Visitor Agreement.
I believe the 2002 Silverados will start to be built this June, so you could wait and order one if your not in a big hurry.
My 2001 Silverado 1500, LS, ext-cab, Z-71, white/pewter, loaded, was built on Dec 6th 2000 and I picked it up from the dealer on Dec 19th. It now has 2878 miles on it, and it has been absolutely flawless. No wind noise, vibrations, clunking, rattles, shakes, or knocking. The truck sits level, all doors close properly even when it's cold out, and it is a pleasure to sit in even with 4 adults and 2 kids on a 200 mile trip. I couldn't be happier with my truck.
Just make sure before you buy your truck, you do a thorough check of everything. When I went to the dealer to get my new truck, I had a check list, and I spent 2 hours going through everything before I even when out for a test drive. And then the test drive lasted 1 hour while I checked out even more things.
I've got my new truck check list written up in Microsoft Word, so if you would like a copy of it, post your email address here.
-David
The dealer replaced the passenger side wheel inner liner to no avail.
Any Ideas
Sounds like you have the same problem I had with my 00 model. I also had chrome wheels and Goodyear tires. My truck vibrated also. As it turns out, I had a warped rim that the dealer said was not warped. I also had some bad Goodyear tires.
My suggestion is ..... Take your truck to a private tire dealer not connected in anyway with GM or its dealers. Have them check your rims and tires. It should cost less than $25. If they're warped, call GM and raise HELL. They'll pay the cost with a purchase order (they did for me) for the private dealer.
Some of those chrome wheels come from the factory bad or get warped somewhere along the way. The steering on the new model trucks is so sensitive that the smallest problem with a tire or rim will be felt in the wheel or seats.
Good luck....John
And no, this will not work on '96 and newer. Only works for OBDI systems.
Jim
The truck was taken to a local tire store because they had a load force balancer. They found one tire that did not pass their test and the dealer told them to replace it. No difference. I've been to all of the Chevy dealers within twenty miles trying to get this vibration fixed and am back at the original selling dealer. When I explain the problem to them and what was done so far, they immediately have the answer, balance the tires, tinker with the computer, replace half of the driveshaft, or just say it's not so bad. I've been through the BBB (waste of time) and their final decision was after four repair attempts was that although the vibration still exists, I should still let Chevrolet try to fix it. I rejected that decision and contacted a consumer lawyer. That was nearly three months ago which is beginning to look like another dead end. I made up my mind ten months ago that I would see this through and try to get Chevrolet to buy back this truck, but I'm near the end of the road, GM has more money and time than I do.
John
I've got a 3.73 limited slip.
Most of my towing is hauling race cars between shops. Thirty miles each way, at seventy mph.
I'll have my dealer take a look at it. Need to take it in for rattling doors and steering wheel cluck anyway.
Mag-Hytec cover? They have a web site? Sounds interesting.
Thanks for the heads up.
Scott
I might go for that for around 100 bucks. 240 is a bit to steep for a diff cover.
Scott
Any advice or experience would be appreciated.
Ken
Shudder occurs between 0-25 mph.
Thanks for the post on your new Silverado! Sounds great and Im glad that you have not had any problems with your truck.
My e mail address is jl_griff@yahoo.com
Jim
will probably continue to do so if this @#!$ thing doesn't drop into Drive when it's supposed
to. Took me about 700 miles to figure out what's going on but I finally discovered that the tranny
will stay in third and refuse to drop into drive. I even kicked it up to 80MPH, then let it coast
to 60MPH and it still stayed in 3rd. Had to shift it into neutral, then back to drive to get
it to drop into Drive. Happened twice on my last trip. Gotta keep a close eye on the tach when
going from a full stop up to freeway speeds. 2K RPM and all is well. 3K RPM and it's stuck
in 3rd. Back to the Dealer onFriday. At least I can explain it this time.
John
should I add a rear spring leaf or have the springs rearched or go with air bags???
the ride is getting more losey every day. dealer say it's in specs....
truck now drifts all over the road , 6 alignments, no luck. No tire wear, just will drift right then left,
then when a large rig passes you can hardly stay on the road.
Real scary to drive. started at 3000 mi. now has 14,000.
If it cant't be fixed, looking to dump it like the 99 that was so screwd up.
My father has his trouble free 2000 Silverado 1500 LS, 2wd, reg cab, long box, tow pkg, 5.3L, auto, 34 gal gas tank, lock diff, white, etc, and canopy for sale. Only 10,500 miles on it. He purchased it on 12/18/99, so still under 3yr/36000 mile warranty. He decided he needed a 4wd so he bought a new 2001 Silverado 4x4.
I've driven it and it is nice, smooth and straight, no rattles, no vibs and will be a great truck for someone.
Kelly Blue Book high is $23,000 and low is $18,500.
He is asking $19,995.
-David
This is the sequence of events which corrected my steering problems and may be the cure for others. Chevrolet & GMC are basically the same so I will post this in both forums.
BROUGHT IN TO GMC DEALERSHIP TO CORRECT AN OBVIOUS FRONT END MISALIGNMENT AT 7200 MILES.
Was informed that the original factory specs were wrong, two new tires were installed & new alignment specs were adjusted. The service Mgr. suggested a replacement of the intermediate steering shaft because after about 8000 miles or so, many developed a clunking sound.
A NEW INTERMEDIATE STEERING SHAFT WAS INSTALLED.
At that time the service Mgr. suggested a replacement of the steering box because of slight pulling to the right.
A NEW STEERING BOX WAS INSTALLED.
Now for the first time there was an obvious excessive free play in the steering wheel and no improvement to other problems. This free play caused the need to constantly correct left to right to stay on the road. This was an especially dangerous problem on windy days.
I BLED THE POWER STEERING SYSTEM BY TURNING THE STEERING WHEEL LOCK TO LOCK ABOUT 6 TIMES. (This should have completely eliminated air from the system.)
That cured about 80% of the free play. I then took the truck back to have the dealership eliminate the rest of the free play. I suspected a defective steering box. After about 8 trips back to the dealer with this problem, the service Mgr. suggested I contact GM (number in the owners manual) to get a GM service Tech. involved. I did get immediate response from GM by phone. A service tech. came to evaluate and to do what ever he could to correct the problem.
THE SERVICE TECH. CENTERED THE SECTOR SHAFT AND READJUSTED TO CENTER THE STEERING WHEEL.
The thinking was that this would cure the pulling to either side. It did not eliminate the excessive free play. So I still had a problem. From that point I had no response from the dealer about my problem for over 3 weeks.
The next step accidentally cured the free play problem. I had to turn a loaded trailer around in a very narrow driveway. This took a lot of steering wheel turning.
I HAD TO TURN THE STEERING WHEEL LOCK TO LOCK ABOUT 30 OR MORE TIMES. THIS ELIMINATED THE AIR FROM THE SYSTEM AND CORRECTED THE FREE PLAY PROBLEM. The steering now operates the way it should and there is also no pulling in either direction.
Sorry for the long post!
Ed
Unless you're going to get the truck for about $1000 with a 100,000 warranty, I would run the other way! You're asking for trouble buying a buy back.....and by-the-way, don't believe a word the dealer says about the truck. Ask the dealer for the original owner's name and number....or call the BBB and give them the VIN number and have them track down the original owner. Don't the let the dealer tell you that the information is not available....that would be BS! The dealer can print out a vehicle history of the truck, including the buy back information as well as the previous owner. Find that guy, or girl, and asked about the truck.
Good luck....John
I hope the check list provides a little help and peace of mind that the truck your are buying is a good one. It did for me.
2950 miles, 4 months and still not one single problem what so ever with my 2001 Silverado LS, ext-cab, Z-71, loaded.
No rattles, vibs, shakes, knocking, leaks, squeaks, or wind noise. It drives straight, sits level, and is just a pure joy to drive. I'd buy this truck again in a minute.
-David
I've got a 2000 Ext Cab, one that has the infamous 70Mph+ shake. Early on in the game with the dealer service, I suggested tires and/or rims. I was ignored.
Well, after rebuilding the front suspension, a new propeller shaft, and numerous balancing attempts, they agree last week to try a different set of tires. So, the service manager took all four tires and rim off his "demo truck" and put them on mine.
HOLY COW! I was driving a totally different vehicle. No shake whatsoever. At any speed up to 90+ (I'm too chicken to go faster
Well, I'm back to my original tires, and they are now going one tire/rim at a time to fix it. Right now I've got one new tire and new rim, and still have the shake. Apparently we haven't found the bad one(s) yet. But, it's the weekend, and I'll be back there on Monday ready for tire/rim #2.
One question did come to mind. My tires are Uniroyals, the ones we tried from the managers truck were Generals. I wonder if there is a particular bug with the current tires that any of them will have problems? I'd like to go back to the Generals, mainly because they were 255s, and I had 235s. But then again, the problem may be due to rims and not the tires? Painfully difficult problem to fix, but at least we know the solution now.
Anyone else have experiences on this?
our '01 had an ever so slight vibe at around 45 mph, but after a couple hundred miles it disappeared. it has 3,000 miles on it now and been flawless.(knock on wood)
red
All three sets of General tires had feathering. AS General kept sending new sets, we figured that it was a tire defect. On the final set, the dealer agreed to upgrade to Michelins. After 4k miles on the Michelins, feathering started. Dealer checked alignment at least 4 times. Being an unbeliever, I had a friend who owns a shop with an alignment machine check out the alignment. He said that the dealer was telling the truth when they said it was within specs and that the feathering could be attributed to driving style, the heaviness of the truck's front end, and the need for rotation at earlier intervals. Coming from a friend, I had nothing more to say on the matter. He swapped the fronts and within a 1000 miles, feathering is gone.
Now on my '00 Denali which weighs close to 6000 lbs., well you should see the feathering on the Michelins on that one after only 2500 miles.
http://209.35.112.209/performance/messages/96343.html
