Was there drama in getting the Prelude parked safely? So how'd you get into work?
And hope for the best. You seem to be running out of cars now. Down 2.
I was under the impression that Honda clutches were bulletproof for a long time.
You might also test it by pumping the clutch pedal a few times to see if it goes into gear then. If that does it, another sign of faulty hydraulics.
Sounds reasonable to me.
And, a scant two-day drive, if you're taking your time. Barely enough to take a deep breath!
that is certainly an unfortunate expense. I assume he realizes it is the fancy version that takes longer to replace the clutch? Not sure how the pressure plate would just let go if the clutch disk is OK. But I am certainly no expert.
at least you should be good for another 10 years.
