Graham - it is a European body shell used in South America but not Peugeot. The upper grille section is relevant - think of a European car with an upright central radiator grille and side grilles ....
Yes - Kaiser Willys is involved.
This was an Argentinian assembled car, made by the former Kaiser plant which had built Kaiser Manhattans there after the US firm stopped production and they knew that model as the IKA Carabela (Industrias Kaiser Argentina). They also assembled Jeeps..
In 1960 they took the dies and presses from Alfa Romeo for their discontinued Alfa 1900 saloon and assembled a locally made version with a Willys 2480cc engine and stronger suspension and this car was called the IKA Bergantin. From 1961 it was also available with a Continental six cylinder engine but they only built a couple of hundred of those.
The Bergantin was a limited success - they built over 5000 by 1962, but by then were also assembling Renault and Rambler cars so this model ceased production.
Your brochure extract shows how they elongated the car compared with the other more dumpy shape of the original = particularly the rear wing..
Probably an S65.
Here it is again Wrench>
Please explain.
IIRC an outside left hand mirror was optional on nearly everything back then. Only a few had it available of the right side as an option.
'59 - side to side.
'60 - front to back.
It was a cut above the Jaguar, and of course below the Bentley.
