2018 Subaru Crosstrek Lease Deals and Prices
1567810
  • kyfdxkyfdx Moderator Posts: 274,051
    instarand said:
    When you folks are listing the MF, does this represent the lowest allowable by a dealer in that area?
    thanks for all the information, much appreciate this thread and all good pricing info!!
    Yes... that's the base rate for top tier credit
    RV and MF for 2018 Subaru Crosstrek CVT 12k/ 36 months in NY 10605. Base and Premium models. Thanks!
    Base: .00150 MF and 65% residual
    Premium: .00115 MF and 63% residual
  • medatudentmedatudent Member Posts: 11
    Thanks! Sorry but do you also have those numbers for a 15k lease (36 months) base and premium cvt.
    Subtract 2% from 12K/yr residuals
  • dasilo31dasilo31 Member Posts: 6
    MF and RV Subaru Crosstrek CVT for both Base and Premium model in Stamford CT 36 months. 12K and 15K. Thanks!
  • instarandinstarand Member Posts: 147
    Looking for MF for 06905 on a Crosstrek Limited - 10/12/15 36 month. Also, any July incentives available for lease or finance?
    12K/yr
    Subtract 2% for 15K/yr
    .00115 MF and 61% residual for 36/15
    Add 2% or 3% for 12K/10K
    No incentives
  • livintheoclivintheoc Member Posts: 60
    May I have the MF and RV on 2018 Subaru Crosstrek Base and Premium, Manual/CVT, for 36/12, and 36/15 in Los Angeles, CA?
    Base stick: .00105 MF and 61% residual
    Base auto: .00150 MF and 63%
    Prem stick: .00125 MF and 61%
    Prem auto: .00115 MF and 61%
    12K/yr Base: .00150 MF and 65% residual Premium: .00115 MF and 63% residual Subtract 2% for 15K/yr
    A dealer in the CT area is telling me that for the Crosstreck Premium CVT 12K/36months the money factor is actually 0.0115 and the MSRP is 24,970 (Edmunds says 24510). Is this dealer just making stuff up ? Thanks!
    12K/yr
    .00115 is the money factor listed in the post you quoted, so I don't see any discrepancy?
    Cars can come with options... If they have a unit with an MSRP of $24,970, then it likely has extra equipment, if that doesn't agree with other sources.
    Thanks kyfdx. What about 36/12?
    Add 2%
    .00115 is the money factor listed in the post you quoted, so I don't see any discrepancy? Cars can come with options... If they have a unit with an MSRP of $24,970, then it likely has extra equipment, if that doesn't agree with other sources.
    Its a diferrence of a decimal place. The MF you quoted was 0.0015 and the MF the dealer quoted was 0.0115. Thanks
    12K/yr
    12K/yr
    To be accurate, I quoted .00115 for Premium.
    All money factors start with at least two zeroes after the decimal. The dealer's quote is just a typo.
    He specifically emailed me “The money factor is .0115 not .00115”. Maybe I should just stay clear of this place. Lol
    Trust me.. he is wrong.
    I know its insane. Thanks
  • mfmar09mfmar09 Member Posts: 4
    MF and RV for Subaru Crosstrek CVT for both Base and Premium model in Michigan, 36 months/12K. Thanks!
  • dkgoodydkgoody Member Posts: 2
    Hi! Can I get MF and RV for Subaru Crosstrek CVT Limited in Los Angeles, 90012
    12k and 15k miles, 36 month
    I got a quote from a local dealer but I think they are marking up the MF
    Quote on Limted: Residual 68%, MF .00265%
    .00115 MF and 63%/61% residual
    That quote from the dealer is for 24/15.
    You are right! Thanks so much !!
  • ereisner1337ereisner1337 Member Posts: 1
    Residual and mf for 2018 premium 36/12k and 10k in Utah. Thanks.
    Also any special deals?
    Assuming CVT
    .00115 MF
    63%/64% residual
    No incentives
  • divine171divine171 Member Posts: 15
    Hi. I'm looking for MF and RV for the 2018 Crosstrek Premium Automatic with Eyesight, Blind Spot Detection, and Rear Cross Traffic Alert, 36 mon/15K miles in 07054 NJ. Thanks!
  • docozzydocozzy Member Posts: 7
    Good day gentlemen. Looking for numbers on Crosstek Premium with EyeSight, Moonroof, Blind Spot Detection, Rear Cross Traffic Alert, and Starlink.
    36 months, 12K. Northern California market.
    Thank yoU!
  • ted_underhillted_underhill Member Posts: 34
    What is the MF and Residual Value for the 2019 Subaru Crosstrek 2.0 Premium CVT at:
    36 mos/12k? and 15k?
    33 mos/12k? and 15k?
  • MichaellMichaell Moderator Posts: 269,835
    Thank yoU!
    .00115 and 63%
    .00115 and 63% / 61% for 36 months
    No 33 month term from Subaru
  • wsy2018wsy2018 Member Posts: 23
    edited July 2018
    hi Res,MF, incentives for Ltd with eyesight.36/12k zip 44124
    .00115 and 63%
    are the numbers the same for the 2018? (as opposed to 2019 which I see are out now).
    Sorry, those are the 2018 numbers, as this is the 2018 thread.
    No 2019 Impreza numbers are available, this month.
  • mdguymdguy Member Posts: 17
    Hi Michaell
    Would you kindly provide mf, residual value for the following
    2018 Crosstrek Premium Automatic with Eyesight, Blind Spot Detection -- 24 months/ 12k
    2018 Crosstrek Limited Automatic with Eyesight Blind Spot Detection - 24 months/12 k
    2019 Crosstrek premium (same as above)
    2019 CrossTrek Limited (same as above)
    Many thanks for your help.
  • camarowithanacamarowithana Member Posts: 14
    Hi, would you please provide MF and residual for 2018 Subaru Crosstrek 2.0 Premium CVT with EyeSight, Moonroof, Blind Spot Detection, Rear Cross Traffic Alert, and Starlink for 36/12 and 36/15 in Texas? Thanks!
    mdguy said:
    Hi Michaell
    24 month terms are not customer friendly, for Subuaru (.00265 MF)
    2018 Premium - .00115 and 63%
    2018 Limited - .00115 and 63%
    No 2019 Crosstrek numbers, this month
    .00115 MF
    63%/61% residual
  • pitabread55pitabread55 Member Posts: 3
    Looking for information for Limited with Eyesight in Wisconsin. 36 month 10/12K miles per year.
    .00115 and 64% / 63%
  • michagarmichagar Member Posts: 8
    edited July 2018
    Can I get the numbers for the CrossTrek JRE 36mo 12k a year please Limited With StarLink?
    Dealer Showing 63% Res for this model, but trying to find out the MF to make sure all this matches up.
    Also Same for Limited Starlink, Eyesight, Nav, Harmon Kardon, MoonRoof.
    Thanks!!
    Thanks!!
    Options don't matter... just trim.
    Michaell:
    3 questions...
    I was just quoted a rate by dealer for 36months/12k for a Crosstrek Premium .00165 and .63 residual value. I pushed back on the money factor saying it was .00115. He claimed Subaru has set it at .00165. Thoughts?
    Also when I am quoted a lease quote for a car (say MSRP 35k, Car price 33k and lease incentives 2k) with incentives. Does this lower the car price by 2k so the base cap cost is 33k - 2k = 31k?
    Finally, I have been using the advanced lease calculator (http://lease.guide/advanced_calc/) that enables me to put in all the inputs (sales tax, registration, dealer processing fee, acquisition fee) and I am getting large discrepancies between the dealer quote and calculator monthly quote. Do the dealers have some hidden additional profit formulas that are not part of the monthly calculators?
    Many thanks for all your advice. Much appreciated.
    mdguy said:
    Michaell:
    3 questions...
    Base MF is .00115
    SMF allows dealers to mark it up by .00050
    You have to ask those questions when you get the quote.
    See the answer to the 2nd question. If it doesn't match up, you aren't working with the actual numbers the dealer is using.
  • chrishjuchrishju Member Posts: 1
    Im sorry but I am slowly trying to understand how these numbers work but can you assist on a good lease deal? Like what can I expect for a good lease deal on this car.
    What I want-
    36 months
    12,000 miles
    2018 Subaru Crosstrek 2.0i Premium with EyeSight, Moonroof, Blind Spot Detection, Rear Cross Traffic Alert, and Starlink
    VIN: JF2GTADC8JH315472
    What I want-
    36 months
    12,000 miles
    .00115 and 63%
    Use this link to help understand how the numbers are used.
    https://www.edmunds.com/car-leasing/calculate-your-own-lease-payment.html
  • tuffsheddtuffshedd Member Posts: 12
    What is SMF? I have received a MF quote of .00215 and another dealership at .00165. Even if they are allowed to mark up, can that be negotiated? (This is for the 18 Crosstrek Prem with Eyesight in the 95691 zip).
    "Base MF is .00115
    See the answer to the 2nd question. If it doesn't match up, you aren't working with the actual numbers the dealer is using."
    "Base MF is .00115
    SMF = Subaru Motor Finance (aka Chase)
    .00050 mark up for profit
    .00050 mark up for tier 3 credit
    Some dealers will bump the MF until they pull your credit
