http://www.pecuniary.com/pecuniary.html
As you know, several oils contain moly out of the bottle, Mobil 1 does, as does RedLine and Schaeffers. The additive in Petromoly really isn't needed if you use these oils. As you also know, Amsoil does not use any moly in its formulations, just heavy zinc and calcium and phosphorus
mark.
Since your engine used either 5W-30 or 10W-30 before this new policy I'd consider using one of those weights. But be advised that this is against your mfr's direction and could result in a voided warranty if you have an in-warranty engine failure and they prove that you did not use the correct oil to maintain your vehicle.
That being said there is no way on God's green earth I would ever use 5W-20 in any car.
untill I T-boned a blond who was putting her make-up on. I swited to M-1 at the first
oil change and changed the oil and filter around every 7 to 9000 miles. I live in
northern Minnesota with temperatures down to -35. I never had any engine troble
(2.5 L.) . Was it the M-1 or just good luck??????. I now have a 2000 Cav, with
the 2.2 L. and you guessed it I useing M-1 again. I just wonder how many miles
I could have racked up on my 86.
Castrol synthetic and most of the time no one mention about the other brand.
Why? Are other synthetic motor oil not good or equal as Mobil 1?
Feed back shall be appreciated.
Someone quite some time ago posted a SuperTech Synthetic data sheet on this board. I requested one from Pennzoil but got only the SuperTech SJ dino sheets. That was last May. I think the synthetic data sheets were several years old. The synthetic sheets were nothing special.
There was a Bobistheoilguy.com oil analysis report on SuperTech synthetic. Unfortunately the poster didn't put SuperTech into his subject heading so that might take a bit of searching. I think the analysis actually looked pretty good. If memory serves me Terry Dyson did the test, but I might be wrong on that.
If you're ready to move up the food chain into a more specialized lubricant related board try:
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Then switched to Mobil 1 ATF in my automatic Camry and Mobil synthetic gear oil in my Tacoma manual transmission. The automatic Camry started shifting noticably smoother. Would now say that my 95 Camry w/ 73k miles and Mobil 1 ATF shifts slightly smoother than my 01 Solara w/ 12k miles and the factory ATF (both cars have the same drive train). On my Tacoma, the manual transmission became much easier to shift when I switched to Mobil 1 synthetic gear oil.
I'm pretty much sold on synthetic lubricants (have 50 quarts of Mobil 1 stockpiled that I bought cheap at Cosco).
IMHO the only way to go but each person must do what makes them feel right.
I lurk at Bob's also, now those guys are really serious about their oil.
tntitan, did you ever get around to your transmission???
Just waiting for the oil analysis. I am going on vacation next Saturday and hope they get here before then.
A.The Synerlec technology provides the best protection and performance increases available, however, it is very expensive. We have blended our street oils to exceed the performance characteristics of any other blended or "Full" synthetic. If having a full synthetic is important, we have our racing line which can be considered a "Full" synthetic.
http://www.synerlec.com/faq.html
Your input is welcomed.
Forget about using synth blends, they have very little synth in the blend.
Is this the same v6 engine Toyota was having the sludge problem with in other models?
I change once a year and only 8000 miles but it does go on long trips and heats up more often then yours does. With so many short trips the dino at 3 months is more economical and better protection. You will probably have high fuel dilution in the oil
Synthetic twice a year. Even if you pay $40 for a change that is still less than $100 a year. Not much to protect an expensive investment.
balance pulley) began to leak badly.
When I tore down the engine, I found the seal had "hardened" and was no longer flexible.
I was also using Amsoil. This was for a 1969 Mercury Montego, and I'd never had anything
like a seal problem. So, I switched the Maverick to Amsoil.
When I mentioned what I'd done to my Amsoil dealer, he had this explanation (whether right
or wrong, but it made "sense"): He described that mineral oil (Mobil 1's base is a petroleum
product) tends to harden gaskets and seals. He went on to say that Amsoil's base is "ester".
Ester, he said, was from the "alcohol" family. And, if you dropped a rubber band into
a jar of alcohol, it would soften the rubber band.
He must have a "point". I've never had another seal or gasket problem as long as I use
Amsoil.
Price is too tempting to ignore. Is it as good as pennzoil? It says that it exceeds all major car brand requirements of API SL, ACEA A3/B3/B4, BENZ, VW 502, 505. SK touts this product as an European style oil (does this make any sense to you?). Btw, factory recommendation for the car is 10W-30. Wonder how 5W-40 shall affect the car. The company website is www.skzic.com but it doesn't have the product translated in English yet.
http://www.redlineoil.com/
http://eng.skcorp.com/
That SK synth sounds just fine. Without comparing spec sheets I'd say the SK is every bit as good as the Pennzoil you are using. The fact that it's ACEA A3/B4 and API SL shows that its a top quality oil.
I'll bet ya the reason the Pennz is so $$ has to do with some kind of tax than anything else. Since Pennz's synth ain't no great product I'd switch to SK immediately.
Redline and Amsoil are true synth also, but are not stocked at retail stores. You must find a dealer or order over the net. They are more expensive also.
After switching from Pennzoil 10W-30 to 5W-40 of SK ZIC XQ, the car seems have better low-end acceleration than before (temperature is around 32 these days). I plan to go at least 6,250 miles on it before my next oil change.
