Chevy Silverado Problems
Has anyone experienced a rough idle or Shivering feeling in drive at idle. Also a pinging sound on accelarition 15-50 mph. The dealership cleaned the throttle plates decarbonized the motor and cleaned the fuel injectors. Still having the problem. The rough idle has been that way since new and the pinging started at 24,000
Hans
Billy
Hans
How cold has it been by you? Its been well below zero here in indiana for sure.
Ryan
Also having problems with posi (differential), 4-wheel drive lever (on the floor, won't shift-locks up), & interior. Chevy won't do anything for any of the problems...zone manager says the 4wd locks in on 4th or 5th try generally, so there is nothing they can/will do. Motor they have basically told us has to blow up before they will fix it.
After having been a Chevy lover for years (we also have an '84 K25 (in the process of putting a racing motor into that one) and a '92 K1500 (which, with a 305, suped up, and 125K miles, has more balls than the 454), I'm really discouraged in recommending a Chevy to anyone right now...attitude after the sale stinks. Anyway, if anyone out there has problems/solutions, please write.
chris
1 of 2 '99 Silverado rear end noise? Herculiner? by ebarnhart Jan 02, 2001 (08:04 pm)
Just bought a 99 silverado 1500 I/a 5.3 auto used. Seem to hear a "flunk" sometimes when it shifts from 1-2 maybe 2-3 anyone else? Normal? Anybody tried the Herculiner compared to spray on's?
99-07-30-002 FEB 99 Harsh 1-2 Shifts
There is also this one, but the clunk is at accelerating from a stop. Maybe...need more info.
Bump/Clunk Upon Acceleration (Flush and ReplaceTransfer Case Fluid) #99-04-21-004Bump/Clunk Upon Acceleration (Flush and Replace Transfer Case Fluid)1999-2000 Cadillac Escalade1998-2000 Chevrolet and GMC K1-2 Pickup and full-size Utility ModelsWith NP246 Automatic Transfer Case (RPO NP8)This bulletin is being revised to add information to the Models and Correction sections and changesto the Parts Information. Please discard Corporate Bulletin Number 86-74-03 (Section 7 --Transmission)ConditionSome owners may comment about a "bump" feeling when the vehicle accelerates from a stop. Thiscondition usually is only a single bump feeling or single event. Do not confuse this condition with alaunch shudder condition, which feels as if the vehicle is shaking or shuddering and is a multiple event (more than one bump).CauseThe condition may be caused by a slip-stick condition between the rear propeller shaft slipyoke and the transfer case output shaft.CorrectionA new transfer case fluid has been developed to correct this condition. This blue colored fluid isthe next generation Automatic Transfer Case Fluid. This fluid contains a better friction modifier thatshould eliminate the slip-stick condition. Flush and replace the transfer case fluid on affectedvehicles using the following procedure and the part number listed below. Refer to the Transfer Casesubsection in the appropriate Service Manual for information on draining and filling the transfercase. Refer to Corporate Bulletin Number 99-04-21-001, dated April 1999, for important information onremoving the transfer case drain and fill plugs.Drain the transfer case fluid. Refill the transfer case with 2 qts (2 L) of new fluid, P/N 12378508 (In Canada use P/N 10953626). After refilling the transfer case, drive the vehicle a minimum of 8 km (5 mi). With the transfer case at operating temperature, drain the transfer case fluid again. Refill the transfer case again with the new fluid.ImportantThe vehicle may require approximately 160 km (100 mi) of driving before the condition is completelycorrected.Parts InformationPart Number Description Qty *12378508 (In Canada use P/N 10953626) Auto-Trak II Transfer Case Fluid 4 qts (4 L ) Containers *The above P/N represents a case of twelve containers.Parts are currently available from GMPSO.Warranty InformationThis procedure requires the draining and refilling of the transfer case fluid twice. To submit forreimbursement, please follow these steps.Use K4290 and put the labor time for the 1st drain and refill in the labor hours field. Put the 2nd drain and refill labor time in the other labor hours field. Submit the part number, the total number of parts used and the total parts dollars in the respectiveparts fields. This claim will require dealer self-authorization using authorization code "E." For vehicles repaired under warranty, use:Labor Operation Description Labor Time K4290 Plug, Transfer Case Drain - Replace Use published labor operation time © Copyright General Motors Corporation. All Rights Reserved.
I have a 99 Z71. My problem is with shifting from 2nd to 3rd gear. I get a klunk (sounds like transfer) plus you feel it through the floorboard. The lazy, worthless mechanics I've taken it to diagnose it by sitting on their butts behind the computer. There is a TB that references drive line flunk, but mine only does it between those two gears. I fail to believe that's the problem, but they won't look further. I have written two letters to Corporate He's, numerous em-ails, and 800 phone calls voicing my disgust with this truck and their "service". Anyone else in my shoes? I've got about 33,000 on it and am ready to trade it off, I'm almost tired of the fight!
I recently filed with BBB with 29500 miles and my outcome was good. You can get the file form from the internet. Run a search for BBB and it'll come up. I've filed 2 times on 2 different trucks with BBB and got what I ask for both times.
Good luck
John
it took a while for me to get my passenger side
rear door to latch on my 2000 silverado. Is there
any service bulletin to address this as I see
others are having the same problem?
Mike
The plastic guide where the seat belt goes into the seat pulls off -it takes a little force to get it started - but once you get it pulled out a 1/2 inch it then comes right off. Then you pull the belt to the end of the spool, and put 1 little squirt of WD-40 on each side of the plastic spool - I then let the belt retract back in and pulled it out a few times to get the WD spread out - Fixed mine a few months ago and no more squeek. The plactic guide snaps right back on -
I was told by one dealer service manager to bring the truck back in everytime the temp went down and he would readjust them. Real smart idea!!!
I was ready to file a BBB complaint when I got a call from a dealer service manager and gues what Chevrolet has a repair kit available. It contains 2 new latches and some rubber part. He is waiting for them to become available from GM.
It seems strange that for weeks I was told no problem existed and then Shazam a fix appears.
I haven't had the work done yet, but it does appear that something is on the horizon.
Also I am having the rear quarter windows replaced as I get a lot of wind noise from them. This is another fix Chevrolet offers (if you ask and complain)but doesn't advertise to the public.
Seat belts squeak:
I have had my drivers side replaced because of the squeak and now it is back. I'll try the WD-40 fix.
The passenger side doesn't squeak, but it locks up and the passenger is trapped. What next!!!!
In my earlier "Knockwurst" posts on "1999 Silverado Knock", I described the symptoms of my problem beginning at 2000 miles (pining, ticking, clicking sound @1000-2000 PM &40-50 MPH in fourth gear or overdrive upon acceleration) and the attempts by the dealer to fix it. They replaced both knock sensors, air check valve, re torqued the exhaust manifold, extensively road tested with me and couldn't find any codes or anything wrong with the engine.
But the sound was still there. At first, I took it really easy since I didn't want to damage the engine. Once the engine was completely gone through, I tried to duplicate and pinpoint the problem, and noticed that the ticking would momentarily stop when driving over small dips while the truck was going down. Once it recoiled upward, the noise would start up again and continue while accelerating. At this point, I remembered reading a post on the Pacific Audio site on this same problem.
Well, to cut to the chase, I printed out the fix from Bob Brim, gave it to the dealer, and they installed the new gasket to the drivers side exhaust flange between the cat and the manifold, same with the doughnut on the passengers side. PLUS, the wrapped more foam on the steering column to prevent any noise from coming the shaft through firewall.
If they couldn't fix it this last time, I was more than ready for arbitration. Thankfully, this episode is over ;-)
OBY, I saw your response #15 Bump/Clunk. I wasn't sure what was going on since the problem was intermittent, but that TSB nails what's happening in my truck. The dealer serviced it per the bulletin, but it didn't fix it. I'll try again. Thanks again, Roger
Good luck with the bump clunk.
M.
I even had the service manager tell me that they added oil, my 2000 burnt 1 1/2 quarts. Then asked me what kind of oil I used. I told him Moil 1 - he looks at me, kind dumb, and says, "that's a synthetic isn't it?"; then went on to say, with even a stupider look, "I don't think the regular oil we added will hurt the motor."
Gives me a lot of faith in service.
Chris
The servicing dealer called today and said that he has the new latches in stock, but the new striker is still on back order. These parts are the fix according to the dealer service manager.
GM did a good job of keeping this problem a secret from the public. I did file a report with the NHSTA for the doors. I think it is a safety issue that GM does not want to acknowledge publicly.
As soon as I can get GM part numbers I will share them with all.
While you are in getting the doors fixed make sure you ask for the rear quarter window replacement. Thsi will take care of any wind noise you may be having. Another secret fix from GM, unless you specificly ask for the replacement.
Good Luck!!!
My wife and I are considering a 2001 Silverado 4X2 LS SB. If you have problems with your 2001, I'd like to know about them sooner rather than later.
Also, I'd like to know how the service is at the dealers? Last time I had to go to the GM service center at the local dealership...let's just say we sold the car and bought an Acura.
Lots of luck.
Chris
Regarding your question, do you have a 4wd or 2wd?
AND I have a 4wd Z71.
1. Notice the engine has an intermittent shake at idle
2. Does not have the 60-65 shake, steering wheel very stable, but notice some slight "hop" at lower speeds (say 30-40).
3. Wind noise, haven't tried to isolate yet.
Any recommendations on bedliner/mat, rail caps, deflectors, splash guards?
Your description of the problem sounds like the intermediate steering shaft as it's located in that area of your engine compartment. However, it's usually felt in the steering also when going over the bumps.
fried2
The hop, is it noticeable in the front or rear? Your intermittent shake would be diagnosed by dealer as normal. Wind noise, try checking between doors and rear ext cab windows. Good luck.
New wheel alignment. (Factory spews. were wrong)
Intermediate steering shaft was replaced. (This gets loose at 8K miles or so & rattles).
Steering box was replaced. (The power assist systems are not balanced & this causes a pull usually to the right).
Now there is no pulling to either side. My problem now is not enough caster! The tires are not tracking straight ahead well enough to satisfy me. Although VERY SLIGHT, I have to correct left to right on uneven road surfaces. When the dealer tried to increase the caster, camber, toe-in, the pulling to the right came back. The system is extremely sensitive to any changes. The Service Manager is still going through GM Etch System to get a solution to the problem.
ad
I am going through the same problem with my GMC, Short Box, Regular Cab, Z71. This is what the dealer has done so far & the results.
New wheel alignment. (Factory specs. were wrong)
Now there is no pulling to either side. My problem now is not enough caster! The tires are not tracking straight ahead well enough to satisfy me. Although VERY SLIGHT, I have to correct left to right on uneven road surfaces. When the dealer tried to increase the caster, camber, toe-in, the pulling to the right came back. The system is extremely sensitive to any changes. The Service Manager is still going through GM Tech System to get a solution to the problem.
Ed
#15057687 Latch, #15057688 Latch, #15063698 Striker. The Chevrolet TSB for this problem is 00-08-64-016 Located in section 08 under Body & Accessories.
Both right and left door are affected by this TSB.
Up till a week ago Chevrolet totally denied any knowledge of a door closing problem. In one week they have manufactured parts and written the TSB. Amazing!!!
Good luck with your vehicles.
ps. Did you ever find out if the Technical Bulletin I mention in my earlier message #45 would help you out in your situation?
