Apparently it leaks internally, so the gunk on the outside is just patina, as they call it these days.
Messed up and went to the UP Craigslist this morning and wondered why there were so many rusty beaters for sale. Did find this for @xwesx.
This Caddy is more like it.
VanNatta Truck Museum
Oh, heck yeah! Hey, would you mind driving it up here for me, Steve? My schedule is a little tight right now....
I kind of like the paint job.
1999 Crown Vic. Oh my... po-leeze.
Tyrod, Barrens
Classy.
Each in its own way.
-Mathias
1950 Chevrolet Styleline Deluxe
This CL Chevy looks like a good driver with a few updates. Looks like it has the optional oil filter (ours didn't) and even though the seller doesn't mention it, the alternator and ignition indicates 12V upgrade. Upgrades are welcome as long as all are sorted out. Seller posted engine bay pics with the + batt cable disconnected and missing valve cover cap. Hmm... I do like the car but not sure I'd want to relive the 1950 experience for the money asked. Spending about $10k or so now can open up a lot of choices. For some reason I really like this '72 custom F-100.
I always have to wonder why people feel compelled to convert old cars to 12 volts and replace generators with alternators. Yes a 12 volt system with an alternator is "better" I suppose but on those cars with few accessories, the old 6 volt systems worked just fine.
Back in 1986, after my Granddad sold his '53 DeSoto Firedome, the new owner tried to jump start it with a 12 volt car, and fried something in it. I never knew how badly it got fried, but the guy pushed the car to the edge of the woods in his back yard, and, as of Christmas 2013 at least (last time I was down that way), it's STILL sitting back there.
Could you use a modern battery charger on a 6-volt car? I guess the 50-60 amp "quick start" mode might do some damage, but what if you just left it on the 12 amp or the 2 amp?
I suppose you could use a resistor of some kind to drop the voltage but otherwise, you would have to change all of the light bulbs or they would quickly blow. The radio and fan motor would have to modified somehow.
Giving 12 volts to a 6 volt horn makes for a LOUD horn! If it isn't used much, it'll last for awhile. I once heard a Model A horn that was hooked up to 12 volts and it was so loud you could hear it for blocks. That old Chevy had vacuum wipers so no problem there.
We used to jump 6 volt cars with 12 volt cars and nothing ever happened. If you had your foot on the brake pedel the bulbs would blow. You had to make sure everything was off.
Again, I just don't see why people think this is necessary. The old 6 volt systems worked just fine in the day.
Price is a bit high for a #3 car. For $10K, you should get "local show" quality and this is just a bit off from that.
Regards:
Oldbearcat
But who knows how to fix these now? All of the old guys who used to know how to shim and adjust those rod bearings are all dead or long retired now.
Also why, in your opinion, did Chevy continue using inferior bearings for so long? I assume the reason was cost, but there may be another reason.
http://en.wikipedia.org/wiki/Babbitt_(metal)
And here's what an 'insert' (also known as a 'plain') bearing looks like:
I remember an old shop that had a fixture so they could align the little dippers correctly.
And those bearings weren't THAT bad, really if you drove at sensible speeds and, once again, had them adjusted if they started to knock.
Of course, in those days engines were typically overhauled around 60-70,000 miles. That's after your 40,000 mile valve job. If you somehow made it to 100,000 miles you needed a rebore for sure!
So maybe the bearings in the old Chevy 6-cyl engines were another example of this?
Ford and Mopar, being smaller companies, didn't have the vast resources that GM did, so they had to standardize a lot of things much earlier on. It almost sounds contradictory, but GM, having more money, could afford to cheap out on the Chevies! But, then they'd often make up for it in other ways. For example, it often looked like GM threw a few more bucks into a Chevy interior, compared to a Plymouth equivalent.
Regards:
Oldbearcat
I'm not an expert on engine wear, but my guess is that modern oils, particularly synthetics (even though oil change intervals have been extended), fuel injection (less cold start cranking) and lower numerical axle ratios are three factors that have contributed to the extended engine life in modern cars. Any other factors? Better machining, resulting in closer tolerances, maybe? Have improved oil filters played a role?
I imagine the overdrive option, on models that offered it, was one way to extend engine life, back in the day. Of course, it only helped when it was engaged at highway speeds, which was generally when the engine had reached normal operating temperatures. That was only a fraction of the driving time.
http://southjersey.craigslist.org/cto/4712623481.html
Saw an El Camino today. Looked in pretty good shape but the string of LED brake lights around the rear window didn't do anything for me.
