1186118621864186618673158
    Yea, the editor is trying to display everything in landscape mode (wider than high)
    If you click on those photos they open in a new tab in the proper orientation. Definitely something to address.
    iPad test
    wide
    Tall
    VERY interesting... displays properly on my iPad, but the tall one is rotated on my laptop
  • ab348ab348 Member Posts: 20,492
    edited June 2019
    Testing a picture post. Let's see if my dearly departed Rusty posts upright or not.
    EDIT Hmm, it inserts the picture above the text I already typed. How do you write something and then post a pic below?
  • kyfdxkyfdx Moderator Posts: 269,433
    I ran into that at first as well. Type your text, hit Enter and then click the Image icon
    If you don't hit enter before adding the image, it treats the text as if it was a caption for below the image since it's in the same paragraph, like this
    Or, since a picture is worth a thousand words, it assumes you WANT the image front and center 📷️
    ALL good stuff though... getting us poking around and finding out what's new
  • imidazol97imidazol97 Member Posts: 27,731
    edited June 2019
    My favorite Corvette.
    I wrote my username and password on my arm with a black sharpie in case I got blown away by the winds of change here, but I guess I didn't need to do that. Seems to work logically. How do I get the black sharpie writing off my skin? 😣
    The sideways pictures in the earlier posts here that I understood some to say go to the correct upright position when clicked, don't do that for me on Win 10 laptop in Chrome.
    Trying a portrait pic direct from my iPhone:
    Edit: I did hit return after typing the colon here.
  • sdasda Member Posts: 7,683
    A picture taken wide, horizontally posts fine, upright, vertically needs to be rotated. This was posted from my phone. Hilton Head beach, btw.
  • oldfarmer50oldfarmer50 Member Posts: 24,434
    edited June 2019
    New technology? I’m scared!😴
    ok pictures load but if I want to edit them out before I post how is that done?
    why do I have to click on the little camera icon to see the picture? I used the icon on the far right at the bottom to post it. Maybe I’ll try the
    second from left.
    ok, it worked but split the text. I’ll keep trying.
    edited June 2019
    OK, this just keeps getting worse.
    I highlighted just your text line and hit quote. It didn't seem to matter as it also quoted your pic, which I did not want to include. What's up with that?
    My original reason for posting was to indicate that I did what you said, but it still inserted my pic above my text. This seems rather flaky.
    EDIT: Double line returns are back too! Maybe it only does that when there is a highlight/quote used?
    Here is a picture
    Type your comment, then hit return/enter. Then post picture
    Rusty looks pretty comfortable. Funny how a cat can just stop and sleep. They are characters.
    I'm typing my comment,
    now I'm going to hit enter and then post a picture:
    edited June 2019
    Ok, that didn't work so well. 😮
    PS: Never thought I'd say this but I miss our cheesy little car Emotorcons. They weren't much, but they were ours. Now we have thousands of the same social media ones that most people never even understand, much less use.
    After talking with my daughter for over an hour yesterday, I got talked into assisting her in finding a place to live. She starts her new job on July 15th, so she needs to sell her house, find a place to live, and then drive down here to South Florida.
    This morning, I am up in Delray Beach with her realtor looking at apartments. Not cheap, that’s for sure. 2 bedroom 2 bath apartment runs about $1700 a month. I suggested that she look in Coconut Creek just south of Boca Raton or even west Deerfield Beach. Apartments are $200+ less a month for nice units. But I am not getting anywhere with her.
    So I am running around hoping to find something she likes. The realtor is doing the driving at least. I am already looking forward to my nap! 😆😗
    Uh, I hate to mention this but I just discovered something interesting quite by accident.
    The problem for Firefox users was that the pull-downs here in Vanilla were sometimes non-responsive.
    I just went to click on the down arrow next to the head icon at the top of the screen in the Edmunds banner to see if there was a user setting or some such that could be tweaked. Guess what? It's non-responsive too.
    Could the problem have been not the forums code, but some site-wide thing?
  • driver100driver100 Member Posts: 32,643
    The typical standard for modern usage is 100 amps; less than 100 amps may not be adequate for your needs. Large homes, and homes with central air-conditioning or electric heat will need more power, typically 150 to 200 amps
    I got that from google.
    Too bad JMonroe....I am still around!😀
    Just for the record, none of the sideways orientation photos rotate into proper orientation when you click on them. They open in a larger size in a new window but are still 90 degrees off. Win 10/Firefox.
    For some strange reason, when I quoted driver's post to ask a question, it would only let me post ABOVE the quote box. No way to get the cursor underneath it as usual.
    @driver100 , what I wanted to ask you was, what did you do to get all of the bold effects in your post?
    OK, maybe I can explain the TRICKY quote part of a post better. Also, you noticed that hitting Enter creates a double space (new paragraph). That's how it works, but back to partial quoting:
    First, you copy and paste the part of the post you want to quote and paste it into the comment box:
    Then instead of clicking the word Quote you see at the bottom of the post you're quoting from, you click on the quote symbol in the paragraph menu and Choose Quote
    Hit Enter again to "close the quote"
    Then change back to Paragraph "mode" (for lack of a better term) to type your response to the partial quote
    It's not as complicated as that "microsecond by microsecond" description makes it look
    edited June 2019
    @ab348
    Yes, getting text under a quote or over an image seems touchy. If you don't watch where you click in the comment box when you go to type, the cursor seems to like to go above quote boxes and below images
    Also note that when you use the @ sign to get the attention of a particular user like I did with this one, it displays in bold instead of looking blue like a link. It still links to that user's profile though
    I copied and pasted....that was the way it appeared on google.
    I WILL TRY TO GIVE YOU THE LINK HERE IF I CAN DO THIS
    I don't think it imbedded. Also, my reply to ab was in bold for some reason!
    Good luck Jip. Take it easy on those waitresses !
    I know I am a dinosaur but....I hate change!
    edited June 2019
    Testing. Testing.
    OK, I wasn't doing what you posted with the paragraph menu and quote function. But I cannot get a reply box without hitting the "quote" function below the original post. When I do it quoted your entire post. Are you saying I need to go all the way down to the bottom of the page and act like I'm starting a new post?
    Working on figuring out the html thing. Hang with me :)
    Heh... my brain is on overload from questions, but in a good way. AND I'm getting a LOT of editor experience FAST
    To make links in your text. Just highlight the text you want to turn into a link, and you'll see the hyperlink choice in the editing tools that appear. Paste in the URL and hit enter. POOF
    Like... you should go to Edmunds!
    edited June 2019
    @ab348 if you are going to partially quote a post, yes, you go to the comment box at the end of the page, paste the text you're quoting there, and do the rest...
    If you simply hit the quote link at the bottom of an individual post:
    ...it quotes the entire post and pulls it into a box down in the comment box and you type whatever you're going to type.
    The two different types of quotes display differently. The whole quote has the quote in a box like this:
    While the partial quote method shows the text you quoted in gray like this:
    Two different types of quotes that create different looking posts.
    I don't think it turned out right....I was trying do a partial quote that was from PF
    edited June 2019
    @driver100 That looks EXACTLY like a partial quote from what I was telling ab348! Gold star!
    edited June 2019
    Ok, I tried to post a YouTube video and I just get a link. How do I make it appear like before?
    edited June 2019
    OK , now I got it just have to figure out why my edits all became separate posts.
    @oldfarmer50 you got the you tube thing with that Embed icon (right next to Image)
    I did that a few times. When you click Edit to edit your post, the comment box below is right there and looks like you maybe should type there. After I did that once, I realized... DOH! :)
    edited June 2019
  • stickguystickguy Member Posts: 53,853
    Scotty has eyes? Who knew.
    Actually this is going smoother than I hoped. Questions for sure, the mods even have them, but no implosions 🙂
    Someone shared this image from the warmup laps at LeMans in 1999.
    @PF_Flyer
    Well, I'm unsure if the cure isn't actually worse than the disease. This is not at all intuitive, seems flaky in its own way, and I find it very cumbersome to use. I really do not like it. There, I've said it.
    Can't we just put a banner on top of the old way saying "We recommend you use Chrome" and go back to that?
