY THERE I CAN PROVE THAT THE INTERVAL WAS INDEED MET (MONTHS AND MILEAGE BOTH!!! (as well as the correct fluid weights. I insist that notations always includes "customer requests all fluids to be correct and topped off...I admit to using an occasional an of Chevron's Techron in a gas tank every once in a while...Gas these days is junk IMHO! NEVER GIVE A DEALER A SHOT AT VOIDING YOUR WARRANTY...NEVER!!!
YOU ALSO MAKE REFERENCE TO THE TIMING BELTS/CHAINS on the 2.7 and 3.3Liter engines. I BOUGHT THE SE model with/ 3.3 Liter ENGINE, PRIMARILY TO AVOID TIMING BELTS (+ some of the nice goodies like the 5 speed auto tranny instead of the 4 speed automatics. ( (THE 2.7 uses A BELT, THE 3.3L HAS DUAL TIMING CHAINS.If you have belts and the engine has not had its belts replaced on time...I think you are a dead duck! That is expensive service...like $6-700 to replace that belt!!! NEVER FORGET THE BELTS IF I HAVE NOT BEEN CLEAR ENOUGH
As for the inspections, I've always operated on the premise that the engineers know what they're doing; as such, I follow their recommendations. A 60,000 mile timing belt interval is very common in the industry and you'd be wise to adhere to it.
As a case in point, the car I owned longer than any other was a Volvo 940 Turbo. I bought the car new and followed the recommended maintenance schedule to the letter. I kept the car for 9 years and 245,000 miles without a single major problem. When I sold it, the engine still sounded and ran like new. Volvo knew better than anyone how their cars should be maintained; I believe Hyundai does, too.
I haven't had any problem whatsoever with Hyundai's warranty and with all of my self-performed maintenance done on my Hyundai. They offer a website for owners to specifically keep track and document all self-performed maintenance. Except for the major service intervals, you can substantially reduce your preventive maintenance costs in this manner.
Although the Lambda V6 used in the Santa Fe uses a timing chain (and under normal use, shouldn't require replacement for 200K to 300K miles), it does use mechanical valve lifters with adjustment shims for valve lash adjustment, e.g. it does not use hydraulic valve lifters. Because of this, if the V6 does eventually require replacement of the shims to bring the valve adjustment back into spec, this service (out-of warranty) will be rather costly, as I believe the labor required for this is around 8 hours.
Re. your comment on timing belt replacement . . . Hyundai's I4 engines are "interference engines." If a timing belt should break, the valves will hit the crown of the piston, possibly holing the piston, but surely bending a valve - or plural in many cases. I believe most Toyota engines are "non-interference engines" - i.e. if the timing belt should break, there is sufficient clearance for the valves to be open when the piston is at TDC (top dead center) or fully "up". Thus, if a timing belt breaks with most Toyota engines, you simply have to replace the belt - not the engine!! Hence, Toyota's longer replacement interval for their timing belt.
The older Hyundai I4 engines were derivatives of a Mitsubishi design, and my son's Mitsubishi Galant, which uses a timing belt, went over 100K before he replaced the timing belt. No problem, but if it had broken, he would have been in big trouble, as the 2.4L Mitsubishi I4 is also an interference engine. I think Hyundai is just being conservative, as unfortunately, a fair majority of owners do not follow the recommended maintenance intervals on any make of car.
Yes my Toyotas for the most part are non-interference shame can't be said for the Hyundai. It's really hard to determine the way to go. I can get a Highlander for a little more then a SE and not have to worry about the chain.
The salesmen said the belt costs 500-600 to replace which I think is way to high, unless there are 2 on the GLS. Normal timing belts cost 200-250 then they usually do the seals and waterpump for another $500.00.
As far as shims and lifter adjustments. I have a feeling when you get your timing chain/belt done at Hyundai they do not even touch those. Sorry I just think they ignore that extra stuff that probally really needs to be done.
I also like the paint better with Toyota. Not very happy with what I have seen done on the paint jobs for Hyundai even todays models. I owned an excel in 1985 that the clear coat pealed right off during its first 36,000 miles. To me the paint is still an issue.
I do use mobil 1 high mileage oil and high mileage filters. I run them until 7000-7500 miles. I called Mobil up and asked a bunch of questions about longevity of the oil and filter and they had no problem with running them at those intervals. 3000 miles using a synthetic makes little sense to me and would hate doing that. I do like the added protection they claim however.
IMO you need to look at the real significance of the things you're using to make a decision. Now, I don't know how much it costs to replace a timing belt (or chain) on a Santa Fe. Whether it's $250 or $500, so what? It doesn't happen but every 60,000 miles which for most owners is every 4 or 5 years. That works out to roughly a $50 difference per year, about the same as a tank of gas. Big deal! In exchange we get a 10 year 100,000 mile powertrain warranty. That's a good deal if you ask me.
As for oil changes, we've already established that the normal interval is 7500 miles, not 3000. An oil change in these vehicles runs around $35. That's insignificant if you ask me.
You've also expressed concern over fuel economy and your notion that other makers' published numbers might be more "reliable" than Hyundai's. I get an honest 22 - 23 on the highway in my Limited (3.3 liter) AWD. Admittedly, that's not great. But even if I got 25 (which subjectively sounds like much more), at 3 mpg more that would be a difference that I'd barely notice in my pocketbook. It's just not worth worrying about.
BTW, the paint on my Steel Gray Limited is absolutely perfect. I bought the car the day after it was delivered to the dealer. As such, it was not subjected to any abuse by test drivers or dealer lot attendants. I'd bet anything that the paint damage you're seeing was caused by abuse after the cars arrived at the dealer.
Wive asked him about synthetic said 5000 miles which is fine with me, living in Florida they say it's harsh so I can't go by the 7500 mile rule. It's not a cost thing with the oil as much as the going to get it done every 2 months I hate doing that. When I purchase higher quality oil I expect a benefit in that I can hold off longer.
By the way it also sounded like they may be phasing out the 2.7 liter for the 3.3 in 08 but that was from a Hyundai service tech, who could not know what is going on.
As long as the mileage is around 21 I'm ok with it. Went through a lot of cars to get it down to the Santa FE and Highlander and just want to get the maintence issues under control now. As far as I can tell most people are vey happy with their Santa FE.
Chain lasts life of engine: Below
http://www.car-stuff.com/hyundaitimingbelt-and-chain.htm
Called Hyundai said no maintence for timing chain.
Also found this:
Hyundai Veracruz
Handles the road as well as you do.
- Veracruz features a powerful, clean and modern Lambda 3.8L V6.
- 260 horsepower and 257 lb-ft of torque help propel you and your passengers to your destination in style
- Aluminum block and head help reduce weight and improve overall efficiency.
- DOHC 24 valve with Continuously Variable Valve Timing (CVVT) and Variable Intake System (VIS) helps achieve 25 MPG on the highway and 18 MPG in the city.
- Maintenance-free timing chain
Called 3 Toyota dealerships:
1 said timing chain last 400,000 miles may need new tensioner once in awhile for $185.00
1 said drive it till it stops working then get it replaced or new tensioner.
1 said never had to change a timing chain. Should last life of car.
as far as timing chains - if you have the money - get it done when the manual says - otherwise it's a crap shoot - many cars don't even break a timing belt or have a timing belt problem b4 100k miles - chains last longer than that - but they do take a beating over time and will need to be changed - the labor time and cost to change just the tensioner is rediculous and you would be better served to do everything at once...
I agree the labor to adjust the tensioner is out of line. But doubt you will really need it done. Basically the chain will not break it will just cause your auto to drive badley or not start as well. Which is a plus in my book (as at least it is telling you something) instead of this random 60-90k estimate they push for a belt that may or may not be going bad.
This also Avoids the extra costs that are involved in a timing belt vs chain are worth the extra $1000.00 for the SE and the extras. Maybe that is why they may be phasing out the 2.7 liter/belt option.
They always recommend changing the water pump/seals and other belts when you change a timing belt bringing the cost up to $1200.00 for the Santa FE at one site. Over 5 years its cheap but when you have to come up with $1200.00 bucks it's kinda hard. The 10year/100k should also cover those components as they are not a required service.
Basically all those extra procedures are influenced by the timing belt change process. If you don't have to have it done till it really needs it all the better.
I agree I would be more intent on doing the synthetic changes between 5-7k. Mobil 1 and Amsoil both seem to cover the extended runs. Around 5k is acceptable to me a little over no biggie.
But one thing for sure you want to have an automatic and have it serviced when they tell you. I have read Hyundai/KIA owners I forget which, were told their manual trans went bad because they drive the stick badley. These were people that have driven manuals for 30 years, who needs that in the equation? Get an automatic do the maintainance and drive till 100k without extra costs.
Bill
It was not a number for a single part, but an entire map light kit depending upon your trim level (as dictated by your VIN#)There were a new dome and Map light assemblies and I believe 2 new harnesses + [non-permissible content removed]'t hardware (crimp connectors etc)
Good luck
Jeff
Bill
Bill
Lithia Hyundai in Reno wanted $96 + fgt for their crimp on trailer oem harness!! (factory list was $81!) so I mail ordered the plug and play from Roseville Calif..there comes a point to say......bye! Will just use RENO stealership enough to keep warranty in shape!!!
New service Mgr (his policy)...and he could not figure out why his oil chg bays were empty, I MEAN REALLY EMPTY ON A MONDay morning...PEOPLE ARE FUNNY HERE! AND They know when they are being ripped off and surprisingly people do know about bulk grade oils! (they would rather use JiffyLube than pay the stealership places!)Just make sure...no leaks and you get your old parts back (Law here if you ask)...no crossthreaed plugs thanks! (if they know what to do and I do have time to do it! I still want it done myself...I know it was done correctly but at the old price..it was worth it!
In fact, Took that funky plastic shroud off just to have a look at filter location...but is it a pleasure AND I DO KEEP RECORDS GALORE!
Figured for $35 w/ Mobile One inc oem filter + 1 additional qt of Mobile One...ok...
but for crummy oil (even at 3000 miles)...I'll do it myself just like the past 35 yrs! I will use the left over in my snow blower! :P It likes 20w/50 SYN too
Their info is if you want em: 3355 Kietzke Ln. RENO, NV...Nice people but who needs em. I will pay for a little convenience BUT lets see... 6-$7 for crummy oil
$3.00 xtra gas r/t BIG TIME HILLS)(second choice in filters would be WIX by Napa Gold and I prefer them just next to the OEM)
My tools going to waste!!! A REAL BIGGIE!!
Even though Mobile One is not Top tier oil that people think it is (great marketing!),,,,,, I will take it in place of that 55 gal drum stuff!the dealership uses and loosen up the interval a little bit, Will be easier on the engine this winter too
they just raised the bulk Quaker Qrap oil chg from $32 to $37 (A FEW $$ morefor the same crummy grade oil...maybe, but Wally World is $26 for 5 qts of Mobile One (just about the same dinero w/ much better oil)...Might have to warm up the 3rd garage bay to stay in practice, drink a bi mor coffee...but.......and use the $$ to go to Mobile one...still staying with oem filters!(about $12 ea. I only do a change about 5-6 times per yr anyway since I dive so little theses days anyway
Lithia Reno Hyundai
Reno, NV 89502
(775) 823-5500
Like yours, the Map light kit was free from Hyundai Consumer Affairs and installed free.
I bought my harness (Part #U8612-2B000) at Arapahoe Hyundai in Centennial, CO (Denver suburb) for $69.37 + tax. Their service department is every bit as good as their sales department, and the phone # is (303) 539-1700. I'm sure they can help you out!
I called Hyundai they called my dealer told them it's on the Hyundai site. I then called dealer,they went thru a spill about not being on the dealer system however they researched and found it on Hyundai's system. Amazing amount of work the dealer did for me hehe. On order $81.61. I should get 10% senior discount.
Jeff, as for oil changes, I take my oil (mobile 1)to the dealer. Most dealer will let you bring your own oil.
Thanks much to both of you!
Bill
The correct HARNESS number has not been in the system since THE HARNESS came out I guess...
as mentioned, a lot of dealers still do not even know you can buy a P&P harness by itself without the rest of the pkg (OVER $363!)! THEN THEY WANTED OVER $100 TO SCREW THE 4 BOLTS ON AND PLUG IT IN. SENT THE WHOLE THING BACK AND ORDERED THE HARNESS FROM ROSEVILLE CALIF...
DRAWTIGHT HITCH, RECEIVER, AND BALL WITH LOCK PIN (OVER $150 = .99 CENT FGT SO WHY NOT) CAME FROM ETRAILERS.COM (excellent outfit and service)
THAT Hyundai service GUY (AT ROSEVILLE HYUNDAI)AT LEAST USED HIS HEAD AND MADE THE HARNESS COME OUT TO $81 EVEN, TO PAY FOR THE FGT, TAX ETC! DEALER...5 MINUTES AND IT WAS OVER! Made it look like a favor which I do no forget either!
NOW, NEXT HYUNDAI (IF THERE IS ONE)WILL COME FROM ROSEVILLE OR CARSON CITY NV (1 HR AWAY)INSTEAD OF RENO (EVEN IF THERE IS ONE OF THEM TOO!) :P IT WAS WORTH IT NOT TO DRIVE OVER DONNER PASS IN A SNOWSTORM ($7500 FT)OR i WOULD HAVE BOUGHT THE ENTIRE VEHICLE for the $500...RENO were nice guys...rocket scientists not!
JUST THINK...YOU ARE ON THE DOWNHILL SLOPE now AT LAST :sick:
HEY, JUST BECAUSE IT IS ON THEN SITE, STILL MEANS THEY MUST BE ABLE TO TURN ON THE PC! :mad:
If They could only get their act together. My dealer had just received the correct part Number (AFTER I CALLED CONSUMER AFFAIRS WITH THE XTRA MARKUP IN IT...SO I BOUGHT IT FROM A CALIF DEALER DIRECT!
THE IDIOTS (AT LITHIA in RENO) ... MY DEALER still MANAGED TO SHIP THE WRONG KIT EVEN THOUGH I FAXED the right paperwork TO THEM!!, HARNESS INFO AND ALL
The $81.61 is the correct NUMBER though for the plug and play harness so they must have gotten it right! Do check it for the correct plugs BEFORE taking it!
Here was then the quote from kdahlquist, original post, with the correct part number (harness only) since most dealers still did not know the harness is available by itself.
btw: WHENEVER I DO ANY OIL CHGS AROUND HERE (LIKE LAWNMOWERS ETC, AND NOW I GUESS THE Santa Fe ITSELF too (another great decision by Reno)....I always took it over to Kragen (less than 1/2 mile away! or Autozone...also accepted for free (they make $$ from waste oil).
BTW: I guess that getting to 65 (senior discount) is good for something anyway....golden years my [non-permissible content removed]! The only reason to let them do it in the 1st place was so they had records and for the good will...it was NOT for the crummy Quaker StaTe bulk stuFF for sure! BEFORE SYNTHETIC, I TOOK MY 12 QTS WITH CASTEROIL gtx TO THEM FOR DISPOSAL TOO! YEP, MY 81 PORSCHE 911 TOOK 12 QTS OF DINO! *(AND HAD A HUGE RACING SUMP AND FILTER!
JEFF
