-June 2024 Special Lease Deals-
Chevy Silverado Problems
I've been waiting for a harness for a child's seat. The first one they gave me was the wrong one, but I took it and tried to install anyway. Didn't work and returned to dealer who had ordered me another, different harness. Told them this isn't gonna work, but THEY tried anyway only to tell me that it doesn't work. Now I'm waiting for another harness which they forgot to order. This has been ongoing for three months for one harness. Will call tomorrow figuring two weeks was enough time for them to bring in the correct harness.
How did I know which harness was correct. My Helm's manual shows the harness that will work. So finally, faxed the info to the dealer hoping they can figure it out and get it right this time. Three months and counting for the right harness....go figure.
here is what i need to know: i tow boats only occasionally (max weight 1800 lbs). i think i want the small V8, limited slip and auto in a 2 x 4 extended cab, with the towing package. is this a good choice ? what REAR END GEARING SHOULD I GET ? also, when GM says "traction control", is that limited slip ? or, is it something else ? i am also looking a Toyota Tundras, but am amazed that they do not offer that truck with limited slip ! incredible !
GOOD LUCK EVERYONE !!!!!! JOHN
Tom
2001 Rado.... 600 Miles. and I have piston
slap in the morning and when the motor is cold..
Quiet as a mouse at full temp..
I am going to take it to the dealer and at least
have them document it now. I will be purchasing
the GMPP at the end of one year. I will be getting
the major gaurd to 100,000 miles. Who knows,
I might be able to get them to put a new motor
in it at 80,000 miles...
Bought the GMPP on my former truck.. 1997 GMC
Sierra.. It paid for itself in spades....
Good luck!
http://agmlemon.freeservers.com/
THE CHEVY REP. TOLD ME THE COLD ENGINE KNOCK WAS DUE TO WRONG SIZE PISTONS. HE OFFERED ME, 100,000 MILE BUMPER TO BUMPER, BUY ANOTHER AND MAKE UP THE DIFF. IN M.S.R.P. OR THEY WILL BUY IT BACK. I TOOK THE BUYBACK. THE TRUCK HAD 28000 ON IT WHEN THE DEAL WAS DONE AND WE AGREED ON 11000. I LOST 1 YEAR OF PAYMENTS BUT GOT MORE THAN MY DOWNPAYMENT BACK. I PROB. COULD HAVE PUSHED THE MILES MORE BUT I HAVE ENOUGH STRESS IN MY LIFE ALREADY.
AS FOR MR. JOHN FLANDERS FROM G.M. WHO SAID " NOT NOW OR IN THE FUTURE WILL G.M. EVER BUY BACK YOUR TRUCK " GO SUCK MY TOYOTAS TAILPIPE !!!!!!!!JOHN
P.S. I'M NOT YELLING AND IF YOU THINK I AM, DON'T READ THIS EARLY IN THE MORNING. JOHN
(im 21 by the way and it is bothersome)
-- Don
I have already filed with the BBB against GM over excessive wind noise. If I'm driving with a crosswind of approx. 5 mph, it sounds like your driving thru a 50 mph wind storm. Has anyone else experienced this? I believe Rayt2 (SP?) said in a post last week before he left for Canada that he was suffering from wind noise as well. I would appreciate feedback from anyone with any insight as to what is causing this. This dealer has already replaced the rear quarter windows and door seals. Thanks!
Mark
It's great to see all this information on these trucks!
michgndr
You've got it......that's what it is....piston slap. You need to have your dealer document it so that you can get the new pistons when they come out....yeah right.... It will start the wheels in motion once your dealer can verify.
Still looking for any insight on the top end engine flush.
Mark
My 99 Blazer made the same noise and had to have the ball joints replaced at 35k miles. What the hell is GM making these joints out of?
John294, what rear axel ratio do you have? I have 3.73 in my V-6 and it has a lot of power. I have timed it 9.3 secs 0 to 60 with my Gtech meter when it was new. The V-6 is very smooth too.
You can have them do the top clean (its just a solvent that gets rid of any carbon) and the engine knock will go away, but it will come right back after only a few hundred miles. I had the treatment done a few months ago on my 6.0l engine and the knock went away completely for about 300 miles or so, but it came back and it now knocks just as much as before the treatment. Every post I've ever read from anybody else who had the treatment done also said the noise came back after a few hundred miles. This noise is either a piston slap, wrist pin or rod bearing noise, but I don't understand how the top end cleaner makes it go away for awhile.
My dealer recommends that all their customers use only Chevron gasoline under the theory that Chevron's Techron additive is supposedly the best at keeping the pistons clean of carbon. I switched to Chevron right after the engine cleaner treatment was done on mine, and since it now knocks as much as before, I guess that theory doesn't really stand up.
You can get the top end cleaning job done and get some quiet starts for awhile, but its not a long term fix. BTW, don't let the dealer charge you for this service if your truck is still under warranty. Some dealers in my area have been trying to stick their customers for this service as a routine maintenance item, not a warranty item. The cost in my area is like $160. My dealer did it for me free of charge with no questions asked.
Mark
Well, when it did come back I was then told that the knock was normal. They said the computer allowed the engine to reach knock and then automatically retarded the timing to maximize fuel, perfomance, etc....sounds like a load of bs to me...
Anyway, i've been told that the top end cleaning involves pouring the additive into the cylinder heads. If this is true, then everytime they perform this they must pull the heads and then reseal them? (thus increasing the chance of contamination, compression loss, etc...). Anyone know for sure?
Punjab -- to decarbon they pull the spark plugs and add the tonic from there, not the heads!
Marko... as for the wind noise I never did resolve that issue..... yet.
Trip to Canada the truck ran great towing the trailer 777 miles round trip & got 10.1 mpg @ 70 mph....wooo whoo! Found that it's best to keep it in third gear tow/haul mode so as the cruise works without shifting back and forth whenever I hit a slight grade. 700 rpm difference but performance was better in third gear then in overdrive.
Ray T.
Thanks!!
Wade
Interesting to note that in the GM factory service manual, they indicate that an engine knock noise for up to 1.5 minutes on cold start-up is considered normal. Wonder what they consider abnormal?
"The limited slip additive available through GM is compatible with the synthetic lube and should take care of the problem."
I had GM change the fluid (they also changed the Transfer case fluid) but haven't gone on any long trips with the RV since, so I don't know if this fixed the problem. Since you say the problem returned on your truck it will probably return on mine as well. If it does, I plan on adding the GM additive and try that. Post your success here.
Stan
Bob
1. Creak/pop in front end - Dealer replaced bushing in lower control arm and swaybar
2. Rear view mirror temp/compass stopped working - Dealer replaced mirror
3. Rear spring slap - Dealer installed rubber caps on end of spring leafs
4. Quarter window wind noise - Dealer replaced rear quarter windows
5. Throttle pedal sticking - Dealer replaced throttle body
6. 2 recalls for minor brake related issues
7. Transmission sometimes starts from 2nd gear and then drops back into first with a clunk - Dealer can't reproduce the problem
8. Alarm goes off for no apparent reason - Dealer can't reproduce the problem
9. Power window on drivers side stopped working while in the down position - by the time I got to the dealer it was working again - Dealer couldn't find anything wrong
10. Very loud lifter clatter after truck had sat for a few days - Dealer said it wasn't lifter clatter, but a piston problem - something about oil getting by rings causing a carbon buildup on top of pistons. GM is supposedly working on the problem and they expect a solution within 4 to 6 months. The solution will probably entail new pistons.
One thing about driving this truck - it's always interesting trying to figure out what's going to happen next.
I have mixed feelings about keeping it. On one hand the problems, for the most part, are being fixed, and just how many things can go wrong, anyway. But I'm getting tired of always waiting for the other shoe to drop. And I don't like to think about owning this thing after the warranty is gone.
Decisions, decisions.
Since I had them on the truck while looking for another set (which I really took my time on) for 8 months, I figured just chuck it to experience and took a torch and cut it into itty bitty pieces. Call it $300 worth of satisfaction.
Jim
Jim
BTW, I enjoy your posts. Seems like you have a good head on your shoulders.
