JP4 is jet fuel. Oil analysis has been around for a long time. It is just that it has finally trickled down into the consumer market! I used to have an NDI or NON Destruct Inspection shop, of which oil analysis was a bread and butter procedure.
However, I still have trouble with the extended oil drain intervals, just doesn't "seem" right to let it stay in so long, you always feel you need to change it out just because of , what, tradition? Where did the 15k mileage come from?
Yours,
Yes as a percentage of crude used to make motor oil, it will go down. But as a percentage of crude oil used by a vehicle, it is insignificant.
If you take my 87 LeSabre that has averaged 23.x MPG over the last 18 months in urban driving, I would use about 44 gallons of fuel every 1K miles, or about 220 gallons every 5K. Compare that with the 4.5 quarts of oil even if it took 10x the volume of crude to make a quart of oil, the consumption of fuel is the biggest consumer of crude oil, and fuel was produced 1 for 1 out of that same crude. (IIRC, a 42gal barrel of crude produces about 50% of that same volume in gasoline, plus the other things produced in the fractioning stack. See http://www.wspa.org/chart7.htm)
However, I do agree that the disposal of waste oil is a smaller problem if one changed every 5K instead of Iffy Lube's recommendation of 3 months or 3K miles.
But lengthening oil change intervals really doesn't save much crude oil in the grand scheme of things.
FWIW,
TB
Oh, and it cannot exceed $0.15/mile to operate over it's lifespan. (I've had the Buick this long and that is the cost to purchase, fuel, repair, maintain and insure.)
Financially speaking, it doesn't make sense to trade the Buick for an econo box. That $700/year savings (if you could find a 46 MPG car) is more than eaten up in the acquisition costs.
That's better than my SVT Contour, a lighter car with a smaller engine and manual transmission, and I've never seen 30MPG in that car.
I say address the problem incrementally as well, but go after the biggest gains first. And since about 50% of every barrel becomes gasoline and another 20% becomes diesel or home heating oil, the issue of how much fuel is used has the greatest impact on how much crude oil is refined. When about 70% of the crude goes into fuels vs 1.1% of that same crude becomes a lubricant, it is hard to justify large amounts of effort and resources spent on cutting that 1.1% to one percent when you probably can get greater gains working on cutting the use of that 70% used as motor fuels.
Just like my financial analysis of the cost to run the Buick vs something like a Jetta TDI wagon, it doesn't make sense to go after the 1.1%
Gotta go fire up the Buick and head off to work.
TB
So for me, analysis is used just to see if my change interval is okay for the engine and mode of operation. If I changed oil every 3000 miles then totally a waste of time and money.
Yours,
Two are on an oil and filter every 7,500 miles regardless of time Amsoil 10W30 (6-12 months in reality) (80,000 and 147,000 miles)
One is on a 12,000 mile interval, filter at 6000 miles Amsoil 10W30 (31,000 miles)
One is once a year filter at 6 months Amsoil 0W30 (72,000 miles)
One is at 5000 miles or one year (last one was a year, doesn't get much use, a twin turbo toy) Amsoil 10W30 (21,000 miles for this 1997)
I may be switching one to Schaeffers 15W40 next time, the Amsoil regular synthetic 10W30 just is not holding up as well as I had believed it would.
Why Amsoil, well, 10 years ago it seemed like a good idea, dealer close by and where I live has a warehouse/distrubution center so no shipping cost. Today, I would also consider RedLine and definitely Schaeffers, Mobil 1 has always been strong.
I've been using a moly additive in my oil changes, called "Molyslip" here in Canada. "Seems" to run quieter and smoother with it, and cooler too in summer. Check out their web site, believe its molyslip.com.
Yours
Anyone who does oil changes will stand to lose money if people change their oil less often. They don't make their money on the oil. They make it on the labor.
I started at 3000 miles with the synthetic and, not believing the claims, had the oil analyzed at 3000 miles and gradually extended it out. When the wear numbers and/or TBN begin to look bad is where I set the change limits. Losts of highway driving and 12,000 miles works fine on my Buick, however, my Camry is about 7500, at 10,000 the oil seems to break down too much for me and everything seems to increase. So each engine is different and how you drive
The lab will flag the numbers that are high and make recommendations as to whether to change or not. Don't go by numbers generated by an engine under 20,000 miles though, most of the time these numbers will be very high due to the engine breaking in.
Appreciate for printing Blacksone lab's oil analysis. However, I have no idea what you are saying, ie Aluminum 8, iron 3, ????
Can you give me more easy understand about the test result like i.e.
Test Result Good Oil
Aluminum 8 Aluminum ?
Iron 3 Iron ?
So, you can compare what the lab is talking about.
I am sure you know what you are looking at it but I sure don't.
Aluminum = 2
Chromium = 1
Iron = 6
Copper = 2
Lead = 3
Tin = 0
Molybdenum = 0
Nickel = 0
Manganese = 0
Silver = 0
Titanium = 0
Potassium = 0
Boron = 79
Silicon = 8
Sodium = 4
Calcium = 918
Magnesium = 1196
Phosphorus = 760
Zinc = 825
Barium = 0
As I said before, the TBN being 8 shows that the oil still has life at the mile that it was changed. I will do another analysis after 20 K miles to verify that the wear metals in the oil have come down and that my drain interval is acceptable.
the averages given above are just way too low in my opnion.
Element 1st anyl. 2nd anyl.
Fe 8 6
Pb 3 2
Cu 4 10 ???
Sn 1 1
Al 8 6
Mn 1 0
Si 10 14
B 35 39
Na 3 3
Mg 396 346
Ca 3162 3127
Ba 0 90 *
P 1226 1212
Zn 1529 1517
All others tested were zero for both tests.
Other properties
Glycol Negative Negative
%Water <0.05 <0.05
%Fuel <1.0 <1.0
Visc @ 100 11.0 11.7 **
%Solids Trace Trace
%Ox 10.0 13.3
%Nox 24.3 22.9
TBN 7.0 11.1 **
No make up oil was used as the level had not drop visibly at all.
* I was using (playing w/ Marvel Mystery Oil) and barium is a known Diesel fuel additive. I suspect that's where this came from.
** The oil I was using previous to this was Mobil1 TS 5w-30 (very 'runny') and I made no effort to do a 'flush' before switching to the Amsoil.
Any guesses where the copper came from? No, I don't have an oil cooler.
Based on what I see here, I'm going to go to 7,500 miles next time.
Dave
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Have newer Ford Van >>> 4R70 Transmission
Any thoughts? Larry
Group III-- Severely hydrocracked petroleum
Group IV-- Natural gas
I believe that Group IV is PAO (like Mobil 1), and Group V is Other, mostly esters (like Redline.)
Group II and III are both hydrocracked, but Group II has a viscosity index between 0.8 and 1.2, and Group III has a VI greater than 1.2
ps This is all from the Bobistheoilguy FAQ.
http://www.exxonmobil.com/basestocks/pdf/Basestocks_Product_Brochure_US.pdf
Group 1-III and IV-V basestocks are made by two different subgroups within Exxon-Mobil. Group I-III are cracked down from petroleum, Group IV-V are engineered from lighter materials. Break down/ build up.
I've already noticed that the truck seems to run cooler, with the gauge running slightly below where it used to. Any other things to look forward to or be aware of? Also, the bottle of oil said that fuel mileage will increase, any thoughts?
Your mileage should go up app 2-5% if for example you go from 10w-30 to 5w-30 Mobil One, all things being equal of course. If you go from 5W-30 to 0W-30 you should see app 2-5% again. So for example I ran 10W-30W Mobil One and got 24 mph. Just on oil change alone it increased to 25.2. I also switched from a conventional ATF to the Mobil One ATF and not only was the shifting far smoother, but I got another app 1 mph more (actual .6 mpg) Mileage will of course vary.
If you're going to use a top quality oil then use a top quality filter. Mobil One filters are considered by many to be the best available. I like Purolater Pure One's myself; a few $$ cheaper too. Even the SuperTech filters at WalMart are surprisingly good - made by Champion Labs with excellent filtration specs. Check out all these.
Fuel mileage is a mysterious thing. A 2% change in mileage may not even be measurable tank to tank (on a vehicle that gets 15mpg, 2% = 0.3mpg). Gasoline producers are constantly tweaking their formulas and this can play havoc with mileage. With winter coming producers are changing their formulations now which in most states lowers fuel mileage a lot more than 2%.
5000 miles should be OK to go to on M1 but if you are really curious about how well the oil holds up the best way to know is to have the oil analysed. There are several outfits that do analysis for modest fees.
Hope all this helps.
I am also thrown off by the fact that my dealership service dept. has discouraged me from switching to synthetic several times. This shocks me since they would presumably make more money on that service. I wonder why they have talked me out of synthetic.
Opinions would be appreciated. Thanks.
As to the dealer not wanting you to switch, well, probably makes more money on dino, buys it bulk wheras synthetic is not used that much. Further, if you go longer between changes he will not see you as often to sell other services.
Thanks...
I really would like to use a synthetic lube in both cases.
Any insight ? Thanks a bunch.
rocky: I have heard that there is a special need a better lubricating oil for Honda. Also I have heard honda rips off its customers.
Ohhhhh yeah. I'm smelling a "delete" on the grill too.
