Subaru Crew - General Maintenance & Repair
If you have a 2000 OB, I'd be curious to know how your front end sounds over sharp bumps at about 10mph. I don't think it's the struts, because the car otherwise rides fine. I do feel like it's hard to keep the car going straight sometimes (seems to require constant correction), and the steering wheel feels numb on-center. The dealer checked the alignment, and it was OK. I suspect the tires, as they seem to have rather sloppy response.
Craig
I agree with texsubaru: if you could set it up in at least one different position -- preferably, any of several different positions -- to divide up the cargo area, that would be ideal. Of course, moving it around would be a bit of a pain.
Say, that gives me an idea: perhaps a slide-adjustable "net on rails", as it were. Squeeze a couple of clips, slide the net-hooks forward or back in the cargo area on either side, let go of the clips and the spring (inside the clip) clamps onto the rail. Voila, instant moveable nettting. You put your packages into the cargo area pressed against the rear seat-backs, slide the netting back until it holds it in place, and drive! Upon reaching your destination, you slide the netting all the way back to the rear, and unload.
(Say, can I get a patent on this? :-) )
Chris
-Frank P.
After I get the rear struts replaced, I'll focus more on the steering rack noise.
Any way to get the redesigned stabilizer links retro-fitted on '00 models?
-brian/subearu
Let's not get into the paper-or-plastic debate!
They call for a full alignment when you swap for performance gas struts, but I'm not sure about an OE swap. Can't hurt, I guess.
-juice
Dave
I have a strange suspicion that they'll end up replacing the right one as well. But, they won't do that until they 'decide' it's defective as well - when I bring it in to get the left one replaced - hopefully next week.
-brian/subearu
-mike
It was originally the left rear having the squeak/rattle. It has now migrated to the right as well.
I haven't been very happy with the service I've received. But, I guess I'm not happy since it's not fixed yet. It's not fixed yet since they're waiting for a part. We love our OB - we just hate having it broken.
My only remaining question is how a strut 'goes bad' in the first place?
-brian/subearu
-Colin
So I want to top it off. But with what? I call my selling dealer, and I'm told that they just put in whatever gear oil they have in their big drum. Same story at other dealers (one told me they use 30w motor oil). But I want to add to the factory gear oil with the same stuff. I call the trusty 1-800 SoA number and they tell me that in fact Subaru sells a specific gear oil, part number SOA635007. Call the dealers again, nobody stocks it. I call Darlene at Qsubaru and she tells me that the SoA gear oil is in fact Havoline from Texaco, 80-90w.
Call SoA again, confirm that the factory oil is in fact Texaco supplied (just checking...). Score one for Darlene vs. local dealers.
Anyway I'll go find some Havoline to top off my transmission. But here's my question: should I switch to synthetic? If so, when? Now? After 1000 miles? At a later mileage? And of course, which one will prolong the longevity of my transmission bearings and synchros AND will improve shifting a bit?
-mike
When I did a visual of the suspension parts (when I first noticed the problem), I did see what appeared to be seepage on the strut piston (or whatever it's called). So, again, I'd say these are just defective from the start.
Anyway, once these get replaced, I'm sure I'll be just as happy as the day we took delivery.
-brian/subearu
BTW, the current Impreza wagon has been around for eons, so parts should not be that hard to come by. Maybe they are using this as an excuse.
Craig
I'm thinking it was filled low at the factory. It's not leaking as far as I can tell.
#1151 of 1153: Wheel Bearings (katie00) Fri 03 Nov '00 (06:27 PM)
Sounds odd. Most posts on these boards are of far more mundane problems although the wheel bearing one has come up before. Patti from SOA looks in on the Subaru Crew - Meet The Members (Topic #20) board very regularly and appears to have an excellent track record on sorting problems (bless her).
Mind you even the best reputed manufaturers have occasional problems. I had a real Monday or Friday car previously (German made) and it was a constant worry.
Hope you get things sorted
Cheers
Graham
Anyone with any experience willing to share comments and observations?
Thanks to all,
John R.
Cheers!
Paul
Katie and c_hunter: Yes, there's a known problem on Forester rear bearings. I've had mine replaced twice in 13,xxx miles. Part of the problem (if not most of it) is how they're installed - if they're torqued down too tightly they get mashed and malformed, leading to premature failure. Darlene at Qsubaru alerted me to it, I filed a complaint with SoA, and Patti and crew worked directly with the dealer to supervise the correct installation of the new bearings. 1,500 miles later and no problems; I just hope it stays that way or else fails while still under warranty.
My 2 cents,
Ed
www.knfilters.com
Schuck's Auto Supply has 'em... if you have a Schucks!
Cheers!
Paul
Schucks!<<
No Schucks Auto Stores, but we do have Schnucks Super Markets. Guess I'll have to buy online.
Dave
Yep, we're practically neighbors here in the DC burbs.
I've already got 1K on the clock, I'll see if I can find a definitive recommendation for when to switch to synthetic.
Why do you think the manual transmission oil change on the Outback will be more difficult than on a Miata?
-mike
I imagine the Soob trannies are very similar from one model to the other.
Hey - you can be the first and then let us know!
-juice
I just use a piece of pressure treated wood with a channel cut in it, but the saddle is probably safer. Always use jack stands for safety.
-juice
Now it rides very quietly and the ride is firm/solid. No rattles or squeaks.
They originally were going to replace just the left one, but I mentioned the right one had started having the same symptoms. Luckily, they had another strut in stock and replaced both. It's the first he's seen of this problem.
I can only think that this defective set of struts has been slowly progressing (from bad to worse) during our 3 months of ownership. It must have been subtle at first, but it was during the last month or so that it became really noticeable to us. I don't remember it riding as nice as it does now!
Anyway, we're happy with our wagon again. Also talked to the service manager about the occasional brake squeal/squeak some of us have heard. He did the cleaning and also recommended an occasional hard stop now and then. He mentioned that the pads are glazing and that's causing the noise. I'll have to further research that since my brakes are not making the noise at this time.
-brian/subearu
Remove wheels. Remove pad. Sand lightly on pad with paper or smooth file. (DO NOT BREATHE PAD DUST. It's probably not asbestos but it's still not a good idea.) Reinstall.
Drive out slowly and make SURE brakes work. After this is confirmed, find an open stretch of unused road. Accelerate to 30MPH and panic stop. Do NOT keep foot on brake pedal after coming to a complete stop-- rotors will cool unevenly and warp. Repeat until brakes are VERY stinky and some pad fade is felt.
Drive home carefully and park for at least 4 hours. Pads are now bedded in.
-Colin
Springs actually absorb impact, while shocks or struts control the spring's motion. Bad struts won't do that, so the spring will keep rebounding, and it'll feel more or less like a Buick!
Colin: is that what shops call "scruffing" the pads?
My Miata's pads have plenty of life, but they squeek a bit. Think that'll help?
-juice
Here's a tip from a trusty old mechanic I used to know: a quick way to clean out brakes is to get going in reverse at a pretty good clip, and then hit the brakes hard. If your brakes are squeeking due to dust build up, this should take care of it. It's especially useful for drum brakes. Won't help if the pads are glazed though.
Craig
Any source recommendation appreciated. Willing to buy from online supplier.
--Need front & read Windshield Washer Pumps for '98 Outback.
Tropicalaurs@hotmail.com
1) Just what the heck is a "throttle body" and what exactly does it do?
2) How difficult should one be to replace?
3) Does $780 sound as ridiculously high to anyone else as it does to me?
4) Can anyone recommend a Mazda equivalent to Darlene at QSubaru to contact for a parts quote?
5) And if anyone has better suggestions for where to post these questions, I'd be interested in those.
-mike
There is a 626 topic under Sedans, but it's not nearly as active as the Crew.
I'm not an expert on throttle bodies, since I've never had to touch one. Our 626 had a major power loss, and it turned out the fuel injectors were clogged. We cleaned those, changed the plug wires, plugs, fuel filter, air filter, and it was resolved for under $400.
-juice
What does this have to do with your throttle body? Perhaps it too has become gummed up with fuel deposits. You might be able to clean it but I wouldn't be suprised if you have to replace it in the end (again, I'm guessing). In the 00 GT, I add a bottle of Chevron Techron fuel injector cleaner to the fuel (whenever I think of it -- haven't come up with a regular interval but I think once a quarter would be good). Hopefully someone mechanically enabled will have a suggestion for you. (Also try searching USMB, link above).
..Mike
-juice
I've got a '00 OB with about 4500 miles on it and I love it so far. The only problem I have with it is the paint. I just got back from a weekend trip and put about 450 miles on it that were mostly interstate driving. Although, I tried to distance myself from the big 18-wheelers I have 4 paint chips (obviously from stones kicked up) on the front downward sloping section of the hood. This is the painted METAL section of the hood and not the vinyl cladding on the front bumper.
My question is if anyone has the vinyl hood protector that's shown in the OB Accessories pamphlet? I'm not interested in the full bumper and hood covering "bra" but just the piece that is separately sold to protect the front part of the hood. Anyone have any thoughts whether good or bad? I'm probably order from Darlene if it's a worthwhile purchase.
RangerRon
It fastens to the bottom with self-tapping screws (they may be torx types) and uses spacers to keep from scratching the hood. It had a good OE fit to it, too.
-juice
-mike
Evaluate the need for snow or ice tires. All-season and all-terrain tires do not perform well in all conditions. To be most effective, snow tires should be mounted on all four wheels.
Keep tires properly inflated as specified in the owner's manual. Use a quality gauge (not the one at the gas station) and check tires when they are cold -- pressure can increase up to 8 psi when tires are warm from driving.
Check the spare tire to make sure it is inflated properly; make sure your lug wrench is in the trunk; and carry a tripod-type jack for safer tire changes on slippery surfaces.
That means that a Forester properly set at 29/29 psi for the summer (92 degrees) can drop dangerously low to 23/23 psi in freezing weather (32 degrees).
Mine was fine, but the wife's car was way low, down to 22psi on a very cold morning! I'm glad I checked!
-juice
Is it the same in the states??
gus
Thanks again
-mike
The rest of the installation is a snap, literally. The spot between the headlights and the grill gets snapped into place with a plastic fastener.
Rubber/plastic 'bumpons' are provided for the deflector. They prevent the deflector from actually coming in contact with the hood. 3M plastic tape is provided to place on the hood itself directly under where the 'bumpons' are.
As far as driving with it: I've driven at speeds of 80 MPH with it and haven't seen it wiggle at all. It is a tad hard to clean under it with it installed, but a cloth with fit beneath it. It also can be removed in about 2 minutes if you need to. Since it's fastened under the hood, you need not worry about it being stolen - unless they open your hood.
-brian/subearu
Chuck
FYI: Best price quote on a 626 throttle body so far was $630 from www.mazdadiscountparts.com, based in Cincinnati, Ohio. (About $50 less than Roebucks).
