2017 Ram 1500 Lease Deals and Prices
MichaellMichaell Moderator Posts: 271,155
edited September 2017 in Ram
Ask your 2017 Ram 1500 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2017 Ram 1500 here
«13456713
  • jeremy_b4jeremy_b4 Member Posts: 14
    Any numbers available for 2017 models yet? Specifically looking for Express Crew Crab 4x4 36/15.
  • MichaellMichaell Moderator Posts: 271,155
    .00001 and 51%
    Wow,  drastic difference from a few months ago on the residual value for the exact same truck except a 2016.     Can you tell me which  trim levels are holding the best residual for the same cab in a 4 x 4 at 36/15?
    Ah, but the MF is higher on those trim levels, to offset.
    For example, the 36/15 residual on the Laramie crew cab is 53%, but the MF is also .00053.
  • jakem250jakem250 Member Posts: 8
    How about MF and residual for a 2017 Big Horn 1500 in Nebraska?
    Thanks in advance!
    Sorry, interested in numbers for both 12k/36 and 10k/36. Also 10k/39 if you have it
    We were seeing .00008 and 59% on Express Crew 4x4 at 36/15, that's a huge difference from where it is now, or am I calculating things incorrectly?
  • kyfdxkyfdx Moderator Posts: 276,317
    Thanks in advance!
    4X2 or 4X4?
    Which cab configuration?
    For December, we are showing:
    .00002 MF and 51% residual for 36/15
    .00002 MF and 56% residual for 39/15.
  • reese917reese917 Member Posts: 11
    edited December 2016
    2017 Big Horn and Laramie, crew cabs, 2wd, 15k miles, 36 or 39 months, Louisiana. Please and thank you.
    Big Horn - .00001 and 49% (36/15) or 51% (39/15)
    Laramie - .00065 and 53% (36/15) or 51% (39/15)
  • potstillpotstill Member Posts: 26
    MF and Residual please in CA on 2017 4x4:
    Laramie, Laramie Longhorn and Limited (V8 and V6 Diesel if that matters) crew cab shortbox
    24/36 month-- 15K per year
    Laramie - standard MF (around .00200) and 58%
    Longhorn - standard MF and 60%
    Limited - standard MF and 54%
    Laramie - .00039 and 53%
    Longhorn - .00113 and 54%
    Limited - .00022 and 48%
    thank you!
  • anderm30anderm30 Member Posts: 123
    Hello, can you give the 36/12 numbers on a Laramie 4x4 Quad Cab in TN? Thanks!
    .00008 MF and 51% residual
  • powercatjeffpowercatjeff Member Posts: 20
    What would the numbers be for a Ram Rebel v8 with a crew cab.
    36/12k. And 39/12k. Kansas city area.
  • jdmdc5jdmdc5 Member Posts: 67
    Hi guys,
    Looking at a 2017 Ram Rebel 4x4 Crew - I think it only comes in one config.
    5.7 Hemi
    MSRP is about 53k
    Located in NY
    Would like to know Money Factor and Residual values for...
    36/15k year
    39/15k year
    36/12k year
    39/12k year
    Thank you so much!!
    4x2 or 4x4?
    jdmdc5 said:
    Hi guys,
    5.7 Hemi
    MSRP is about 53k
    Located in NY
    36/15k year
    39/15k year
    36/12k year
    39/12k year
    Thank you so much!!
    .00017 and 49% (36/15) or 53% (39/15). Add 2% for 12K
    Hi guys, Looking at a 2017 Ram Rebel 4x4 Crew - I think it only comes in one config. 5.7 Hemi MSRP is about 53k Located in NY Would like to know Money Factor and Residual values for... 36/15k year 39/15k year & 36/12k year 39/12k year Thank you so much!!
    Thank you again.  When do these expire? How often should I check back for new figures?
    jdmdc5 said:
    jdmdc5 said:
    Hi guys,
    5.7 Hemi
    MSRP is about 53k
    Located in NY
    36/15k year
    39/15k year
    36/12k year
    39/12k year
    Thank you so much!!
    New program is effective Wednesday, 01/04/2017. Numbers update monthly
  • scruffy222scruffy222 Member Posts: 34
    Looking for residual and mf for 24month 12k and 15k
     Laramie 4x4 crew
     Big Horn 4x4 crew
    Express 4x4 crew
    in Ohio
    also any lease cash? Returning leasee money?
     Laramie 4x4 crew
     Big Horn 4x4 crew
    Express 4x4 crew
    in Ohio
    24/15
    Laramie .00014 and 58%
    Big Horn .00010 and 56%
    Express .00019 and 58%
    Add 1% for 12k
    4x2 or 4x4?
    Sorry 4X4
    4x2 or 4x4?
    Sorry 4X4
    .00017 and 51% (36/12) or 55% (39/12)
    Wow thanks. Ram lease deals are not what they were 2 years ago. I leased my current 2015 express crew 4x4 in March of 2015. The Residual for 24m/12k was 66%. Now the best residual truck(Laramie) for 24m/12k is 59%.
    It's possible Chrysler Capital was tired of taking losses on lease returns when the market value was thousands lower than the residual value in the lease.
    It's a bit of a balancing act, trying to figure out the right residual values.
  • burgers1999burgers1999 Member Posts: 7
    4x4 - 36 month / 15k per year
    Laramie, Lonestar
    Texas
    thanks!
    Laramie, Lonestar
    Texas
    thanks!
    CrewCabs, right?
    Laramie: .00039 MF and 53% residual for 36/15.
    Looks like the best program on the Lonestar is for 39 months.
    .00011 MF and 53% residual for 39/15.
    Laramie, Lonestar
    Texas
    thanks!
    CrewCabs, right?
    Yes, sorry Crew
  • smokerisessmokerises Member Posts: 14
    Ram 1500 Sport crew cab 4x4 in ny
    12k 36 month and 39 month
    15k 36 month and 39 month
    .00012 MF and 50% residual for 39/15.
    Add 2% to residual for 12K/yr
    36 month residuals are lower.
    24 or 27m/ 15k
    crew 4x4
    all trim levels
    residual and MF please
    2017 RAM Rebel 4x4
    Looking for money factor and residual for January.
    36/12 & 39/12
    Thank you in advance.
    jdmdc5 said:
    2017 RAM Rebel 4x4
    36/12 & 39/12
    .00005 MF and 56%/48% residual
    24 or 27m/ 15k
    crew 4x4
    all trim levels
    Between .00002 and .00026, though some trims use the standard MF of around .00200
    Residuals vary between 55% and 67% for 24/15. 27 month numbers not competitive this month.
  • qxbuzz75qxbuzz75 Member Posts: 14
    Sport CC 4x4
    Night CC 4x4
    Residual and MF for 36/10 36/12
    Rebates $500??
    Are the rebates expected to increase in Feb or Mar, and is there a $1000 rebate if I have a current lease on a Ram with Chrysler Cap.....?? I have two payments remaining and will lease another Ram
    Thank You
    qxbuzz75 said:
    Sport CC 4x4
    Night CC 4x4
    Rebates $500??
    Thank You
    36/12 numbers:
    Sport - .00015 and 56%
    Night - .00015 and 57%
    Add 1% for 10K
    No information on any Ram incentives for January.
    No prediction as to what might happen in the future.
    Hello, what are the 36/12 or 39/12 numbers (whichever is better) for a 4x4 quad cab and crew cab Laramie in TN? Thanks!
    Quad - .00005 and 54%
    Crew - .00013 and 54%
    39 month residuals aren't as attractive.
  • whel10whel10 Member Posts: 18
    Hi what are the RV and MF for an Express 4 X 4 Quad Cab 2017 with the 199/ month lease
    For 36 / 10 K per year ? THANKS JW<
    Previous comment location is Illinois Thanks JW
    For 36 / 10 K per year ? THANKS JW<</p>
    .00015 MF and 61% residual, if the deal is through Chrysler Capital.
  • mvzmvz Member Posts: 3
    Does the bed length have an impact on the residual?
    Just cab configuration
  • lovemychaoslovemychaos Member Posts: 1
    Looking for RV and MF on Bighorn 1500, crew cab, 5'7", 4x4, Minnesota
    Wondering if my quote is reasonable (first time leasing). Seems a bit high.
    $1000 at signing, MF .00055, RV 59%
    MSRP = 49010
    Price = 44,993 - 2000 rebate = 42,993
    MSRP = 49010
    I show .00014 and 57%
    Could be a third party lease company, given the rebate involved.
  • borovy3488borovy3488 Member Posts: 2
    edited January 2017
    Looking for RV and MF on Bighorn 1500, quad cab, 4x2 in Tennessee. 36/15
    .00014 MF and 53% residual
