2019 Toyota Highlander Lease Deals and Prices
1161719212240
  • raj_amarraj_amar Member Posts: 42
    edited June 2019
    hi Can i get RV/MF/Incentives for Highlander AWD XLE and Limited platinum AWD for MA 01721. Acquisition fee for Toyota. Term 36/12
    Term 36/12
  • MichaellMichaell Moderator Posts: 269,522
    .00043 and 62% (XLE) or 58% (Ltd Plat)
  • DiggleDiggle Member Posts: 4
    Looking for the Lease Incentives, Res Value and Money Factor for Highlander Hybrid XLE. 36 mo/12K miles
    Zip Code 02072
  • kyfdxkyfdx Moderator Posts: 273,342
    Zip Code 02072
    .00285 MF and 59% residual
    Hello, Looking for the Lease Incentives, Res Value and Money Factor for Highlander Hybrid XLE. 36 mo/12K miles Zip Code 02072
    .00285 MF and 59% residual No lease incentives
    How about XLE? Res value and MF.  36 Mo, 10k.
    Zip 02072
    Diggle said:
    Zip Code 02072
    Zip 02072
    AWD?
    .00043 and 63%
    Much, much cheaper....
  • johns525johns525 Member Posts: 83
    johns525 said:
    Can I get the RV/MF/Incentives for Highlander Hybrid XLE and Limited? 36/12
    What is your ZIP code?
    Doh, sorry, 91387
    Doh, sorry, 91387
    Either trim
  • malloreehmalloreeh Member Posts: 17
    Could you please give me the MF & RV on a limited Platinum AWD (36/12) for Kansas (66213)?
    .00166 MF and 58% residual
  • phxdavephxdave Member Posts: 25
    edited June 2019
    Can I get the RV/MF for Highlander XLE (and AWD if different) for 36/12 (and any shorter term like 30, 27 or 24 months). I presume 10k is +1% on RV.
    Surprised on variability of MF reviewing last 3 pages. I thought MF is national.
  • Hat2000Hat2000 Member Posts: 6
    Can I get the RV/MF for Highlander Platinum AWD 36/12 zero down, for 01923? Thanks!
    Coming to end of 36 mo lease in July, Im way under on miles, had 36k allowed, currently at 27k.  Should I assume my res value is a few points higher than originally calculated?
    2016 Tundra Crew Max, SR5, 4x4 5.7L v8, 5.5' bed
    MF is highly regional for Toyota.
    What ZIP code do you live in?
    .00043 and 58%
    No - the residual value is fixed.
    The car may be worth more than that; take it to a CarMax and see what they offer you and compare that to the residual value.
    edited June 2019
    85255
    Also check with VROOM and Carvana.
    85255
    .00085 MF
    61%/62% residual for FWD/AWD
    10K/yr is not offered
  • usmanakr86usmanakr86 Member Posts: 25
    Hi can I get MF and residual for following
    2019 Highlander LE XLE SE Limited
    24/36 12k term
    Zip 06518
    Also is NY in a different region than CT for Toyota leases or would the numbers be same?
    24/36 12k term
    Zip 06518
    NY and CT share the same programs.
    That's 8 sets of numbers - 16 if you wanted both FWD or AWD (you didn't specify)
    Please give us your top three choices of trim and term.
    Sorry AWD
    XLE SE Limited
  • albert_palbert_p Member Posts: 25
    Can I please get the Resid, MF, incentives on 2019 Toyota Highlander AWD XLE and SE in 07090 for both 36 12k and 15k?
    edited June 2019
    Sorry AWD
    XLE SE Limited
    .00056 and 62% / 63% / 59%
    .00056 and 60% / 61%
    Thank you so much also does Toyota allow msd?
    Maybe.
    What we think we know is that MSDs are only allowed when you start with the "standard" MF from TFS, which is .00285.
    Even with max MSDs applied, the MF would still be higher than the .00056 we quoted you earlier.
    36/15 .00056 and 60% / 61% No lease incentives
    Thanks Michaell. What about for 36/12?
    Add 2% to residual.
  • saturdazesaturdaze Member Posts: 36
    Hi, can you please let me know the MF, residual, and any incentives for a Highlander XLE V6 FWD in 29910 zip in SC for 36/10 & 36/7.5 if available?
    edited June 2019
    .00118 and 67%
    No 10K available for SETF
  • hpnas47hpnas47 Member Posts: 72
    Can I please have the MF, RV and any incentives for an XLE V6 AWD in 10028 for 36/10
    .00056 MF and 63% residual
  • Kp213Kp213 Member Posts: 32
    Can I get the MF, residual and incentives for 2019 Highlander hybrid limited platinum in 90278 for 12/36 (do they offer longer leases and is it worth it?) Thanks!
  • esquirevolesquirevol Member Posts: 5
    Can I get the MF, residual, and incentives for a 2019 Highlander XLE in 37174 (36/12 works for me). Thanks!
    .00285 and 57%
    36 months is the sweet spot.
    FWD or AWD?
    .00285 and 57% 36 months is the sweet spot.
    Thanks! Can I also get the info if I got the platinum non hybrid?
    For the AWD and FWD platinum non hybrid. Thanks!
    Kp213 said:
    .00285 and 57%
    .00061 MF
    57% FWD
    58% AWD
  • NikolaTeslaNikolaTesla Member Posts: 1
    edited June 2019
    XLE AWD in 11412 for 12/36. Thanks!
  • atlas123atlas123 Member Posts: 29
    edited June 2019
    hi all - for 2019 Highlander- 36/10 36/12 1- hybrid platinum awd 2 -xle awd 2-limited platinum please -zip 60601
    .00056 MF and 62% residual
    1- .00285 MF and 57% residual
    2- .00197 MF and 62% residual
    2- .00197 MF and 58% residual
    Can you plz tell me residual and MF for Rav 4 XLE AWD in Gas and Hybrid. 10k 36 Mo.  ZIP 02072
    Gas: .00080 MF and 64% residual
    Hybrid: .00143 MF and 66% residual
  • telfer19telfer19 Member Posts: 48
    hello, can you provide me with the MF and res value of 2019 Highlander XLE and Limited trims in zip code 28205?
    FWD or AWD?
    FWD   36/12k
