Visitor Agreement.
This market will keep a man honest!
On another note, got to see a new Corolla Cross yesterday on the way home. It was a dark blue LE model and liked the color. Think that dark blue over a gray would look really nice. Size wise, think it'll work here at the house so we'll just have to wait & see. Still love the white pearlized paint and think that'll be the color I choose. No giving up things this time around, decided I've got to have the JBL audio and the roof. Think there's only one kind of alloy but if they do have the Limited alloy as a choice, I'd go with that also. Just want what I want this time and willing to wait.
Dropping the off off Monday morning to have the brakes checked. Since I'm keeping it for awhile, might as well address this issue as I feel a bit unsafe at times.
A customer’s RHD 1992 JDM Civic SiR
Speaking of back seats -- is an Uber ride the only time you ever ride in the back seat? I have known people who could not ride in the back seat without suffering minor motion sickness.
What is the current price?
Actually…yes, now that I think about. I normally ride upfront.
$64k.
Filled up the Jeep on my way home from work. Hand calculated 29.77 mpg including charging up every night.
Yes we moved her in about 4 years ago.
https://hartford.craigslist.org/cto/d/manchester-2006-acura-rsx-type/7466446470.html
Saw this sweet looking RSX Type S - looks like an ideal C&B candidate.
I think your son needs to write a book.
Given the fact they’re driving me to or from a mechanic, I won’t confirm or deny whether there was weeping.
I'll take all the all old Hondas and Acuras.
What is the current price?> @roadburner said:
Original asking price on the carfax was $66k ($65,987)
Here is current carfax. The “carfax value” has dropped quite a bit as well as the “savings”
102K Miles Sold for $10.3
90K Miles Extensively Modified Sold for $15.7
61K Miles sold for $17K
Can I assume this is the M4 in question for @roadburner ?
Was there something going on with it?
Can someone show me the opposite?
That’s the one. RB has been following it. It is RB spec other than DCT transmission- otherwise I still think it would be in his garage.
How many miles? How roomy is the M4 compared to the M2?
12K miles.
I suspect a bit roomier than 2 series/ M2. The current 3 series is about as big as earlier 5 series
https://www.bmwblog.com/2018/04/20/should-you-buy-the-bmw-m2-competition-or-bmw-m4/
Dropping off the Golf Sunday evening at my mechanics so he can get an early start on Monday. Luckily they have a drop box where I can leave my spare set of keys. Hoping he will be able to work his magic and raise the pedal a bit. Having disc brakes at all four corners means I can't go in reverse while using the pull up emergency brake to tighten them. Used to do that in my vehicle that had drums in the rear & usually did the trick. We'll see happens. Almost time for an oil change, June 10th will be a year, but since I haven't even driven 2500 miles, might just wait awhile longer though it is cheap insurance to just have it done while he has it there. Will talk with him Monday morning and get his opinion on this. Just looked at my schedule and yep, just over 3K miles since the last change. Since I do mostly short trips now, would consider that style more severe as the car never has enough time to really warm up, most trips now are between 5 to 15 minutes actually. Will let him look at the oil & let him tell me his thoughts. Cheap insurance really as it's staying in the garage for the time being, so really need to take care of it.
The Ford OLM caps the oil changes at 12 months. The one in my Mustang would drop about 2% per week even if it wasn’t driven.
Sandy, nothing but short drives is worse for oil because it rarely gets heated up enough to burn out any contaminates. and as others noted, cheap insurance. probably not a big deal if you wait until June though if you feel like going back again.
might be time for new pads though. Generally the pedal drops as the pads wear, because the fluid level drops. I had that once (forget which car) after a fluid change. I think they did not fill it all the way (dealer did it) and my tire shop would not top it up per policy. It is supposed to be a way to tell that brakes are worn. I had to twist their arm a bit to convince them (brakes themselves were fine otherwise). New pads and fluid topped off to the max fill line likely takes care of your issue.
More fun with an Italian:
Wife complained the Fiat trunk wouldn’t open again. Happened once before when my son did some sequence of convertible opening and trunk opening that upset the car. Eventually read that the top needs to be reset, much like how you reset the auto-up feature on a window, and that allows the trunk to unlock again. (FYI, trunk will not open with top down to prevent people from breaking the rear window.)
Went immediately to the reset procedure. After trying that probably a half dozen times, I decided that there had to be something else. I disconnected the battery and left the car alone for about an hour while I did other stuff. Reconnected and tried the reset again, with no luck. Time to take a look at the electrics. Went through the backseat and pulled the emergency release. I removed the handle and tested the button. It worked fine. Reinstalled the handle and went to check the motor, but the button then worked. Thought maybe I had just cleaned the connections while testing and all was good. Closed the trunk and it would not open again. Release it again, played with it while open and it worked. Closed, no work. Alright, this has to be a bad wire issue. Pulled the wiring apart from handle to under the roof, cut it out and spliced in replacements. Now it works. Took most of my afternoon, though.
I drove 608 miles since the last visit to a Sinclair station, averaged 102mpg with 80% of the power supplied by the results of Mr. Franklin's kite discovery. After, I stopped at a municipal lot a mile down the road, to visit my favorite bakery, where there are two Chargepoint stations, formerly gratis. Now $.25/kWh; thank you very little town of Dedham.
If I knew I was going to have to pay for car shock therapy, perhaps I wouldn't have gone that route! Can you imagine the nerve?
The Gold aisle looked very sparse. I’m pretty sure there was a Trax in the lineup. I was eyeing a Cherokee since I had one of those before and liked it. There was also a previous generation Sienna, which would have been far more comfortable and refined than a lot of the other choices. Lucked out and saw an Edge further down the line. It’s a 2020 with the Ecoboost and AWD, so the same power train as the Maverick I have on order. Drove it about 10 miles to the hotel and, so far, so good, although I’m finding the lane keeping assist a little overbearing.
She's thinking she wants either a PHEV or an EV (shocker!) - they filled up the Infiniti last night at Costco and it cost $94 to fill the tank.
My sister is leaning towards a luxury PHEV SUV, and the short list includes:
1. Volvo V60 Recharge
2. Lexus NX450+
3. Audi Q5e
I'll go on record and predict she'll end up with the Lexus - she had a used RX400h for a number of years, and really liked it. Audi is the dark horse, while the Volvo - in addition to being a wagon - doesn't exude the 'luxury' feel she really wants.
I did tell her that she should begin looking for cars to test drive now, as I suspect it will be 6 months before a vehicle comes available.
The Q50 has 28,000 miles and might have some equity in it, which would help. Don't know if she's planning to buy or lease this one.
My S-I-L and her husband both have a late model Edge. They like them a lot.
No wonder Chrysler sold to Fiat.
Sounds like the same setup. What led me to look to the handle in the first place was a post online from someone who was smart enough to rebuild his (which amounted to a hidden resistor at the end of one wire) rather than spend the $300.
Dear Steve,
I hope this email finds you well. Please see below for an important message regarding your current vehicle from our Managing Owner, Mark Cohen. Mr. Cohen is very interested in purchasing your vehicle. Because of the current inventory shortage, pre-owned vehicle values have never been higher so we're willing to pay up to $4,000 OVER the current KBB trade-in value. We have identified YOUR vehicle as one that is in high demand so we really want it.
There is absolutely no way I will part with it, before then. I might buy something else to play with, but it is so well suited to me, I have no reason to get rid of it.
We took delivery of some new 2022 Ford vehicles lat week, Escapes & Edges and loved the new Edge. They drive nicely with plenty of power and the new dash is ergonomically easy to use. Even though it's just too darn big for me, liked it better than the Escape, more of the size I'm looking for. Just wish Toyota would do something with the interior of their Corolla line-up...very dull & boring & just needs a total redo to bring it into the 21st century. Big reason I'm not in such a hurry to get a new one is am hoping the folks at Toyota will finally decide to revamp the whole Corolla line. Compared to the Honda Civic, it's just super boring & needs some fun added. I get that why mess with what ain't broke but, Toyota, your interiors need a kick in the butt to make them more modern and do think overall, their customer base will like it. Honda really nailed it with the new 2022 Civic in every way & think Toyota is missing a big opportunity here by just doing nothing!
Ignore him. I will pay you UP TO $1Million for your car!! When can you come in?
Of all of my rejects, I wish I would have kept that 2-series. Great balance of performance and comfort at a steal of a price. And a bit of that old school BMW feel. That I miss.
2025 BMW i5 - 2017 911 C4S - 2025 BRZ - 2025 MB GLE450e - 2024 Genesis GV60 - 2019 Cayman
