Visitor Agreement.
2) Don't worry about the sludge either.
3) With such a short drive cycle, I'm not at all sure that I'd even bother changing to synthetic oil. In fact, were I in your shoes, I'd definitely opt for something like Havoline 5W-30 and stay with the 3,000 mile OCI. Keep in mind; I am a dyed in the wool advocate of synthetic oil, so for me to recommend that you stay with conventional is very much against my nature. That said, I think in your case conventional oil is the better bet.
Best Regards,
Shipo
So for example, I would have no issues so called "extending" even conventional oil. Indeed I ran the first full 10,000 miles OCI (as recommended by the OEM) on the Honda Civic, again 5w20 CONVENTIONAL oil. If all you wanted to do was to run YOUR full recommended OCI, then run the recommended conventional oil. So in that sense I would be in full agreement with Shipo. No real sense in "wasting" money, time, and resources.
Best Regards,
Shipo
Except for changing the OEM conventional, so called "break in oil", 5,000 miles TOO early, the answer is NO! I also take it the Royal Purple is 0w,5w20 for the Civic is Honda/Ford specified oil.
In winter especially, change the oil sooner, according to the instructions in your manual for severe driving conditions.
Consider using synthetic oil and make sure your car is driven at highways speeds for at least 30 minutes every week.
I read your common on message 6266 about the low mileage on a VW, I have very simular driving condition about my camry except it is not a turbo. You mentioned need to bring the car to exercise at least once a week, does that also apply to 90F in summer and average above 40 in winter of Alabama weather? My commute to the campus is 100% city stop and go city driving and less than 2 miles, just barely enough to bring the car to normal operating temperature. I just changed my oil to M1 5w-30 which is recommand by Toyota, do I also need to bring my puppy out exercising all year round, and how do I make sure there is no water in my oil? Is it possible to know this just by looking at the exhaust (smoke due to water vapor)? If the answer is yes, can your describe how to do the exercise, is interstate the only way or just drive long enough when there is no smoke coming out from the exhaust? I will change the oil once a year since I drive less than 10000 miles a year,is it a good idea.
Thank you in advance for suggestions
As for how to tell if the water has boiled off, there is no indicator per-se (unless your car has an oil temperature gauge, something that very few cars have these days), so it's more of a time/distance guesstimate thing. FWIW, just because the engine is "up to normal operating temperature" doesn't mean that your oil is. Your coolant temperature gauge can easily be showing normal while your oil is barely above 100 degrees.
Were I in your shoes, every weekend I'd do at least one ten mile drive so that you effectively purge your oil of water weekly.
Best Regards,
Shipo
The good news (errr, sort of) is that we get the same fuel here year-round. The bad news is that E10 is generally considered to reduce fuel economy from three to five percent. Keep in mind that due to the temperature of the intake charge in the winter time, fuel doesn't atomize as well and your mileage will suffer as a result. Said another way, here in New England, we get a double whammy in the winter time with both cold air and E10 fuel.
Thanks for any suggestions in advance
However if you have 3 years/36,000 mile warranty concerns, you can either ask for warranty fulfillment at the 33,000 to 36,000 miles period or just proceed as you had planned.
try using the My Watched Items to navigate to forums. If I keep repeating the Mark As Read it will eventually catch that I've read them all and I click on Read New Posts and we're all set.
Cliff
Best Regards,
Shipo
Cliff
Cliff
transmssion problems. Sludge occurs in several cars, some more, some less,
Good luck and change your transmission fluid often.
There's nothing "100% synthetic" about either Walmart or Quaker State oil. The "synthetic" oil offerings available under either brand name are actually hydrocracked Group III conventional oils.
Best Regards,
Shipo
Miles on engine 9838
Miles on oil 5046
Date sampled 12/31/07
Make Up Oil 0
OEM Mazda Filter
Mobil 1 5w30
Aluminum 4
Chromium 1
Iron 40
Copper 83
Lead 2
Tin 0
Moly 80
Nickel 1
Manganese 1
Silver 0
Ti 0
Potassium 2
Boron 38
Silicon 12
Sodium 6
Calcium 2634
Magnesium 11
Phosphorus 624
Zinc 808
Barium 2
Sus Visc @ 210F 56.2 should be 55-62
cST Visc @ 100 C 9.13 should be 8.8-11.1
Flashpoint in F 375 should be >365
Fuel % 1/3 to 1/2 of what some other owners are reporting. Silicon is a bit high as well, but again it is in line with other UOAs of this motor. Blackstone believes that all three numbers will settle down by 15K-20K. At least the motor isn't completely wrecking the oil like the M54 in the X3...
Okay, let's see here:
- The Iron looks a bit high, however given that your engine is still breaking in, no red flag there.
- I'm thinking that the Copper looks pretty high as well, probably also due to the break in process.
- Contrary to what Blackstone says, I think the Silicon looks perfectly fine, especially given how young your engine is.
All in all, a most promising UOA. Given that I'm a "0W" bigot, I am of course going to suggest that you start using the new "Mobil 1 0W-30 Advanced Fuel Economy" even though you don't live up here where it can get seriously frosty.
Got a little hasty with the cut and paste; the TBN was 2.9. Boy, I wonder what conventional oil would look like after 7.5K miles, like some folks are doing...
My sense from your (normal) results are Mazdaspeed engines are more consumptive of oil/oil additives than say Honda Civic. So for example, my Civic oem recommendation is 10,000 miles OCI's with conventional oil.
Best Regards,
Shipo
It seems that the new direct injection engines are prone fuel dilution issues, particularly the twin turbo BMW I6 as well as the normally aspirated V8 in the Audi RS4. Since my fuel % was <0.5 I must be living right, as Blackstone considers anything <2.0% to be accepatble.
The manual says that any SM 5W-30 is acceptable. I selected Mobil 1 because of the good results I've had in other engines as well as the fact that this Mobil 1 grade meets the Honda/Acura HTO-06 standards.
