Are gas prices fueling your pain?
13738404243197
  • 1stpik1stpik Member Posts: 495
    you can get a Volkswagen TDI next year after VW meets the new emission standards ..... but it'll cost $26,000.
  • blufz1blufz1 Member Posts: 2,045
    Waitin' for a Honda. :)
    "First you will be spending $40/month more for the car ($90 extra payment less $50 gas saving which I find hard to believe)."
    If you find it hard to believe, then do the math yourself. And this time, include the $2,100 tax credit!
    Either I'm saving $2,100 off the MSRP of the hybrid, or I'm saving $58 per month with the tax credit ($2,100 divided by 36 months).
    The hybrid costs $3,100 more than the regular Civic. Subtract $2,100 and you get a $1,000 premium. With the $50/month ($600/yr.) gas savings, the hybrid pays back in 1 yr. 8 mos.
    Or, I pay $40 more on the basic payment, but save $58 with the tax credit. So I gain $18 per month from day one! How's that for a payback period?
    No matter how you look at it, the hybrid is a good deal.
    I bet the Jetta, Rabbit, and Beetle TDIs won't cost $26K.
    The 2006 Jetta TDI cost $22,000 - $25,000. To meet the new emission laws, the new TDI will use the Bluetec diesel, which ain't cheap. Count on $26,000 as the mid-range.
    The 2006 Beetle TDI cost $19,000 - $23,000. That price, too, will increase, plus the Beetle coupe doesn't really compare to the Civic sedan.
    The 2007 gasoline Rabbit 4 dr.costs $18,000 - $22,000. We'll see what the diesel version goes for.
    BTW, the TDIs get 30 mpg city, 38 mpg highway, 33 mpg avg. The Civic hybrid gets 40/45, 42 mpg avg. See for yourself here: http://www.fueleconomy.gov/feg/sbs.htm
  • plektoplekto Member Posts: 3,738
    The Civic Hybrid still qualifies for the full tax break so that's a wash. What's left is the $3995 you pay for the home filling station plus the $2000 extra in sticker price. That's $5995. Let's subtract the $1000 tax break for this filling station and you've got a $4995 difference. How long does that take to recoup when the hybrid is rated at mid 40's mpg and the GX is rated at 30 mpg? If you can do this in a 5 day work week then you must have been an accountant for Enron.
    So let's work this out for $1.59 CNG at the local station.(there are hundreds across the U.S.) Basically it's $2000 difference. Now, pollution and battery replacement and such aside(plus recycling the batteries and so on - all pretty toxic industries) - that's a cost of 5.7 cents a mile. 9.5 cents a mile for the hybrid. 3.8 cents saved. 52,000 miles. So, 4.5 years of normal driving. That's not too bad, either.
    A Camry V6/Buick/etc - almost 16 cents a mile for comparison! Either option will save you silly amounts of money. - as much as ten cents a mile.
    You are leaving one part out on the VW TDI vehicles coming out in all 50 states. They will qualify for the same tax credit given to the Hybrids. Should be $3400 on the Jetta TDI from calculations. Credit is based on the percentage of gain the diesel adds over a comparable gas car. That brings the Jetta down to below what you will pay for a stripped Prius with what is left for their tax credit. Plus you get a much superior handling well built vehicle. Only time will tell which is the most reliable.
    Tax credits for Toyota hybrids end either this month or Sept 30th. You decide from the website. Has conflicting dates.
    Tax credit ends?
    If you are the average California commuter, the Civic GX is probably the very best choice. They also still get the HOV access given to any CNG only vehicles. It is still the cleanest burning car the EPA has ever tested.
  • tpetpe Member Posts: 2,342
    I agree with your numbers and it does appear that you will recoup the cost premium on the Civic Hybrid relatively fast in your case, but you must really be driving a lot. One question though. Does the Civic Hybrid really cost only $3100 more to drive off the lot? I know that with the regular Civic you can get it for under MSRP, is that the case with the hybrid?
    No 52,000 miles isn't all that bad. Probably less than a 4 year payback time for most drivers. But that is based upon $4/gallon gas and $1.59 CNG at the pump. Gas is currently only $3/gallon and if you look at the long term contracts on the commodities market the consensus is that it will be a little lower than this over the coming years. So if you go with a more likely scenario of gas averaging $3/gallon the cost per mile of the hybrid 7.2 cents or only a 1.5 cent savings. Now it takes 133,000 miles.
    Sure gasoline could go higher, it could also go lower. CNG could do the same. If you are using a financial rational for making this purchasing decision it should be based on what you consider to be the most probable.
    I do agree that the Civic GX is a very clean car from an environmental perspective. If I was going to buy one that would be my primary motivation. I might add that I do get some of my initial investment back through fuel savings but I wouldn't promote this car as a money saver, which is what a lot of owners of these alternatively powered vehicles do.
    Why is that? We've already established that it's not cheaper. Yes it is cleaner. As far as HOV access goes, the last time I was in California that wasn't all that great a deal. In fact I understand that there is some challenge to hybrid access to these lanes. Maybe it's already happened. If so could CNG powered vehicles be far behind?
    Anyway, for your statement to make sense would require that the CA commuter's top priority is a clean burning car. More important than performance, ammenities, trunk space. Again, I've driven quite a bit in CA and from the vehicles I see I certainly don't get that sense.
    So the way I see it the Civic GX's main claim to fame is how clean burning it is. I'm surprised that you consider this to be so important given that you are such a big diesel advocate.
    Ill do the math, first off we will use real numbers the Civic Hybrid gets an EPA estimant of 42MPG combined while the regular Civic gets a combined 30 MPG. Giving a monthly savings of around $45 a month which gives you a additional 36 months after the car is paid off to make up for the extra $45 a month you pay during the term on the loan ($90 extra loan payment less $45 in gas savings).
    Of course the tax credit does change this but I will have to check into what it actually is because they do go down after a set number of cars are sold.
    Nope, if saving money is your goal there are less expensive cars that get good mileage that will save you money over getting the Civic hybrid.
  • kernickkernick Member Posts: 4,072
    That's great news on the tax credit! Plus you get a lot more power from the TDI.
    And real-world driving with the 6-speed trans. I'm sure you crack 40mpg. And I prefer less motors and sensors - less to go wrong.
  • m6vxm6vx Member Posts: 142
    $3100 / $4/gal = 775 gallons
    My car = 30 mpg
    Hybrid = 50 mpg
    difference 20 mpg
    20 miles/gallon * 775 gallon = 15,500 miles
    Any math wizzes out there that want to chime in?
    chuckhoy,
    Try this:
    My car = 49 mpg (not quite, but this is an example)
    Hybrid = 50 mpg
    difference 1 mpg
    1 miles/gallon * 775 gallon = 775 miles
    You can see the logic is faulty!
    The correct formula is:
    (Cost / GasPrice) / (1/CurrentMPG - 1/FutureMPG)
    (3100 / 4) / (1/49 - 1/50)= 1,898,750 miles
    Or for your original example:
    (3100 / 4) / (1/30 - 1/50)= 58,125 miles
    Great news for who? If fuel prices stay high I expect these new diesels to be very popular. Meaning the bulk of that tax credit ends up going to the car dealership.
    I definitely expect Honda diesels to be selling for over MSRP, which will be an indication that there is a strong demand, exceeding supply. Our government in it's infinite wisdom will find it necessary to increase this demand. It won't get any more of these vehicles on the road but it will add to the dealership's profits. Our tax dollars at work.
  • chuckhoychuckhoy Member Posts: 420
    Yes, I already corrected myself in later posts.
    That's the problem with taking some time off and falling behind the posts. :-)
    "The 2007 gasoline Rabbit 4 dr.costs $18,000 - $22,000. We'll see what the diesel version goes for."
    The base Rabbit 2-dr goes for $15,5, and the base Beetle is very little more. I figure the diesel will add about $2K to the price. A 2-door Rabbit TDI for $17,5 is a bargain, I think, given it has a lot of standard equipment even in base form. I am surprised, however, at the low projected fuel economy numbers. 30/38 is all it will do? I will go with a gas Civic or something smaller if that is the case.
    I hope Subaru's new diesel does better numbers-wise.
    I'll never buy a diesel car until they get rid of the stink in the fuel. One mishap or one fuel leak and your car seems to stink forever. I trust that biodiesel will eliminate this issue. One problem I had was that people would spill the diesel at the pump and then you'd pick it up on the soles of your feet. I always used to wipe my shoes with a towel after fill-ups.
  • robertsmxrobertsmx Member Posts: 5,525
    Yep. Thats my biggest gripe about diesels. Somehow I can take a bit of gasoline fume, but diesel is downright nasty.
    I wish there was a bigger push nationwide to making biodiesel available. Of course, then your car will smell like french fries after every fill-up! ;-)
    I don't know what biodiesel smells like. Supposedly the exhaust smells like french fries. My understanding is that the smell of diesel is one of the primary reasons that diesel vehicles never caught on in Japan despite their high fuel prices. However that seems to be changing.
    I like French Fries.
    In fact I might have some for lunch. YUmmy fat and all.... :D
  • jkinzeljkinzel Member Posts: 735
    The new clean diesel seems to have lost a lot of that nasty smell in its unburned state. I have noticed when driving around big trucks on the freeway that that nasty diesel smell is hardly noticeable with clean diesel.
    Yeah well if you think pump biodiesel smells like french fries, then my socks smell like gardenias.
    That's not the case. Biodiesel smells better but it's not exactly fragrant or french fry like (that myth comes from people using recycled restaurant oil. It's got a kind of musty, fairly neutral smell, you know, like a tailpipe!
    Yeah I have never smelled Bio Diesel. One of the heating oil companies near me offers a bio diesel heating oil mix. Never looked into it to see how much it was though.
    I still like French Fries. :P
    Now I want some fries! :-P
    I am totally getting some for lunch now. I think I will go to Five Guys.
    "Does the Civic Hybrid really cost only $3100 more to drive off the lot? I know that with the regular Civic you can get it for under MSRP, is that the case with the hybrid?"
    2007 Honda Civic EX msrp $19,500
    2007 Civic Hybrid msrp $22,600
    I paid $21,400 for the hybrid w/o navigation system last month, and I probably paid too much. Check these prices:
    http://www.greenhybrid.com/discuss/showthread.php?t=12833
    Last year, dealers were adding thousands to the msrp of hybrids. But this year the manufacturers increased production, so the supply and demand have equalized. You can get the same discount on a Civic Hybrid that you'd get on a regular Civic. Same financing, too.
    It's true that Congress limits the number of hybrid tax credits on every model, but that doesn't affect the Civic Hybrid. The limit is around 60,000 units per year, and Honda sells 40,000 hybrids. Toyota sells 100,000 Prius hybrids, so buyers late in the model year get screwed with a reduced credit.
    (From ajc.com) Our friends in Congress are debating Senate Bill 1419, the Renewable Fuels, Consumer Protection and Energy Efficiency Act of 2007. The legislation “could result in significantly higher prices for gasoline consumers,” according to Heritage Foundation researchers.
    “Gas consumers can expect to pay between $3.16 and $3.79 a gallon for gas in 2008 after adding in the estimated impact of the Senate energy bill. By 2016, all states can expect gas prices in excess of $6.00"
    Sorry anything from the Heritage foundation is instantly suspect to me.
    consider the source. That sounds like a scare tactic from the energy/auto industry. (aka major donors Dow Chemical and General Motors ;)
    Visiting Host
    If you're looking for scare tactics, you should look at Congress. They're the ones claiming that we need $29 billion in new taxes on oil, plus billions more in tax subsidies on ethanol because the earth is melting. They're the ones decrying the "obscene profits" of oil companies.
    Exxon makes 11 cents per gallon profit on gasoline. The federal government makes 18 cents per gallon. Congress doesn't drill for oil, transport it, or refine it, yet they make 70% more money on gasoline than the oil companies.
    Talk about obscene profits! Now they need more, and if they don't get it, the earth is DOOMED!
    Heritage's claim is irrational on the face of it. Obviously oil companies would love gas to go to $6 a gallon--wouldn't you if you were an oil company? That leaves only one explanation for Heritage's hyperbolic statement---that alternative energy sources are frightening to the oil companies, with whom Heritage is quite cosy. Ergo, sell FEAR to the consumer (as usual). Didn't somebody say that the only thing we have to fear is fear itself?
    So true. I don't care WHAT political stripe sells fear...I refuse to respond to FEAR. I hope you do, as well.
    However I will agree with you 100% that ethanol is a scam and merely a hidden subsidy to special interests in the states from which certain politicians are elected.
    As for global warming, that is a proven scientific fact, so we'll have to deal with it one way or another....whatever that way turns out to be.
    Visiting Host
    "TDI vehicles ... will qualify for the same tax credit given to the Hybrids. Should be $3400 on the Jetta TDI from calculations."
    What calculations? Cite your source. Here's an example:
    The 2006 Jetta TDI got zero tax credit because it didn't meet the provisions of the Clean Diesel Vehicle Tax Credit in HR 6.
    Source: http://www.dieselforum.org/fileadmin/templates/Resources/LDTax.pdf
    Alternative energy won't cause gas prices to rise. $29 billion in new taxes on oil will. That's the point.
    Congress is trying to present this bill as if it's good for the environment, when the truth is that it's just another money grab.
    If Congress was ever concerned about reducing automobile emissions, they'd only have to raise the passenger car CAFE standards. The number has been 27.5 mpg for the past 22 years.
    Source: http://www.nhtsa.dot.gov/cars/rules/cafe/overview.htm
    If Congress had continued raising that number by only 1/2 mpg per year, the current standard would be 38 mpg. Of course, if cars burned less fuel, then the federal government would get less money from the 18 cent/gal. fuel tax. And keeping CAFE stagnant keeps campaign contributions flowing from Exxon/Mobil, GM, etc.
    Get the picture?
    per gallon seems to have had so little impact, Congress should tax gasoline to hold the price steady at $3.50, for the purpose of reducing consumption, then ramp it up a little each year for the next 10 or so. A much better tool than all these CAFE talks, which will just result in a set of regulations that automakers will quickly find a way around, just like last time.
    Just remember, nobody is forcing you to pay less at the pump or in taxes. If you really feel that $3.50 gas is right, tip the cashier the extra money. I'm sure they won't mind. Think you pay too little in taxes? Send extra every April 15th. I am sure it will be put to good use. ;)
  • texasestexases Member Posts: 11,163
    Find me some politicians that will pursue that - in Texas they talked of rolling back gas taxes to ease up on people, in Oregon they're considering installing GPS mileage monitors in all cars (pay per mile, not per gallon) because the pols don't have the will to push for higher gas taxes just to keep revenue flat for road repair, etc.
    p.s.-I'd only want it if it were revenue flat - fat chance!
    I must say, that is a good price for 40/45mpg.
    That just scares the bejesus out of me. :surprise: Much like the Big Brother aspect of traffic cameras. All they need to do is call for it in the name of "the children" or "safety" or some such claptrap for me to vomit. :sick:
    I don't know about that. It seems to me that if you make it more expensive for the oil companies to do business at least some of that added expense will get passed on to the consumer. With these sweetheart deals they've been getting its quite possible that some wells/fields that had been profitable will no longer be, which will reduce supply, which will ultimately drive up costs. I'm not trying to defend the oil companies here but this just seems like common sense to me.
    You only think the cameras are Big Brother if you are running red lights. :)
    Yes comrade.
  • andre1969andre1969 Member Posts: 26,109
    I'm driving my '76 LeMans up to Carlisle PA for the GM Nationals. I'm planning on starting off with a full tank, and am going to attempt hyper-miling it up there.
    Anyone want to place guesses on what kind of mpg I end up getting? It'll be mostly highway, although some driving around in town and such, and the car has a Pontiac 350-2bbl and lame-o axle ratio like 2.41:1 or something like that.
    I doubt I'll be putting too many Priuses to shame, but I wonder if I can get it into the upper teens?
    Have you ever jacked up the back of the car and spun the wheel to see what the rear gear is?
    Not yet...guess I should get around to that to really see what it is instead of guessing. I just remember reading somewhere that in 1976, GM started using 2.41:1 ratios in powertrain combinations where the 2.56:1 had once been standard.
    I guess it *could* be a 2.56:1, but probably not anything much quicker. The car's pretty slow off the line. My '79 New Yorker, with a 360-2bbl and a 2.45:1 rear is faster. It actually seems more responsive at higher speeds, and is very willing to downshift.
  • pat84pat84 Member Posts: 817
    A company is hired to run those traffic cameras. They get a percentage of the ticket revenue. They place the cameras where the yellow light is shorter than average to maximize their revenue.
    I objected to this so I had Fresnel lens coverings on my license tags. You could only see my tags looking directly at them. They would not be seen by a traffic camera above.
    I had a radar detector on my visor. Radar detectors are illegal in VA
    I was doing about 85 in a 55 after crossing the bridge from VA to MD. The bridge cop caught up with me about 10 miles from the bridge. He had to be doing well over 85 to catch me.
    He gave me a warning for the Fresnel covering. As he was talking to me, my radar detector went off as a MD radar car went by. The bridge cop said nothing about the beeping radar detector.
    I almost laughed. He had to do close to 100 to catch me, said nothing about my speeding; knows I was in VA with a radar detector, says nothing about that, and gave me a warning ticket for license covering.
    He saw me grinning and said, " You're grinning because you know that your license can't be read by a camera."
    Right, that's why I was grinning.
    I took the Fresnel covering off for about 6 months.
    They're back on.
    Big Brother can hop a spoon.
    The $6 a gallon "message" is alarmist propaganda. A $6 a gallon fee, after all, would plunge America into a massive, horrifying depression of unparaled proportions. It's an irrational speculation IMO and impossible for a mere tax to do that anyway. And why exactly would Congress vote to destroy the country? It's just coo-coo stuff from Joe Coors and Co.
    I haven't read the "tax" bill however. You may be right, it may not be at all a good idea...I really don't know just yet.
    I was just commenting on the hysteria of the $6/gallon message, that's all. I'd need to read the bill in detail to know what else to say about it.
    Visiting Host
    Now now, Pat, I don't think that's appropriate talk. Now the big end of a baseball bat, THAT'S a different story! :P
    BTW, I don't know if this is true or not, but I hear that if you have a pickup truck and drop the tailgate, that those cameras also can't read your license plate. I have a pickup truck, but I'm not about to try it to find out!
