2018 Subaru Crosstrek Lease Deals and Prices
1235711
  • MichaellMichaell Moderator Posts: 269,006
    elrepho said:
    Thanks. Are the numbers the same for the 2018 Crosstrek Limited/Automatic in NJ?
    62% and .00105 for 36/15
  • rambag3rambag3 Member Posts: 13
    edited January 2018
    Hey guys looking for the RV and MF on the Premium and Limited models in Ny, 11559. Thank you, is finally time to pull the trigger on something. Automatic.
  • kyfdxkyfdx Moderator Posts: 272,632
    Premium: .00095 MF and 62% residual
    Limited: .00105 MF and 62% residual
  • skwirlskwirl Member Posts: 32
    Hi guys, looking for RV and MF on Limited models in Washington State for 36 months, 12k and 15k. Thank you!
    64% / 62% and .00105
  • Hello - Can I please get residual and MF for a 36/10 lease on an Crosstrek Limited (auto) in MN? Any current incentives?
    65% and .00105
    No incentive info
    65% and .00105
    No incentive info
    Thanks again! Appreciate all your help today.
  • gooner21gooner21 Member Posts: 3
    Hello, may I have the MF and RV on a Crosstrek Premium in MA and RI, please?
    .00095 and 62% for 36/15
  • silviodantesilviodante Member Posts: 18
    Hi
    Can I please have the RV/MF for a Crosstrek premium in NJ for 36/12?
    Hi
    Assuming CVT, 64% and .00095
  • jbramanjbraman Member Posts: 8
    Hello, May I please have the MF and residual for 2018 Crosstrek 36/12 & 36/10Limited in
    Indiana and Outback Limited, same terms? Thank You!
    .00105 MF and 64%/65% residual
  • sticksandturbosticksandturbo Member Posts: 2
    edited January 2018
    Hi, what's the MF and any deals on a 2018 Crosstrek Limited automatic 36/10k and 12k? 91709
    65% / 64% and .00105
  • edonefifthedonefifth Member Posts: 4
    Could I please have the residual values and money factors for Crosstrek 2.0i and Premium for 36/10k in PA? Is there any difference for manual vs auto transmission? Thank you!
    2.0i manual: .00085 MF and 65% residual
    2.0i auto: .00110 MF and 67% residual
    Premium: .00095 MF and 65% residual (either trans)
  • wonkierdatawonkierdata Member Posts: 2
    edited January 2018
    I've been getting the run around from 2 local dealers and the numbers they give me don't add up. At least one of them (if not both) aren't being honest about the MF/RV for the cross trek 2.0i auto.
    Could someone please give me the current MF/RV for the 2018 crosstrek 2.0i in NJ (08753) for 36/10k? (Or 39/10k if offered)
    Base trim?
    CVT or stick shift?
    edited January 2018
    Base trim? CVT or stick shift?
    Apologies...
    CVT base
    Base trim?
    CVT or stick shift?
    Apologies...
    CVT base
    36/10: .00110 MF and 67% residual
    39/10: .00120 MF and 66% residual
    42/10: .00110 MF and 63% residual
  • chanb2349chanb2349 Member Posts: 2
    Can I get MF/RV for 2018 Crosstrek 2.0i CVT for 36/10, 36/12 and 42/10 for base, premium and limited in Southern California(LA)? Please and thank you!
    .00110 MF and 66%/62% residual for 36/42 months, 12K/yr
    Add 1% for 10K/yr
    Thank you, which trim is this for? Can you provide the same for other two trims?
    That was the base trim, quoted above.
    Premium
    36/12 - 64% and .00095
    42/12 - 61% and .00115
    Limited
    36/12 - 64% and .00105
    42/12 - 61% and .00120
    Add 1% for 10K
  • bgrosenbergbgrosenberg Member Posts: 6
    Hello. Looking for MF and RV for Crosstrek Limited in MA? 36/10. Thanks in advance!
    Could I please have the residual values and money factors for the Crosstrek Premium CVT for 42/10k in PA? Thanks!
    65% and .00105
    62% and .00115
  • thegrubenthegruben Member Posts: 19
    If you have them can I please have MF & RV for Crosstrek Limited w/ eyestight for 36/15k. Thanks!
  • aligstaraligstar Member Posts: 1
    Residual and MF for 2018 Crosstrek premium with EyeSight + Blind Spot Detection / Rear Cross Traffic Alert + Accessory Package 36/15,000 lease in Hawaii. Thank you
    62% and .00105
    62% and .00095, assuming CVT
  • vhalomnativglvhalomnativgl Member Posts: 29
    Can I have the MF, residual and any lease incentives for 2018 Crosstek limited 36/12 CVT in zip code 92555 SoCal. Thank you.
    .00105 MF and 64% residual
  • jhtowns2jhtowns2 Member Posts: 3
    Can I get the RV/MF for a 2018 crosstrek base model CVT and premium CVT with eyesight,  both 36/12k, in 27511? Thank you!
    Base - 66% and .00110
    Prem - 64% and .00095
    edited February 2018
    May I please have the RV/MF for 2018 crosstrek CVT base, premium, and limited (36/10) for central NY? 13815
    For 36/15 ....
    Base - 64% and .00110
    Prem - 62% and .00095
    Ltd - 62% and .00105
  • marig500marig500 Member Posts: 1
    Can I get the RV/MF for the 2018 Crosstrek CVT, Premium and Ltd, (36/10) for zip 97211?
    Many thanks!
    Many thanks!
    PREM - 65% and .00095
    LTD - 65% and .00105
  • lucyredlucyred Member Posts: 95
    Hi can you please give me the residual value and MF for 2018 Subaru cross trek limited without the blind spot package for 36/12 in NY.  Thanks so much.
  • flatulentfoxflatulentfox Member Posts: 2
    Hi, could you please give me the RV and MF for the 2018 crosstrek CVT premium and limited, with eyesight and moonroof package? PA - 18425
    Thanks in advance.
    Thanks in advance.
    Prem: .00095 MF and 62% residual
    LTD: .00105 MF and 62% residual
  • kit185kit185 Member Posts: 3
    Can I get the RV/MF for the 2018 Crosstrek CVT, Premium 36/10 and 36/12 for MA - 01590?
    Many thanks!
    Many thanks!
    .00095 and 65% / 64%
    Thanks in advance.
    Could you also provide me with the numbers for 36/12? You guys rock!!
    Thanks in advance.
    Add 2% to the residual for 15K
