Yeah, I really don't know how to use the data. In addition, I have a hard time seeing the colors on those thin lines, so the whole thing just sort of blurs together for me (even when large). However, the fuel trim percentages seemed really high, but that's not much to go on if you can't figure out why their so high. LOL
Clearly, though, given the complexity of the electrical systems involved, it pays (or maybe doesn't!) to understand how those systems work at least as well as understanding the mechanical systems. And, not just the ones you may *think* are important.
On what sort of system does this software run? I assume that it is just operating on a Windows machine (or similar) with an OS and other software present. If this is the case, a video screen capture program such as Fraps or Camtasia might be very nice for capturing short moving segments of the data stream.
Not that this would be of any use to me (or most of us here), but, for other educational purposes, it may prove useful!
One of the more interesting parts of the conversation revealed that he is on the zoning committee for our town. I asked him if someone wanted to open a shop in town, where would it go. The answer is there cannot be any new shops in town because they can only be in the buildings in town that currently are shops. If any of us shut down they have one year to get another shop in the building, or else the town will lose that business forever as most of us are grandfathered in where we are at, but the site loses its exemption if it goes vacant. That's what is going to happen to that shop across the river too.
Every gas station had a "Mechanic on Duty" sign and today the repair bays have been turned into mini marts.
Even in the suburbs this is the case now.
"Investigators believe the explosion was caused by liquid propane gas leaked through the fuel pump of a commercial truck that was being serviced Monday afternoon.
Mechanics had emptied the tank before working on the truck but some of the gas remained, Medlin said." (Globe Gazette)
At least the shop is sticking to the party line about oil changes:
"Oil – Change your oil and oil filter as specified in your manual—more often (every 3,000 miles) if your driving is mostly stop-and-go or consists of frequent short trips"
Driving with windows open could actually aggravate his exposure as pressure differentials could suck fumes into the car.
BTW did you watch the video? See the TPMS lamp on?
As for the video, it didn't work for me this morning either. It did work a minute or two ago, though, with a bit of patience on the load.
Hey, the writing was on the wall here. Heck, even the car was practically screaming for them to get away!
When I was at the counter, the service advisor said they couldn't figure out how to get the TPMS light to turn off. He was trying to look it up online. I advised him that it would turn off within about ten minutes with the car running. He was doubtful, but deferred to my knowledge as the owner and assurance that it really was not a problem. I paid him and drove off; the light turned off a few minutes later.
As for the TPMS, my E90 has a reset button, so there's no problem switching to winter tires with TPMS; the Mazda doesn't need a reset at all- just switch tires/wheels/TPMS. While looking at STIs I've read that new TPMS have to be coded to the car. I'd hope not.
I will say, though, that I am pleasantly surprised by how reliable the sensors are. I haven't touched the sensors on the 2010 for any reason, and yet they still work just fine after 6.5 years. Or, the light doesn't come on without cause anyway.
In fact, I've never seen the 2010's light come on for a low pressure situation. I keep my summer tires at 35 front and 40 rear (due to frequently carrying heavy loads) as a baseline. When we did our transcontinental trip, I set the rears to 44, which was the upper limit stamped on those tires, because we had a really solid load on the car for all 12.5K miles of the trip. The only time we had a TPMS light was through Saskatchewan when we were running at about 75 on the Yellowhead in 100-degree heat. When I checked the tire pressure, the rears read upper 40s, so I suspect that the light was saying the pressure was too high.
This should work.
http://www.cnbc.com/2016/01/22/first-gm-ignition-switch-lawsuit-is-dismissed.html
Furthermore, in pilot training one is required to learn how the aircraft works, and do maintenance pre-checks (fuel levels, oil level, controls, surface inspections, etc.) before climbing in.
Then after you start the craft you have to perform all of the pre-flight checks ensuring all the switches are set correctly, oil pressure is correct, choke heat is set, mixture full rich, landing light on, throttle up and confirm manifold vacuum in range, charging system voltage correct, fuel gages correct with what you manually inspected before you got into the craft (Plus anything else required in the flight manual). Then and only then are you supposed announce your flight intentions, check for traffic, stage and then take-off. (Note: variations depending on whether you are operating from a controlled airport or not)
If drivers were trained to operate cars the way pilots are trained to operate aircraft, it still wouldn't solve all of the problems but it would solve most of them because pilots are trained to accept that the vast majority of the problems are either caused by the operator, or failed to be prevented by the operator through negligence. There is no whining about oil specs because another brand is ten cents or even ten dollars cheaper. If you want to work on an aircraft you are required to be certified to do so, and while there are some who consider themselves above that, there are significant penalties should fate ever catch up with them.
Automotive technicians have a twenty year growing phase before they really master their craft, but the learning never stops. There is always something that one has never seen before and the only right way to deal with that is an experienced, disciplined approach that consumers have been trained to not support.
