Visitor Agreement.
Also I have listed 4 that are NOT sludge prone.
So a bit off topic, synthetic (conventional also) oil lets me plan for the app 250,000 miles, I plan to keep this commuter. So given 3k OCI.s and 20k OCI's 3.3 qts per avg oil change and 3.4 quarts for synthetic the consumption is 277.2 qts/4=69.2 gals of conventional and 44.2 qts/4 qt=11.05 gal. It is also 84 OCI's vs 13 OCI's.
While that statement is true enough, just to make sure that nobody construes that statement as saying "all oils, conventional and synthetic alike, coke at the same temperature", it should be pointed out that a fully synthetic oil (i.e. Group IV PAO based oils) have a substantially higher coking temperature. Said temperatures are so much higher in synthetic oil that they easily exceed all normal and even abnormal temperatures encountered in even the hottest pressure cooker engines (i.e. blown motors).
Best Regards,
Shipo
Nah you wouldn't need to because it won't hurt a thing :shades:
As others mentioned paticulars of the law say a warranty cannot be voided in it's entirety, just applicable parts, like that early valve noise would not be serviced etc.
So in the real world (how the miles and driving ACTUALLY work out) this is the "real world" benefit to me of 3k oci's vs 15,0000 to 25,000 mile OCI's;
20 oil changes vs 3 oil changes per year.
This is of huge utility to me.
Anyone hear this noise? I haven't been able to find anything on it, but the rumor is said to have started with both an Audi and Mercedes service advisors.
Normal? No. What's normal? Beats the willies out of me. On some new engines 10,000 might well be all synthetic oil would be good for, on others, 15,000 to 20,000 (or more) is more normal. It all depends upon the engine and the driving environment.
...what would you say to the same miles using petroleum based oil?
Other than some of the new Hondas, I don't think there are any engines sold here in the U.S. that can safely go 10,000 miles on dino juice.
And what if you added some thing like STP oil additive, will this help? Will this create varnish?
Save your money, while snake oil might not harm your engine, it sure as hell won't help it.
Best Regards,
Shipo
Been there, smelled that, got the Tee-Shirt. ;-)
EWWWWW!
Best Regards,
Shipo
Ughh.
However, I have used a mixture of STP and motor oil to pre-lubricate bearings when I installed them in a rebuilt engine. I just dip the bearing in the mixture quickly and get a thin coating of the gooey mess on there.
So STP has its uses.
Best Regards,
Shipo
Best Regards,
Shipo
Can't directly comment on your choice of filter. There have been a number of posts across the web about using different filters on the Passat, mostly concerning the 1.8T engine and the desire to increase oil capacity.
You've got the V6 - it's less demanding in that regard.
Well spoken. Now, where do you get OEM filters for your Daewoo?
Why should I wait to change the oil the first time?
Your Honda engine was delivered with an oil that is specially formulated for new engines that have not yet developed their "natural" wear patterns and may contain minute particles from the manufacturing process.
American Honda strongly recommends this special oil be left in the engine long enough for these wear patterns to develop, usually until the first maintenance interval specified in your Owner's Manual, based on your specific driving conditions.
Sure I can understand the confusion. You have folks saying 3,000 miles (or DIE) 5,000 miles, extended OCI's, severe duty, time, over time, under time, environmental conditions, low, good, medium, high, quality oil. USE ANOTHER OIL DESPITE WHAT THE OWNERS MANUAL SEZ. Use supplements. Don't use supplements.... The list drones on and on.
So yeah, who do you trust? As you can tell I am advocating what the OEM says to do. On the other hand, you didn't ask me what I actually do.
In other words it does what other oils do. Nothing special explained there!
The Sandman
So given the new information, to cut to the chase: drive it to 15% remaining. Change the oil at that point, obviously. Let us know how many miles that happens to be. Again, since the OLM is (seems to be) calibrated for conventional oil, the usualy TBN is 7 vs say a Mobil One 0w20, 5w20, TBN being 12. So once you know a few of your mileage intervals, it will be very easy to adjust it, if you wish to switch to synthetic oil, for example. If you are at all picky, you can even do oil analysis; which would be a bit like consulting a second watch to see if time is being tracked correctly.
So for example, since I have an OLM on another vehicle that is actually callibrated for Mobil One 5w30 oil AND an oem recommendation NTE 15,000 miles;(1 tBN= 1365 miles) the olm indicates changing at app 14,500 miles. So the real TBN consumption is 1318 miles per tbn. So even if I do say so myself, the driving style is easier on the engine and therefore oil rather than harder.
"My '06 Civic LX also says to wait till the oil life says 15%. I called the service department and they also told me this. I'll be waiting...and with a little over 2800 miles and at 60%, looks like it'll be around 7k miles before I need the 1st change. "
So for example in Sandman's case, he is getting 1071 miles per tbn. so 15% of 7 =1- tbn =6 (consumed) x 1071= 6,500 miles , due.
1) My OLM is probably calibrated on conventional dyno oil, so if I switch to synthetic it wouldn't be accurate in its estimate.
2) Assuming your "1318 miles per base number" figure is somewhat universal for synthetic oil since it's calibrated on Mobil 1 5w30 synthetic (although my Honda calls for 5w20), I can probably safely run my oil for ~13K miles using Mobil 1 5w20 syn. That's based on 10 TBN consumed out of the 12 TBN to give it a cushion. The OLM on my Accord will probably come on at around 7k miles (based on its 7 TBN calibration), but I can ignore it. Incidentally, currently at 1600 miles my OLM is at 80%. That's about 1100 miles per base number with the factory filled oil.
Is that about right?
As it applies to oil filters just keep in mind that FRAM is the oem provider (to Honda's specifications) for Honda.
I personally would buy oil filters on price. Indeed the WalMart SuperTech is made by Champion Labs and costs ($2.07), less than even the FRAM.
Again this is true for the 2004 Honda Civic, the OEM recommendation is for EVERY OTHER oil change interval to change the oil FILTER. So in my case 20,000 miles.
The answers can be very simple to very complex. So I would say put it in the context that is most correct for one's situation.
So to get technical,
(which will probably drive away 75% of folks who would want to read this)
(that is a 3.2 qt (1 per qt) and (with filter 2.07 per) 3.4 qt+ .20 per crushable washer = 9.07/20,000=
.0004535 per mile lubricated.
(materials only, ADD app 18 dollars per oil change for shop and disposal costs)
As a comparison I got Mobil One 0w20 for app 4 per qt, so as you can see even a 20,000 mile OCI comes up more expensive 3.4 x 4= 13.60 + 2.07+ .20=$15.87/ 20,000=
.0007935 per mile lubricated
or 43% MORE. Indeed full parity is app 35,735 miles OCI.
So an interesting question, what % of folks would actually use a 10,000 mile OCI? Would they be more likely to use a 3,000, 5,000 mile OCI? Upshot is do the math with or without shop and disposal costs.
UPSHOT why I use synthetic at 20,000 mile OCI's
Research and my own SOTP experiences indicate using synthetic oil (0w20)gets from 1-3 mpg better fuel mileage over conventional oil . So over the course of 20,000 miles using 36-42 mpg I will use up to 37 gals (x 2.50 per gal=$92.50) LESS unleaded gasoline. So now, what is more expensive ?
$9.07 (+92.50) or $15.67 ?
Up front, a no brainer
TOTAL?
So we do not get too wacked out with adjustments, the OLM indicates 8,000 miles OCI's (with CONVENTIONAL oil), so you are not the NYC taxicab driver who moonlights as the pizza delivery person at nights.
So if your quote is the trend, the adjustment is fairly straight forward if you wish to convert to synthetic oil.
I have been doing a lot of posting on this subject from memory, so I got curious and went back to my written mileage logs, first 10,000 mile interval. (conventional oil). So here are 6 snap shots for each 10k interval. (first three after the OCI and last 3 before the next OCI.
The first three tank fulls are not unlike yours at 35.6, 37.7, 34.9 mpg. Gassers are also well known to be broken in well before 5,000 miles. The last three before I changed the oil to Mobil One 0w20, 35.2, 35.9, 37.625, So the average of those 6 readings= 36.15.
So just after the second 10,000 OCI and just before the third, Mobil One 0w20), 38, 36, 38.99, 39.35, 36.4, 34.625, So the average of those 6 readings =37.29
So just after the third 10,000 OCI and just before the 20,000 mile marker, 39.14, 40.17, 37.25, 39, 40.34, 41.09. So the average of those 6 readings = 39.565
So because I am on a 20,000 mile OCI, here are the last 6 readings (current) 42.64, 36.33, 44.91, 37.1, 38, 40. So the average of those 6 readings= 39.83
So I wish you all the best in your new Honda no matter what you decide.
While a daily commute (among other things of course) does not come under what I would classify as fun, we are enjoying this Honda Civic under very many categories. We hope to run it a min of 250,000 miles with no more than changing wear able items: like, tires, rotors, drums, pads and shoes and the timing belt change at 105,000 miles (or so?) with a spark plug change at the same 105,000 mile interval.
So I said in past posts 1-3 mpg, the numbers under the above conditions, indicated 1.14 to 3.68 mpg. So over 20,000 miles that is 553 gal-502 gals=51 gal * 2.50 =127.50 per 20,000 miles. So if 3.68 mpg holds true over 250,000 miles, then we are talking 36.15, 39.83 mpg/250,000 miles or 6,916 - 6,277 gals respectively or 639 gals saved * 39.83 mpg = 25,451 miles of commuting.. At 2.50 per gal that is $1,597.50.
I am sure you don't need me to do the math on say 250,000 miles and the waste oil generated with 5,000 mile OCIs vs 20,000 mile oci's.
So if you think that is excessive in whatever (the) way/s, either range, difference, etc, etc. then really that is and has to be ok with me.
As you know, mpg is very low hanging fruit, given the WIDE range of possibilities and variables. So for example the sticker on the Honda Civic is EPA 29/38 it also says the majority of vehicles will achieve between 24/34 (city) 32/44 mpg (highway)
On another car, (VW Jetta) TDI it is EPA rated at 42/49, BUT the stated range on the sticker is between 35/49 city, 41/57 mpg highway. I have gotten as high as 62 mpg.
So for example what would you have me state when and if someone asks what can anyone expect for MPG?
The other interesting thing is the recommendation for the first car is 5w20 conventional and for the second 5w40 synthetic and BOTH for 10,000 miles OCI.
The other point is OEMS are EMBRACING synthetic oils AND the 0w20 to 5w20 viscosity. I understand the Honda Civic SI actually recommends synthetic. Again, Corvette, Porsche, BMW, MB, VW have been for a while, to mention a few.
