2017 Subaru WRX Lease Questions
15678911»
  • dobeonguarddobeonguard Member Posts: 5
    I have a question regarding Subaru Motor Finance credit score. Isn't their tier 1 still 700+? I saw a dealer advertising a lease special on a WRX but the details said to qualify you needed 800+?!?
  • MichaellMichaell Moderator Posts: 268,726
    SMF tier 1 is indeed 700+
    Dealer may be using a third party bank, with different qualifications.
  • kyfdxkyfdx Moderator Posts: 272,621
    Some banks/dealers use an enhanced Auto score, and that scale goes up to 900, instead of the 850 FICO.
    Or, they wrote the ad that way, so they could upcharge the 95% of customers that can't cut it..
  • pavicarguypavicarguy Member Posts: 35
    2017 Base and Limited STI MF and Residual for 36/10 in socal (92880) thank you.
    .00070 MF and 63%/60% residual for Base/Limited
  • leasehackleasehack Member Posts: 18
    Hello. Can i get November numbers for 36/10 on Base / limited STI? Thanks
    Base: .00075 MF and 61% residual
    Limited: .00100 MF and 60% residual
  • h2opolosealh2opoloseal Member Posts: 28
    edited November 2017
    Howdy! May i please have the numbers for both a 2017 WRX CVT Base/Premium, with 10k/12k, for 36/39mo? California.
    Thanks a million, hands down best forum on the web for this info! You guys have saved me many thousand of dollars over the years.
    Base model doesn't come in CVT
    Premium:
    .00040 MF and 56% residual for 36/12
    .00075 MF and 55% residual for 39/12
    .00105 MF and 54% residual for 42/12
    Add 1% for 10K/yr
    Base model doesn't come in CVT Premium: .00040 MF and 56% residual for 36/12 .00075 MF and 55% residual for 39/12 .00105 MF and 54% residual for 42/12 Add 1% for 10K/yr
    Thanks Kyfdx. Should have known better about the CVT, thanks. Funny how those residuals keep dropping month to month, thankfully the MF followed suit decently.
    Premium:
    Add 1% for 10K/yr
    Residuals almost always go down throughout the model year.
  • enniom3enniom3 Member Posts: 5
    2018 Subaru wrx limited manual 36/10k
    Danbury CT 06811
    Danbury CT 06811
    I see you've also posted in the 2018 WRX thread; we'll answer you over there...
    2017 base sti and limited sti 36/10 socal 92880 MF and Residual please thanks.
    .00035 MF and 61%/58% residual for Base/Limited
  • desii72desii72 Member Posts: 10
    Can I get 2017 wrx premium and limited numbers?
    36/10 and 36/12?
    Subaru numbers are national correct?
    Also, the MF you post is based of tier one credit? How are the tiers broken down?
    36/10 and 36/12?
    Stick shift or CVT?
    Top tier credit is 700 or higher. Every 20 point range is a tier lower. Add .00025 for tier 2; .00050 for tier 3 or .00080 for any score lower than 660.
    Can I get 2017 wrx premium and limited numbers? 36/10 and 36/12? Subaru numbers are national correct? Also, the MF you post is based of tier one credit? How are the tiers broken down?
    Stick shift or CVT? Top tier credit is 700 or higher. Every 20 point range is a tier lower. Add .00025 for tier 2; .00050 for tier 3 or .00080 for any score lower than 660.
    Thank you for the tier info.  Does that apply to all Subaru or just the 17 wrx?
    This is for a stick shift
    desii72 said:
    36/10 and 36/12?
    Stick shift or CVT?
    All Subarus have that markup for lower tier credit
    Premium: .00040 MF and 56%/55% residual
    Limited: .00025 MF and 55%/54% residual
    Can you give me numbers for a Base model as well? Stickshift.
    59% / 58% and .00030
    .00030 MF and 59% residual for 36/10.
    .00095 MF and 57% residual for 42/10, if a longer lease interests you. Might be cheaper.
