Visitor Agreement.
I did post a web page detailing refining capacity by manufacturer over on Bob's site. I'll try to find it and re-post here.
http://www.bobistheoilguy.com/oilshear.htm
There are also a couple of Lucas threads on his forum.
http://www.fernblatt.com/longhurst/additives.html
Therefore, be careful, dealers don't have all the answers either. Remember, they are paid by the supplier to let them display their stuff in the dealership.
Frankly I'm not sure how useful his Timken machine tests are. They are interesting however.
I don't think Bob is anti-synthetic. It's just that a good dino or blend with a good additive package may do as well as a full synthetic at a lower cost. Also, being a full synthetic doesn't guarantee that it a good oil for extended drain.
Jack
Denver8 - I sent it to Blackstone Labs but next time I am going to use Dyson from over at Bob's site. Cheaper, more comprehensive analysis.
I decided to order some Schaeffers Supreme 7000 5W-30 after seeing some analysis at Bob's site and determining that the Chevron should only go about 4K. My plan it to try 7,500, do an analysis, go 10,000, and do another analysis, and then decide what to do with the rest of my life.
Buy both ChevronTexaco and ExxonMobil and you will have both sides covered!!
http://www.redlineoil.com/dealers.htm
Justy a couple of possible opinions here:
(b)smily1:(/b) I think based on discussions on Bobs board the SS is better. It does have Moly where the TriSyn does not have. I did a comparison between the two here (Ignore the spelling): http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000192
Regarding Post # 4490: I think you have bad information here. Both Mobil 1 and Amsoil are PAO based with an Ester to equalize seal growth. I have used both and had zero problems with either. Sometimes mechanics don't know what they are talking about.
Later,
Al
smily1: I think based on discussions on Bobs board the SS is better. It does have Moly where the TriSyn does not have. I did a comparison between the two here (Ignore the spelling): http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000192
Later,
Al
Ken
See this link for some Lucas Stabilizer info:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=000594#000000
I totally agree with your use of synthetic under high stress, low speed, low time, low mileage driving. The only real issue that folks have is the higher cost that comes along with slightly lower oil change intervals. For certain the synthetic protects better!
I've purchased a 99 Ford E-150 conversion van (V8). It has just passed the 25,000 mile mark and had an oil (dino) change before my purchase. The records indicate very regular dino changes at 3,000-3,200 miles. I plan to drive this van around town in typical conditions with occasional longer trips (4 hours one way). Every summer will include a 3-week vacation pulling a 5,200lb travel trailer for 2,500 miles. I've been reading the posts because I'm considering switching to synthetic oil the next go around. Is 28,000 miles too late to switch? I welcome any advice! Thanks.
In a word NO! But I would not switch to synthetic oil and keep the app 3k oil change interval. I personally keep a 15k interval but realize that MOST folks do a much more frequent one.
Dino oil is about $1.75 per qt. synthetic blend about $2.50 per qt. full synthetic is around $4.50 per qt.
5qts of dino oil = $08.75
5qts of synthetic blend = $12.50 ? percent synthetic
4qts dino and 1qt synthetic = $11.50 20 percent synthetic.
just a thought.
Jack
Chevron Supreme $1.08/qt (very good dino)
Mobil 1 SS $17.88/5qtjug (very good synth)
Personally, I've found that a 50% conv/syn mix works very well for 2 of my vehicles.
Flushing out dirt and metal is why I wish to keep to 3000 to 5000 mile changes. My new car has a turbocharger is why I am looking into syn oils. Turbos can add more heat to a engine.
2003 chrysler PT Crusier GT
on their usa web site - faq section??
Will give Chrysler the honor of doing the first change since they are known for putting filters on to tight at the factory.
If you should choose to get into the really heavy duty synthetic lubrication products, check out the ester based products, such as Redline. It is quite expensive, but outstanding. I prefer the top quality SL oils now on the mineral based market, making this choice on the old "bang for the buck" theory.
