Visitor Agreement.
Again, a totally pathetic answer that should not have gone without a challenge.
Every diagnostic tool is only as good as the person operating it. So I could see owners and technicians getting into debates on how to interpret the readings. "It says 02 sensor out of range. Why did you replace my fuel injectors!"
Of course not but I will be sticking with the older models.
Looks good in black,eh?
FWIW, everything is OK this morning after sitting out all night. It wasn't minus 6 but still pretty damn cold.
For a second there, I thought she had a twin in Minnesota. WHEW.
Like when the girl said to make sure I change the oil in my Legacy every 3,000 miles. - which reminds me...I did do the 1st oil change on the Legacy at 3,000, but I do that with all my new cars. The same girl insisted that I have the tires rotated. I declined the offer. I'll get it the next time.
I told this tale back on SFTSFL many years ago but it deserves repeating since we are on the subject again. This was the result of a service advisor telling me why the mechanic didn't do a bad job tuning up my '66 Bonneville (that alone tells you how long ago this happened). The only reason I had them do the tune up is because I was still living in an apartment and I had to take the car in for warranty work anyway.
Here is the discussion as best as I can remember it:
Advisor: I'm sure the points are set correctly and the spark plug gap is correct too. We had one of our best mechanics work on your car. So I don't know why you are here.
Me: No, they are wrong because I checked them myself and the timing is off 2 degrees too. So nothing was done correctly.
Advisor: Well, Mr. jmonroe you have to understand that those parts and settings change due to wear.
Me: It could not have worn that much in 2 weeks with only a couple hundred miles having been put on the car.
Advisor: Oh you'd be surprised.
Now I'm hot.
Me: Yes, I would be surprised and I'm surprised with everything that was done wrong on this tune up. Your guy did a lousy job. The plugs were probably taken right out of the box without setting them and the same goes with the points. As for the timing being off, if the mechanic didn't play with the distributor rotation I would have probably been better off with the way it was already set because unless something drastic happens like a chain going bad, you almost never have to touch the distributor.
The advisor was still sticking to his story and with every pathetic excuse I kept looking over my shoulder.
Finally he said:
Advisor: Mr. jmonroe you seem to be looking for someone. Are you expecting someone to pick you up while we take a look at you car?
Me: NO, I thought you were talking to the a-hole behind me but there isn't anyone there.
Yes, they finally tuned it up right but I learned a valuable lesson. If I could do something why pay someone to screw it up and then be inconvenienced in the process?
This was not a rant, just my opinion about service advisors talking when they don't have to.
Beyond regular oil changes, much/most of "scheduled maintenance" is a scam. Check your fluids, and keep them between the lines. Change as required, which isn't very often beyond the engine oil. On-condition maintenance is my system. Filters are easy and relatively cheap, as are oil changes. I'm willing to pay the independent garage for coolant/brake fluid/transmission oil changes, and they're generally pretty reasonable.
As I learned from my first wife, keeping alive has much to do with staying out of the hospital, unless things are really (really) screwed up. Same applies to cars, in my world.
oldfarmer.......you mean it is so cold in upstate NY that you are going to buy a snuggly for your legs.....
I learned a valuable lesson. If I could do something, why pay someone to screw it up and then be inconvenienced in the process?
But, the corollary is, "Why try to fix it myself and then screw it up and make it even more expensive to repair?"
Not talking about you JM, just some people like me can do more damage by DoingIY.
I'll never forget the time a guy came over to me as my hood was up in a parking lot as I was looking at the battery to see if the connections were tight and not corroded. As usual they were fine but I needed a jump start. He said with a smile on his face, "looks like someone is going to be calling AAA. I hope you AAA". I said, "I'm glad you showed up. Can you give me a jump start". He said, "I would but I don't have jumper cables". I said, "I have a set in my trunk". He now has a strange look on his face and said, "Ah, ah, I have to pick someone up and I don't want to be late". Nice guy. No problem, as I'm closing the hood a guy comes over and asks if I needed help. He never mentioned AAA. I said, "just a jump if you don't mind". He said, "sure, I'll pull my car over and get my cables out". I told him I had cables and he said, "great, you'll be on your way in no time".
Us DIY guys understand each other.
At least they didn't try to tell you that your rotors were warped because you didn't drive the car enough like the Chrysler service advisor.
The fact neither could fix the stalling problem and their stories didn't match about the brakes made us distrust Volvos.
Actually, the C250 comes of warranty this month, but, with 20000 miles on it I'll risk it for awhile. It's like living without a safety net.
Didn't see or smell any smoke, but it was so loud I was getting a headache.
Shut off all the breakers except the furnace, but no difference.
Luckily, I found the bad one on the first try, so the rest quieted down.
Looked in the drawer and found some 5 year batteries, Great!
Put one in and it didn't seem right. It tested ok, but I noticed a 2017 expiration date on it, then it started chirping after a couple of minutes.
Ok, all my 'new' 9 volts are expired. Off to the store and find some new '5 year' batteries.
Maybe I should check the expiration date. It's 2020. Dug through some of the back rows and found some 2022's.
Overall, it's good to know how loud the smoke detectors can be, but I wasn't in the mood to deal with it after 10 hours at work, first work day of the year.
They never go off at a great time though.
I did that with both used Chevrolets I purchased for my son to drive by purchasing an extended GM warranty from a dealer online who specializes in discounting and selling same. The first one more than paid for itself with things it covered before the time ran out. Both the Cobalt and Cruze purchases were what I consider cost effective in that if something's wrong the dealer handles it.
One year for the driving it part but around 4 years to learn how the combination lock works for the glove compartment and how to get at the donut spare. :@
then over the last few weeks, had a couple decide to chirp for low battery (serves me right for using the cheapo EverReadys that came with). Always in the middle of the night. So this week, after the latest one, went around and found the rest of the old batteries and changed them in advance. So now back to peace and quiet. At least from the ceilings.
My 2017 E400 is only driven for 7 months, so I could have about 30000 miles on it when the warranty is up after 4 years........I would consider keeping it past the warranty period....but, I have time to decide about that.....I still like the idea of spending my kids money (inheritance that is)..
