Visitor Agreement.
Anyone see a synthetic oil engine torn down after many thousand miles?
I also would agree!
http://forums.stangnet.com/showthread.php?s=&threadid=181031
I frankly just got tired of dishing out 50 bucks per synthetic change. I just didn't feel comfortable with 5k mile intervals. Owning a turbo car, the oil has always had a tendency to get dirty very fast. I thought I would feel more comfortable dishing out 20 bucks per 2k mile interval with dino.
But after those pics (if they are really true to the words), I feel I might have a made a mistake..
Barring that I think a one year supply of oil is fine for storage. Depends on how frequently you change your oil.
http://www.petro-canada.ca/eng/prodserv/lubesgreases/automotive/3- - 136.htm
Here's some specs lifted from that site...
Petro Canada PowerPlus (Synthetic Perf.) 5W30
Visc cSt
@ 40C 60
@100C 10.3
Visc SUV
@ 100F 279
@ 210F 60
Visc. Index 159
Flash C/F 214/417
CCV 2300 @ -25
BorderLine Pumping 10100 @ -35
Sulphated Ash 0.8%
Petro Canada Full Synthetic 5W30
Visc cSt
@ 40C 59
@ 100C 10.2
Visc SUV
@ 100F 274
@ 210F 60
Visc. Index 159
Flash C/F 225/437
CCV @ -25C 2110
BorderLine Pumping @ -35 9000
Sulphated Ash 0.8%
Using 10W-30 Tri Syn, will go to Super Syn when old inventory is used up.
How exactly does Mobil One guarantee "it" for 7500 miles? What exactly do you have in writing from them?
I'm not comfortable going over 5000 miles between oil changes, regardless of brand. Money is not the primary issue with me. Engine protection is.
But if an oil company is willing to provide me with some sort of written guarantee......
Synthetic at 7500 miles or longer with analsyis will also get you to 200,000 + miels if you can stand driving the same car that long
My guess is 1-5% MAX. Since Mobil One is reputed to have fully 60% of the synthetic engine oil market, the actual numbers drift down from there.
As most folks on this thread know, I change my Mobil One oil at 15k intervals (usually between 13-15k) Even I would agree that out of Mobil One users, I am probably an even smaller minority.
I have to say that the 15k interval is very boring, in a nice way! Currently, I have a vehicle with just under 100k and have only changed the oil 7 times (15k intervals against a much more normal 34 times (3000 mile interval). This particular vehicle goes into a 60k mile major valve check (and normally gets adjusted at premium dollar rates) The mechanic that tore the valve cover apart and checked the adjustment said that the engine was WAY CLEAN for a vehicle of this mileage and DID NOT need adjustments as it had the factory specs as it came off the assembly line. It is due another 60k miles check (120k mile mark) and I suspect that the results will be pretty similar to the 60k mile mark.
The point is that I am presenting the "minority" report! Unless of course folks do not find that gauge useful. What I am saying is that the results are "boring" and not catastrophic with the 15k intervals. Am I missing something, or is the report boring because I have boring results?
You would definitely not think that if you have ever seen a sludged up engine using conventional oil ! The only thing that can get that puppy halfway clean is like a Borsh type internal hot solvent flushing!
If you read the oil book and oil analysis company recommendations, it usually gets down to 3 things: 1. pre oiler 2. double filter system, one bypass (10% small particle filtering), one full. 3. synthetic oils.
1. Why preoilers? Fully 60% of engine wear occurs at start up or more technically, because of metal to metal contact with no oil circulating. (Synthetic oil without preoilers DO NOT remedy this condition)Synthetic oil MAY or MAY NOT have a slight advantage due to the fact the synthetic oil tends to flow quicker and faster in a wide temperature range. 2. Why bypass filters? because 40% of the other 40% of the oil wear (16%) is due to particles under the particle size caught by normal flow through filters. (5-20 microns, I believe) 3. Why synthetic? Well that is the crux of this whole thread!
Actually part (but not all) of the reason that Redline is unable/unwilling to pass the SL standards test is because it uses too much moly (I believe I read that somewhere) as a anti friction coating device and that compound is a tad less friendly to the new emissions systems. Another stated reason is that Redline is content to SAY it passes the standards, but in fact they have not submitted their products for testing for inclusion. That marketing effort seems to work.
As to filters, well, I have now formed the opinion that they are worthless in the modern engine and that the oil does all the work. I am going to test this a little in one car. In the past (two analysis also) I have gone 12,000 miles between changes with a filter at 6000 miles. The oil (and filter) currently in this car has about 7500 now and I am not going to change the filter until it reaches 12,000 miles. An analysis at that time will be interesting the hypothesis being that the filter staying in there for 12000 miles at over 6 months will not make a difference in the wear analysis as compared to changing it at 6000 miles.
We see oil change intervals studied, oils etc. but no one has any data on the actual effect of filters on the longevity of a average car (average). Everone seems to agree that if you cut open a fitler you basically find nothing in there (proponents of filters say it is too small to see in the media but it is there. i say who cares, it is too small to do any damage even if the filter was not in place. So, a cheap fram or an expensive mini micron filtering Mobil 1 will not make any difference in extending the life from 100,000-200,000 miles.
Fire away, studies if you have them?
Based on my prior post about the fact that 60% of all engine wear happens on start up, i.e., no oil protection till fully functioning. This probably is the STRONGEST case for PRE OILERS. And the estimation that only 40% of 40% (16%) of wear due to oil particles is due to just under the particle size that most filters filter out, I agree with you. Con currently, this is a strong argument for bypass filtering.
My however is: I am glad the propholactic is available.
So while how long an engine lasts depends on too many real world variables, for discussions sake, let us use 100-200k miles as a basis. Would you not in theory be better off with 60% more miles of wear or 160-320k with pre oilers?
Add in a bypass filtering system which can decrease the wear from 40% total to say 10%, you would add on respectively 48k to
96k? or 208k-416k?
Yet WAIT there is MORE!!! you can consume up to 5x's LESS oil product using synthetic oil!!
So structurally it is VERY feasible to remove or mitigate those variables that MOST wear is attributed.
{(and inexpensive I might add) 200-400 dollars aftermarket price of pre oilers and 200-400 dollars aftermarket price of bypass systems.}
Great for long haul truckers, not prcaticle for the ave driver. My real issue with the bypass, no place to mount it in todays small glove box space. You also forget that if you wish to sell you car early on in its life (under 5 years) these two products will make the car harder to sell, they are not perceived as enhancements to a car for the ave buyer and will be detrimental to a sale. You will have to remove them, another hassle!
I would agree that the key point is economic feasibility and perception. While there is chest thumping about conservation etc, the truth is that even the environmentalists like massive consumption!!!.
The other practical matter is that pre oilers and bypass products are good for the true conservationists and or some one who travels between 25-50k miles per year. All of these are true minority positions which probably explains that the oem and their markets are well intergrated to each others wants and needs.
Post #5000, Inky, please see the 5W-20 thread about the new "reduced engine life" oil.
1) price - my first synthetic oil change cost $61
2) my dealer doesn't offer synthetic oil changes and I'd like to document my maintence through my dealership
3) the place I got my oil change doesn't do lube jobs
