Just so this is clear, unlike your experience, there will be Michelin tires that do not squeal, and General tires that do. It is more connected to alignment and road surface than to tire brand.
But if you want to look solely at tires, then complex tread patterns - especially tread patterns with open shoulders (common in all season tires) - are more likely to squeal than simple straight ribbed patterns. But there are enough exceptions to this to render what I just wrote as not a good rule because the texture of the road surface plays a HUGE role in how the tread pattern interacts to generate noise.
I'm looking to replace the tires on my '07 Ford Expedition EL. I'm planning to make a 1,000+ mile round trip across the desert in 40C heat next weekend (on highways, not dunes!) so I want something that's good quality but not too expensive because I'm skint at the moment.
I went to a local dealer who didn't have the original Pirellis I was looking for but suggested Cooper Tires at $50-100 each less than the Pirellis. I'm from England so I've never heard of Cooper - are they any good? Or should I spend the extra cash on the Big Ps? Any advice or Coopers testimonials gratefully received!
TIA
We have local guy we use, he charges maybe $20 per tire more than tire rack's price, but then there is no shipping and he charges about $10 less per tire for M&B, if you buy the tires through him rather than bring in tires from tire rack. He is not a tire shop, but is able to get about any tire we want from his suppliers within a few days.
Incidentally, the guy I got the Continentals from said that the Coopers sold here in Saudi Arabia are actually retreaded refurbs imported from the UAE and aren't any good. I would be interested in finding out if this is actually true.
For at least some rebates, it does not matter where you buy. Michelin does seem to often say something about having to buy from selected dealers. Tire rack is good for learning that rebates exist, I found out about one on Continentals there that I got, but you could buy tires anywhere for that one.
But one thing that tends to even things out, many stores give you free rotation and sometiems balance when you buy from them. With a TR purchase, I have to pay for that every 6 months. So, gotta factor that in.
My Corolla tires are rotated:
DriverFront goes to DriverRear and viceversa
and
PassengerFront goes to PassengerRear and viceversa
Therefore tires always spin in the same direction.
Other car's tires are rotated in a crossed (X) pattern, which end up with the tires spinning in the opposite direction. I've heard that if certain tires--which are meant to be rotated like my Corolla's--are rotated in a crossed (X) pattern, spinning in the opposite direction may debilitate and break down the tire structure. Is this true?
Thanks in advance,
Richard
Just picked up an '02 Audi A6 that hasn't been driven in at least 4 yrs - I had to have the car flatbedded to my house. Close to brand new Toyo Proxys are mounted on BBS rims but 3 of the 4 will not hold air. If I have the tires remounted and balanced, will that result in the tires holding air? I do not see any cracks or dry rot.
Thanks for any advice you can provide.
However, I would be concerned about flat spots on those tires. They might never roll naturally again.
Might as well do it now!
of the wheel, not the tire
If I were you, I'd get the car running and drive it around a bit to see if its going to hang together, before I put new shoes on an older Audi of unknown qualities.
I won't even begin to talk about all the engine seals and rear diff seals that are leaking and need replacement on this 2.7T A6. The guy absolutely did no maintenance on this (what once was) a really nice car.
I'm going to get it going and see about getting the TB changed and new seals installed by a mechanic on the side; or, maybe just drive it for a bit and trade it after I detail it - I did pick it up cheap.
Question - all these expensive 17", 18", 19" and 20" rims with low aspect tires must get bent all the time - incredible considering the cost of these. Particularly here in the Northeast where the roads are terrible. Do guys just keep buying replacements? 15" to 16" appear to be a no brainer.
The 2.7T models may have bigger brakes to handle the increased speed/power... and, may require 17" wheels...
We've been driving with 17" rims for the last 7 years... and, no problems... My latest buy has 18" rims..
cheaper than a new one!
What maintenance is there to do that would have anything to do with leaking seals?
I am a nOOb when it comes to cars. Just recently during a service I learnt my car tires were in 'dangerous' state with treads of front 1/32, 1/32 and back 2/32, 3/32.
Now I did a little homework and figured newer tires have a tread about 10/32 or 11/32 so I have the following questions:
a. How bad is the condition of the tires - Do I need to get them replaced yesterday or can it hold off a week or so
b. Based on looking around, I can either get Michelin Radial X in a couple of days OR I can wait a week and do a special order and get Michelin Primacy (which are pricey) but I really don't know which ones to go for. Is Radial X considered a decent type or should I spend a little extra and go with the Primacy or other recommendations?
Any recommendations on good tires- I live in a snowy region, drive a camry and don't do lots of freeway drives but only once in a while (a couple of times a month tops)
c. Do all 4 need to be replaced in this condition?
Any suggestions, ideas are much appreciated, thanks!
I would not recommend any long drives, and would be concerned a bit on wet roads, but a few more days probably (but no guarantees!) won't kill you. I just would not push it too far.
and you certainly should replace all 4 in that condition. And of course, get your alignment checked.
For your usage, any of the michelins should be fine. Is the radial X a costco only model? I know they had a model with their own name, but not sure which tire it was.
There are plenty of other options that will cost less money. You can check tirerack.com for options and reviews. Consumers reports also tested AS tires earlier this year.
I put BFG Advantage T/As (from BJs) on my Acura TL, and so far they have been excellent. And were a good price.
I don't have any freeway drives, just a few miles to work and within the city for now
Radial X is at Sams, the only reason I mentioned those were because those are available right now with them. I have a trip coming up over the weekend and was debating either holding off (placing a special order for one of the other tires) and renting a car for the weekend OR going with Radial X and go for my trip.
Sams does have BFG T/A and Slalom but I read some reviews on the Michelin Radial and it sounded pretty decent in general. Radials are about 95$, T/A's around 75$ and Primacy are $118-$150. I don't mind paying for the radials but just not sure if I should go up to Primacy type higher end tires or not and if it is significantly different for my purpose.
you will be amazed by how much of a difference the new tires will make, especially wet grip.
1. Michelin Weatherwise II - $550 with taxes (Sears)
2. Michelin Primacy - $560 with taxes (Sears)
3. Michelin Radial X DT - $470 with taxes (Sams)
I live in a snowy region, this is for a camry, I don't quite care about "sporty" features, though I tend to drive a little rough once in a while. Don't do long distance drives, maybe once or twice a month, mostly inner city driving.
Any suggestions are much appreciated!! Thanks in advance!
Could you take a look at the tire choices I have and comment if you know about these tires? I have the option of getting any of these prior to my trip.
To me, the other two the Weatherwise or the Radial X DT, look like the way to go. Long life, Michelin build quality, all-season design. No one ever will say you made a mistake buying Michelin. They make a good tire and either of these will probably serve you well. I'd go with which ones you can get put on the car before your trip. They look comparable to each other, to me. Go with whatever is the better deal, which looks like the tires from Sams.
YMMV, not responsible for any misadventures, poor tire wear, etc! Good luck! I think you'll enjoy the feel from having new tires on the car.
You are correct, I am not running separate tires. Thanks for your feedback about Primacy, I was thinking those were the good high end but from the sounds of it they won't do much good in winters.
I am torn between Weatherwise and Radial X DT. I don't mind paying the extra $$ as long as I am getting a better quality. But if they are pretty much the same kinds then I'd lean towards Radials. I was reading about weatherwise and noticed that it got good reviews for handling in Snow and overall performance as well.
Both have about the same mile-warranty so it pretty much comes down to which one is worth the $.
Any other thoughts on these 2 that might help me make up my mind?
Thanks again for taking the time to respond, I really appreciate it!
I found my Michelin seller which is a large chain in the immediate area was willing to price match on identical tires, but they wouldn't match Sear's different tire under a different name. I don't recall about Discount Tire's policy.
Most places are wanting to sell tires. And I believe Michelin has had a $70 rebate for 4 tires and I think one chain has another add on rebate from that.
Might be worth some phone calls. I personally like to show up at the store with my suede covered checkbook sticking out of my shirt pocket, hinting I'm not going to use credit card and cost them a service fee.
The WEatherwise II has 10/32 tread depth. The other two have 11/32 each. I learned that when I was cross-shopping for my Harmony tires.
I personally never trust Sears. This is just another example.
Michelin's site page. SEarch under "Find by Name." Then choose "Specs" to see the depth and ratings for each tire size for that particular line.
http://www.michelinman.com/tire-selector/tire-search/
I've never bought tires from either vendor, prederring to deal with smaller, locally owned shops, but I know lots of people buy tires at Sam's.
But I am reading around and am not seeing a strong review regarding handling in Snow.
I am not looking for snow-only tires but would atleast want it to work well in those conditions.
I am pretty much down to picking between Weatherwise II and Harmony now...I could also wait a bit if Radial X is Highly recommended. Any other thoughts to help me decide?
Thanks for chiming in guys!
I later put Harmonys on my 03 leSabre replacing the Symmetrys that came on it standard due to the 16 inch wheels and Celebration package. I have a Cobalt with Hankook tires (made in China) and I checked depth and satisafaction with them. I would put Harmony's on it in a flash at the least problem.
But I suspect that is due to the tread design and the DEPTH of the tread. It was my personal opinion that the Sears tire had a more closed design with more tread area contacting the road, leaving less open area for water handling and snow grip between the rubber parts. That extra coverage of rubber area wise compensated for smaller depth and gave the same treadwear rating. The Agility tires were very similar in open tread design to the Harmony.
I looked for the rebate and it may have expired in early August. Try price shopping with various stores that sell Harmony and see if you preferred store will honor it. Some say stores will meet TireRack's price.
Compare openness of tread:
WeatherwiseII
Harmony
Destiny
X-radial
thanks for the detailed description and sharing your experience of using harmony in the snow!!
I did remember something that I am planning on moving in the next year or so and don't want to lose the "free lifetime balance + rotating" that the bigger stores offer. I am not sure if that is important enough that I stick with the big shops so when I move to a different city, I still have access to those stores? If they are going to charge me 20$ each time for this and I'll probably be getting it done about 10-15 times, maybe worth it to go for a bigger store?
That kind of narrows down my options to either Sams Club (Radial X) or Sears (Weatherwise). I know I've been flip flopping on my choices but if I didn't have the urgency to get it replaced I would've done a special order in these locations or ordered online.
So between Radial X and Weatherwise II, do you have any experience or heard from anyone about their quality? Going with Radial X is about 80-100$ cheaper overall but the cost is not my highest priority. Getting good tires for my situation is a priority.
Thanks again for your feedback everyone!
Not every community has a nearby Sams Club.
I believe Walmart can order in any tire for you. Walmarts and their service are everywhere. Walmart does carry the Symmetry by Michelin. It's a luxury tire tread with lots of small pieces that lead to a quieter ride.
Personally I wouldn't buy a dead cat from Sears Auto Centers. You may have one near you that you feel is good, but the next one down the road may not operate that well.
Sears was doing the rotation and balance for my X-Ones after NTB closed all stores in my area. Sears inherited the lifetime because they owned NTB. After hot rodding the nuts on and off the studs many times, they were doing the new struts I had bought through them and a nut jammed on the stud. They replaced the stud which is what they should have done. They didn't put the air connections on the rear struts correctly and when I loaded the trunk with mulch, the air leveling system on the rear blew off the hoses. They fixed that.
But later they jammed a nut they had cross-threaded earlier and hot-rodded on with their air guns. It was partly on. They told me I had to pay for their jammed nut and damaged stud problem. I told them to put the nut tight again and I drove home. They said they would do so. But I drove home on 4 studs.
They did NOT tighten the nut because they were afraid they'd twist the stud off. I've been on a crusade against their minute oil change quality mechanics since them. The local store has an almost empty parking lot for the auto service. I hope I've helped direct some people to a better store and save other people trouble.
The threads should have been cleaned occasionally and driving the nuts on fast tends to build up heat and tighten them worse with any grit present. Cross-threading them does even more damage, which is what the previous Sears rotation caused.
I like the fact they have a somewhat better quality tire but now I am a little wary of their service. Online reviews are not very gentle either. Sams doesn't seem to have as much negative chatter online for their Auto-service.
