2019 Toyota Highlander Lease Deals and Prices
1212224262740
  • kyfdxkyfdx Moderator Posts: 271,234
    ark4766 said:
    Hi, can I please have the residual and MF for a 2019 Highlander SE AWD, 36/12 in PA (19047)? Thanks!!
    .00070 MF and 63% residual
    Highyatoy said:
    Hi, could I please get the MF and Residual for a 36/15 lease on an AWD Highlander Limited in zip code 44138? Thanks!
    .00036 MF and 57% residual
  • bkingbking Member Posts: 20
    Hi, could I please get the MF Residual and incentives for a 36/15 lease on an AWD and FWD Highlander XLE V6 for zip code 33511?
  • Vadiksf415Vadiksf415 Member Posts: 25
    edited August 2019
    Heard MF dropped for Highlander....can I get 36/12k and 36/15k on Highlander XLE AWD in 94066.
  • MichaellMichaell Moderator Posts: 267,765
    .00116 and 66%
    Either drive
    .00125 and 60%
  • mripgurumripguru Member Posts: 63
    Please provide MF and RV for 36/10k and 12K for Highlander XLE AWD in zip 22554.
  • Billy_123Billy_123 Member Posts: 90
    Hello! Can I please have MF, residual, and incentives for Highlander
    XLE AWD
    LIMITED AWD
    in 22079 for.... 36/12 Thanks in advance!
    .00070 and 62%
    XLE AWD
    LIMITED AWD
    .00070 MF
    62%
    59%
    No incentives
  • bogey1oparbogey1opar Member Posts: 18
    Hello, can I please have MF, RV 36/15, Incentives for Highlander XLE AWD in both 27707 and 24541? Thanks!
    .00070 and 62%
    Does TFS not offer 36/10 in this region? If they do, what is the RV change?
    Does TFS offer 39 months?
    27707
    .00116 MF and 66% residual
    24541
    .00070 MF and 60% residual
    mripguru said:
    .00070 and 62%
    +1% for 10K/yr
    39 month term is not supported
  • dan_407dan_407 Member Posts: 11
    SE AWD
    XLE AWD
    LIMITED AWD
    LIMITED PLATINUM
    in 07020 NJ for.... 36/12 Thanks in advance!
    .00038 MF
    63%
    62%
    59%
    58%
    No incentives
    Hi
    for 36/10, will the residual be +1% for all trim levels quoted above?
    SE AWD
    XLE AWD
    LIMITED AWD
    LIMITED PLATINUM
    .00038 MF
    63%
    62%
    59%
    58%
    No incentives
    Hi
    That is correct
    mripguru said:
    .00070 and 62%
    +1% for 10K/yr
    Is 39 month term supported in zip code 19372? If so, please provide MF and RV for 39/10 for Highlander XLE AWD.
    Also, please confirm that lease term availability for TFS is based on dealer location and not location of registration.
    mripguru said:
    mripguru said:
    .00070 and 62%
    +1% for 10K/yr
    39 month term not supported in PA, either. Not aware of any region where it is supported, frankly.
  • momo97momo97 Member Posts: 58
    Can i get MF and RV for Highlander SE AWD in 94022 zip code?
    .00125 MF and 61% residual
  • kfogarty259kfogarty259 Member Posts: 6
    Hello, can someone tell me the base money factor, residual and incentives for a 2019 highlander Le plus for 12k/36m? Zip 97229. Thank you.
    Forgot to mention: AWD
    .00042 MF and 61% residual
    $500 lease cash
    $500 lease cash
    Thank you. I see online a $3000 factory rebate. Does that not apply if I take the incentive money factor?
    $500 lease cash
    Correct, does not apply to the special lease program.
    $500 lease cash
    Makes sense. They are telling me that the base MF without the incentive rate is 0.00255. Is this true, or marked up?
    $500 lease cash
    You sure that isn't for the Hybrid model?
    Tell them you won't sign any deal unless you get the base MF.
    Not common for Toyota dealers to mark up the MF
    $500 lease cash
    .00255 MF if you want the rebate?
    If so, that’s lower than the last time we saw it. (which has been a few months)
  • avol77avol77 Member Posts: 5
    MF, RV, and lease incentives for 2019 xle & SE awd 36/15 in 46514. Thanks!
    .00197 and 60% (XLE) or 61% (SE)
    no incentives
  • bill466bill466 Member Posts: 11
    edited August 2019
    Just reporting back a great lease deal I got today. 2019 Highlander Limited Platinum AWD V6.
    MSRP: $49,168
    My Price: $43,718
    36mo/10k . 3.24% APR.
    Then I rolled in all fees, tax (4.5%) & GAP Insurance.
    First Quoted price was $802/mo, I got it down to $629/mo
    I had Toyota and Ford negotiate against each other to get the best deal. Thanks Edmunds team for the help!
  • HumeorusHumeorus Member Posts: 36
    Could I please have MF, RV, and any incentives for Limited, 36/12, FWD and AWD in 89119
    MSRP: $49,168
    My Price: $43,718
    Thanks for the report.
    .00082 and 58% (FWD) or 59% (AWD)
    no incentives
    hi folks,
    I'm getting close to making a deal on a highlander. Just not getting any response from dealers about the MSDs. Can MSDs be applied to a base rate of 0.00038? In my estimate, i think i should be able to put down 4 MSDs. How do i approach this with the dealers?
  • flydrummaflydrumma Member Posts: 14
    May I have the MF and incentives for lease 2019 highlander in 37211
    Hi
    To confirm, the money factor for NJ and NY zipcode 11580 is 0.00038 for all trim levels?
    For example: 10k/36 month SE AWD should have a MF of 0.00038 and residual of 64% ?
    and for 10k/36 month XLE AWD should have a MD of 0.00038 and residual of 63%?
  • clfehlingerclfehlinger Member Posts: 29
    Looking for 36/12k mf residual and incentives on a Highlander LE FWD & AWD. Zip code 47130
    dan_407 said:
    hi folks,
    From everything we've heard, you can't use MSDs with the special money factor
    Which trim?
    Also, FWD or AWD?
    .00036 MF
    62%/63% residual for FWD/AWD
    dan_407 said:
    Hi
    .00038 MF for all gas models
    Correct on the residuals
    Any incentives?
    .00036 MF
    .00036 MF
    Any incentives?
    .00036 MF
    .00036 MF
    None
    no incentives
    Thanks. Could I please have the same for XLE? Also, does the $3000 customer cash not apply to leases? It isnt specifically excluded on the website.
    no incentives
    61%/62% residual
    Customer cash isn't applicable to the lease program.
    no incentives
    61%/62% residual
  • spryzapspryzap Member Posts: 14
    Hi, can I get the MF and residual for a 36/12 on the LE Plus FWD, zip code 77381? Thanks.
    @Michaell do you have rv and mf on Highlander XLE AWD in 94066 through Ally Bank and US Bank?
    .00135 MF and 60% residual
