I saw that one of the car magazines had to have the transmission in their long term Pilot replaced at just over 21k.
Not sure if the Ridgeline has the same one.
the new look is all about trying to come across as Macho and tough, practicality be darned.
Stopped by a multi line dealer today that has Audi Ford Lexus and Porsche.
I was looking for a Ford.
On the remote lot, where most of the Fords are, I saw 4 Audi's up on bricks, with no wheels/tires.
An S5, A6 and 2 TT's. Guessing the TT's were performance models as they had quad exhaust pipes.
Lot of money gone there.
Doubtful we'll see the Germans or the luxury Japanese brands do this, however. Too much cachet in the brand name, not the model name.
easy to know how to compare a 3/5/7 series. Or a C/E/S class..And X or Q signifies the SUV version.
IMO, does not work the other way, when everything starts with say XT like Lincoln, and there is no apparent logic or consistency to the rest of the name.
and names can be just as bad, unless they are clearly established, and don't change (civic/accord, Malibu/Impala). coming out with new names frequently is just as bad, though maybe easier to learn.
I guess it really is Caddy and Lincoln that are causing the problems.
Names changing over time ended up being an issue for domestics. In 1957, a Bel Air was the top model, in 1959 a Galaxie was the top model, and so on. By 1970, both of those were not the top model. Bumping a name down in rank doesn't help with equity. The same braintrust who brought the weird structure to Infiniti has brought it to Caddy.
Why not just leave the Q off?
Basically, you put the car in reverse, press this thingie/button, and the truck goes into high idle speed, and a camera shows you a top view of your trailer on the dash screen. Then you use the rotating thingie/button to actually steer the trailer as the truck moves backwards. "It" knows the type of trailer and all the important dimensions because you plug those in beforehand for your particular trailer (tongue length, width, etc).
I'm pretty good backing up trailers already but for some folks who haven't practiced--they really suck at it.
Over the years, one friend jack-knifed his camper on a freeway bridge blocking the two northbound lanes, two friends dropped their jet boats off their trailers in the middle of busy intersections and another guy had his utility trailer pass him and wind up in a field a half mile ahead of him.
Should be a towing endorsement required on the driver's license for those who pull trailers. Check the safety chains when you see trailers in parking lots - rarely will you see them property hooked up.
And if you see someone toting firewood with a homemade trailer made from a pickup bed, yikes!
There should be endorsements for many types of vehicles. As it stands today, I can use the same license to drive a Smart or a 42' behemoth motorhome or a 1000hp Veyron or a relatively large rented box truck, but I need an endorsement for a 250cc Vespa. Someone bought their laws.
Let's just say, the instructions were minimal. Mostly where the key went, and how to put it in gear. And off you go.
man, they were so much fun to drive. Just not on tight city streets.
3 Rav4's, Honda minivan, Ford Explorer, Lexus ES350.
