Visitor Agreement.
Simple answer; none, zero, zip, zilch, nada. VWoA retroactively changed the oil spec for your engine in the 2002-2003 time frame to a high quality synthetic oil for all 1.8T engines going back to the late 1990s. If that engine has sludge in it (and it sounds like it does), I'd be getting it to a mechanic pronto to have it thoroughly inspected (i.e. cam cover(s) off and possibly even an oil pan drop or failing that sending a video pickup into the pan to inspect the oil inlet screen).
The above procedure won't be cheap, and any remediation won't be cheap either, however, combined they'll be a fraction of the cost of a new engine (which it sounds like they'll need if they continue along with their current maintenance practices).
Best Regards,
Shipo
Best Regards,
Shipo
The vendor is our Walmart here in this W. Georgia town. Both Mobile 1 and Castrol Syntec were on sale - all available weights.
It looked like such a good deal that we purchased 4 jugs of the stuff
Best Regards,
Shipo
While Shipo will probably disagree, I run a 25,000 miles OCI on a VW Jetta TDI which I plan to keep between 500,000 miles to 1,000,000 miles. I just had my first timing belt and water pump change, so it is still a baby at 100,000 miles. Visual inspection indicated literally little to no wear markings on the high points of the camshaft. Original tool markings were clearly visible. The innards of the top of the engine were shiny. There was not a hint of either varnish build up and/or sludge. The regional guru's take was "what's the big deal" :shades: (All cool, in English)
The intake was inspected. (by our local regional guru) While blacken, there was no build up. It was pronounced good to go, to a min of the next timing belt change. (200,000 mile mark)
Best Regards,
Shipo
Should I:
a) go 7500 miles on conventional like it says?
b) go 7500 miles on synthetic?
c) go 5000 miles on conventional?
For what it's worth, I am more interested in doing what is best for the car, than I am about saving money on oil changes.
Use a good quality Synthetic Oil and run it for the full OCI. Even then the oil will most likely be good to go for another several thousand miles, but staying within the maintenance requirements for warranty purposes is far more important than eeking out every last mile from your oil.
Best Regards,
Shipo
As a follow-up, how long should I leave the oil in that came in the car? I heard that the current machining procedures are a lot cleaner now than they used to be, and there is less "debris" in new engines. Should I leave it in for 3,000, then change over to synthetic, or change sooner?
I have yet to see any concrete evidence that says that the factory fill cannot easily last for three to five thousand miles. Me? I'd probably start thinking about an oil change once I'd crossed the 3,000 mile mark. ;-)
Best Regards,
Shipo
Well, they are in all new engines and that's why an early oil change will be beneficial.
Best Regards,
Shipo
Why. (in my case) On my 2004 Civic, the mileage I intend to go is 4/5 timing belt/water pump changes @ 105,000 miles per belt/water pump change= 420,000-525,000 miles. Assuming you are using the recommended specified oil, (in my case 5w20, 0w20, Honda and/or Ford specifications-FORD being more stringent) there is no reason why you can not go YOUR full interval (7,500 miles). (in my case interval= 10,000 miles, conventional oil.) Honda (owner's manual) made a BIG deal about leaving in the conventional oem fill for the FULL interval term. (10,000 miles). It made a further HUGE deal to say further that the MAJORITY of drivers do NOT meet the SEVERE cycle (5,000 miles), despite the fact that there is GREAT pressure to classify one's vehicle in the severe category.
My .02 cents converges with Shipo, after the first FULL interval. At 7500 miles, change/switch to a high quality synthetic oil i.e., Mobil One.
Because I am way past the warranty mileage, 3 years/36,000 miles, I "self insure" anyway. I run 20,000 mile OCI's with 20k oil filter (recommended for the filter)change. The car runs like the proverbial top. You can see the original tool markings. There is NO sludge and/or varnish build up/formation. The innards are shiny! It gets 38/43 mpg on a daily commute (EPA of 29/38 mpg). We almost always use the A/C. My wife listens to baseball on the am band. :sick:
See, it has been my experience, with the way I typically maintain cars, that the engine and transmission are the last things to go. With the case of your Civic, the engine and tranny, if properly maintained, MAY last forever, but I would bet the electronics, a/c, cv / axles, etc... will not.
To answer your question, I will probably keep the car until I get nickle and dimed enough to where I might as well use my repair money on payments for a new, warrantied vehicle (and get the pleasure of driving something new).
If you want to change to synthetic, then change to synthetic, simple as that.
Best Regards,
Shipo
I know, wear metals are always high and contaminant concentrations go down quickly over the first few OCI's.
I just can't help it. I feel better changing the oil more often initially.
After the third oil change I will drive the car for at least 10k and after an UOA maybe go to 15k intervals (with synthetic oil of course) and possibly extend intervals further, depending on the analysis results.
A dual filter by-pass sistem is in my plans too! I removed it from my previous 2001 Echo.
When the extended performance first came out, I was all over this-research wise On the practical basis, this also increased the complexity. I was already doing the 15,000 mile OCI's on the Mobil One 0w30,5w30. These are already wonderful results (with the normal Mobil One) despite the CONSERVATIVE 15,000 miles OCI's. Without a series of UOA's I was not willing to extend this to 20,000-25,000-30,000 miles OCI's. The extended performance did/does NOT meet the GM spec 4178 M for another machine. The Toyota Landcruisers that COULD use the extended performance ALSO could use the following: 0w30,5w30,0w40 products and in the 5w30 Truck and SUV and extended range.
I think you would gain a slight mpg just by going to a 0W product if you are not already using it!
https://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Extended_Performance_- - - 5W-20.aspx
So since you have it, I would look forward to your analysis on the product. Since I run the Mobil One 0w20 and or 5w20 @20,000 miles OCI's, I would not have much concern for the ep product, even as I know you have stated concerns on a few occasions.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_0W-20.aspx
The Sandman
That's a great bike! I also have a Triumph- a 1996 Speed Triple. I use BMW 15W-50 Synthetic Motorcycle oil. It's not too expensive and it's also relatively easy to find.
The 2001 Corvette Z06's olm is calibrated for Mobil One 5w30 (with a TBN of 12) and up to 15,000 miles or one year.
So for example if a 7 tbn can go say 7,500 miles OCI's, then a 12 TBN (with a 41% better TBN) by virtual of using Mobil One 5w20, then 10,500 to 11,000 miles is a conservative extention.
"I think this is the cheap way to bring the customer to the stealer... what do u think? thx "
YES and NO!
There is no statistical calculation showing for example what the affects/effects of say you changing oil when an olm goes off at say 7,500 miles vs a oem mileage certain of say 10,000 miles.
As you have probably surmised, a direct oil sample can be done. It can cost more than just changing the oil a tad earlier. Again, millions and probably billions are wasted on this reasonable or unreasonable doubt argument.
Oil analysis started off more to measure FLEET trend line, for statistical and specific maintenance programs. Obviously the individual members can be sampled. UOA kits are available to the consumer markets.
http://www.enhancedsyntheticoil.com/New_Motorcycle_Oils.htm?gclid=CP3JjbWvhY4CFR- - LNIgodLh0_QQ
Click on the "white paper" to get some informative, dry reading.
I will be using the tire place or Honda store within my city after the 15k service anyways, so I'll get there opinion also. I like to at least do an oil change at the closest dealership just in case any unforseen warranty issues do crop up, i will at least be on record for having a service done at their store. Would it bring me any future goodwill or even a free loaner if something under warranty fails and they must keep the car for a time. I'm hoping it would. We'll just have to see what happens and will be interested on their take of synthetic oil over dino.
They also checked out the strange noise in back going over speed bumps and concluded it was just tire noise. Drove with the tech also and he concurred. Will be keeping my ears open, as over bigger speed bumps, there's definitely something going on.
The Sandman
Take a look at www bob is the oilguy dot com
Question to you all: is the Accord 4-cy known to burn oil like this? My car has 10K miles. And I drive very gently.
Some Toyotas, probably the older ones that are maintained, are famous for sludge and smokey exhusts. Because yours is '06 looks like it should be OK.
