2009 Acura TSX
I don't understand Acura's thinking about adding the 6 either, nothing unique about that. VWs markup of about 2k for the TDI over the RUG Jetta really just covers the added expense of the D2 engine IMO. It seems to be quite a good deal and I think Acura could have done the same but with an even higher markup(due to the luxury brand mostly) to cover costs and even make some gravy.
Tell us more.
Why?
You would assume the car would be new and be just fine. But, sometimes a simple drive or look around can make a difference. Worth the money to inspect. Instead of being stuck with a lemon for a few years.
I am having a weird problem with my new '10 Base TSX. When I play music through the blue tooth audio, I am unable to skip songs. I tried the +/- buttons on the steering, skip buttons and the selector knob. The only way to change tracks is via itunes on the phone itself.
However, if I connect the phone with USB, then I am able to use all of the above to skip tracks. Has anybody else faced this problem?
I have a 3g iphone.
Regards
Makes it a bit more complicated when your bundled up to run and have to dig out the phone to skip a song. But, better than a wire.
